SU1500RTXL2UA
SU1500RTXL2UA
    TRIPPLITE
    UPS TRUEONLINE 1.5KVA 1200W 6OUT
SU1500RTXL2UA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 120V 1.5kVA 1.2kW DoubleConversion UPS, 2U Rack/Tower, Extended Run, Network Card Options, USB, DB9 Serial Highlights ● 1500VA / 1.5kVA / 1200 watt on-line double-conversion 2U rack/tower UPS ● 120V +/-2% output at 50/60Hz, high efficiency economy mode option ● Expandable runtime, Hot-swap batteries; 19 in / 48.3cm installed depth ● USB, RS232 & EPO ports; support for network card options ● Front panel status LEDs with detailed load and battery metering ● 2 independently switchable output load banks ● NEMA 5-15P input; 5-15R outlets ● To use the Auto Probe feature, this product requires a WEBCARDLX network interface (sold separately) running LX firmware update 15.5.2 or later MODEL NUMBER: SU1500RTXL2UA Package Includes Description Requiring only two rack spaces (2U) in a standard rack enclosure, Tripp Lite's SU1500RTXL2Ua SmartOnline UPS System protects connected equipment against data loss, downtime and equipment damage due to power outages, voltage fluctuations and transient surges. Featuring true on-line operation with pure sine wave output and zero transfer time to battery, it provides the highest level of power protection for mission-critical equipment. Internal batteries support connected equipment during blackouts, and runtime is expandable with optional external battery packs. The SU1500RTXL2Ua has six outlets arranged in two individually controllable load banks that can be used to reboot select equipment on demand or maximize battery runtime for mission-critical equipment. USB and DB9 communication ports support messaging of detailed UPS operational parameters and line power status. Included PowerAlert UPS monitoring and unattended shutdown software provides management support for an unlimited number of network UPS systems. Features ● SmartOnline high-performance UPS system is ideal for critical voice, data, medical and industrial network applications ● True on-line, double-conversion UPS provides perfectly regulated sine wave output within 2% of 120V under all usage conditions ● Maintains continuous operation through blackouts, voltage fluctuations and surges with zero transfer time ● Highly efficient operation in optional economy mode setting, saving BTU heat output and energy costs ● Removes harmonic distortion, fast electrical impulses, frequency variations and other hard to solve power problems not addressed by other UPS types ● Corrects line voltage conditions as low as 65V and as high as 150V back to 120V (+/-2%) values ● Standard internal battery set offers 14 min. runtime at half load (600W) and 5 min. at full load (1200W) ● Extended runtime available with optional BP48V24-2U (limit 1), BP48V60RT-3U (multi-pack compatible) and BP48V27-2US (multi-pack compatible) external battery packs ● Some external battery configurations require the use of Tripp Lite's External Battery Configuration Software (see manual) ● Intelligent battery management system extends battery life ● Compact rackmount form factor installs using only 2 rack spaces (2U) with a maximum installed depth 1/7 ● SU1500RTXL2Ua UPS System ● 1 x 6-ft. USB Cable ● 1 x 6-ft. DB9 Cable ● 4-Post Rackmounting Hardware ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States of only 19 in. ● Ships with all mounting accessories for 4-post rackmount installation ● Optional 2POSTRMKITWM enables 2-post rackmount or wallmount installation ● Optional 2-9USTAND accessory enables small-footprint upright tower placement ● Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions ● Network interfaces support simultaneous communications via built-in USB, DB9 serial / contact-closure and slot for network management card options ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD, MODBUSCARD and RELAYIOCARD ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● Included PowerAlert UPS monitoring software supports safe unattended shutdown, monitoring and control via local connected servers, plus any number of additional servers over IP ● UPS interface supports on-battery, low-battery, power-restored, AC-voltage, DC-voltage, output current monitoring, battery charge current, battery capacity, AC line frequency, timed inverter shutoff, activate self-test, load bank output power control and remote reboot, UPS nominal voltage adjustment and UPS line to battery power voltage setpoints ● Built-in Emergency Power Off (EPO) interface with cable ● NEMA 5-15P input plug; NEMA 5-15R output receptacles ● Integrated 2-bank switched PDU enables remote outlet management for load shedding or remote reboot of individual load banks (bank one has 2 outlets, bank two has 4 outlets) ● Front panel LEDs offer current monitoring and battery charge level information ● UPS ships fully assembled in full compliance with DOT regulations; no time-consuming connection of internal batteries by user required ● Single-line tel/DSL or network Ethernet surge suppression ● $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) Specifications OVERVIEW UPC Code 037332125972 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 20A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 15A 120V Input Frequency 50/60Hz +/-5% 2/7 1000 Eaton Boulevard Cleveland, OH 44122 United States OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 1200 Output Capacity (kW) 1.2 Output Capacity Details OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes; 150% load for 30 seconds and >150% load for 0.5 seconds before switching to BYPASS (when bypass input voltage and frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE bypass limits) Power Factor 0.8 Crest Factor 3:1 Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Output frequency matches input nominal on startup, defaults to 60 Hz on cold-start Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 2% Load Management Receptacles Two switchable 5-15R load banks (bank 1 - two outlets, bank 2 - four outlets) Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 5 min. (1200W) Runtime Half Load (min.) 14 min. (600W) Expandable Runtime Yes External Battery Pack Compatibility  BP48V24-2U  (limit 1);  BP48V60RT-3U  (multi-pack compatible);  BP48V272US  (multi-pack compatible) DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 80% (typical, full load discharge) 3/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC94-2U  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction 2% output voltage regulation during overvoltages to 150 Undervoltage Correction 2% output voltage regulation during undervoltages to 80 Severe Undervoltage Correction 2% output voltage regulation during undervoltages to 65 (under 70% load only) USER INTERFACE, ALERTS & CONTROLS Switches 2 switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions LED Indicators 14 LEDs indicate line power, online mode, economy/bypass mode, on-battery, overload, battery low, replace battery and fault status information; 4-LED meter displays load and battery charge levels; LED panel rotates for viewing in rack/tower formats SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 600 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to 914mm) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 55.88 4/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Minimum Required Rack Depth (inches) 22 Minimum Required Rack Depth with External Battery Pack (cm) 66 Minimum Required Rack Depth with External Battery Pack (in.) 26 Minimum Required Rack Depth without External Battery Pack (cm) 56 Minimum Required Rack Depth without External Battery Pack (in.) 22 Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  2POSTRMKITWM  enables wall-mount and 2-post rackmount installation;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm);  UPSHDEARKIT  enables installation in 2 or 4-post racks using front vertical rails only, without rear support Primary UPS Depth (mm) 483 Primary UPS Height (mm) 89 Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 9.20 x 23.40 x 19.50 Shipping Dimensions (hwd / cm) 23.37 x 59.44 x 49.53 Shipping Weight (lbs.) 61.60 Shipping Weight (kg) 27.94 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 8.89 x 44.45 x 48.26 UPS Power Module Dimensions (hwd, in.) 3.5 x 17.5 x 19 UPS Power Module Weight (kg) 20.00 UPS Power Module Weight (lbs.) 44.1 Unit Weight (lbs.) 44.0000 Unit Weight (kg) 19.96 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 612 AC Economy Mode BTU / Hr. (Full Load) 216 Battery Mode BTU / Hr. (Full Load) 667 5/7 1000 Eaton Boulevard Cleveland, OH 44122 United States AC Economy Mode Efficiency Rating (100% Load) 95% COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX ;  MODBUSCARD ;  RELAYIOCARD  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure communications; Economy-mode setting option is available using PowerAlert software and DB9 Serial cable connection OR via select Network Management Card options PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Low Voltage Transfer to Battery Power (Setpoint) 80V (100% load), 65V (
SU1500RTXL2UA 价格&库存
很抱歉,暂时无法提供与“SU1500RTXL2UA”相匹配的价格&库存,您可以联系我们找货
