OMNI900LCD
OMNI900LCD
    TRIPPLITE
    UPS 900VA 8OUT LCD DISP USB
OMNI900LCD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OmniSmart LCD 120V 900VA 475W LineInteractive UPS, Tower, LCD display, USB port MODEL NUMBER: OMNI900LCD Highlights ● 900VA tower 120V line interactive UPS with LCD display ● Corrects brownouts as low as 89V without using battery power ● LCD screen reports input voltage, battery charge and UPS status ● USB port, Surge-only outlets, 97% efficiency ● NEMA 5-15P input plug and 8 NEMA 5-15R outlets Package Includes Description Tripp Lite's OMNI900LCD Line-Interactive Digital UPS System offers voltage regulation, surge suppression and long lasting battery support for personal computers, home entertainment systems and media centers. Internal UPS circuits support entry level PCs for up to 50 minutes or individual VCR/DVR components for as long as 2.5 hours during power failures. Prevents data loss, viewing interruptions, lost recordings and loss of component programming. Automatic Voltage Regulation (AVR) circuits regulate brownouts as low as 89 volts back to usable levels without using battery power. 97% line-mode efficiency saves energy and reduces BTU heat output. Offers complete power protection in an attractive black tower configuration. Includes 4 battery-supported and surge-protected outlets, plus 4 additional surge suppression-only outlets for items not requiring battery support. USB port enables optional unattended system shutdown without data loss in the case of extended power failure. PowerAlert software available via free download. HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. Built-in audible alarm and large LCD front panel voltage display indicates line power status, battery power status, battery low/replace status and voltage boost operation. The LCD display includes a dimmer switch and can be rotated for easy viewing in any application. 900VA/475 watt power handling ability supports entry-level PCs, home entertainment systems, network workstations, audio/video components. Offers 3 minutes battery runtime with a full load of 900VA/475 watts and 10 minutes with a half load of 450VA/237 watts. Supports battery replacement via built-in access panel. $200,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only). Features ● LCD Display with dimmer switch indicates input voltage, battery capacity and a variety of operating conditions. Display is rotatable for easy viewing whether UPS is in vertical or horizontal position ● OMNI900LCD Digital Uninterruptible Power Supply offers voltage regulation, surge suppression and long lasting battery support during blackouts ● Supports entry level PCs up to 50 minutes or single VCR/DVR components for up to 2.5 hours during blackouts ● 97% line-mode efficiency saves energy and reduces BTU heat output ● Regulates brownouts as low as 89 volts back to usable levels without using battery power ● 4 UPS battery-supported and surge-protected outlets, plus 4 additional surge suppression-only outlets ● USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert (user supplies cable) ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X 1/5 ● OMNI900LCD UPS System ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● 900VA/475 watt power handling ability supports a variety of sensitive computer, home theater and other equipment ● 3 minutes full load runtime (900VA/475 watts), 10 minutes half load runtime (450VA/237 watts) ● Cabinet adapts to tower format or rackmount shelf format. Rackmount (2U) format requires an optional shelf, available separately ● Supports battery replacement via built-in access panel ● Optional PDUB15 bypass PDU enables hot-swappable UPS replacement with no disruption to connected equipment ● $200,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) Specifications OVERVIEW UPC Code 037332125156 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P; Right-Angled UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 900 Output Capacity (kVA) 0.9 Output Capacity (Watts) 475 Output Capacity (kW) 0.475 Nominal Voltage Details 115v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Battery Mode) +/- 5% UPS Output Receptacles (Surge Suppression Only) 4 UPS outlets, 4 surge-only outlets Hot-Swap PDU options PDUB15 (2U / 8 5-15R outlets) Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (8) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 3 min. (475W) Runtime Half Load (min.) 10 min. (238W) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) Less than 16 hours from 10% to 90% Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC51  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 89 Undervoltage Correction Input voltages between 89 and 104 are boosted by 14% USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Backlighted LCD screen indicates input voltage, 5-bar battery charge level, overload, AVR, on battery and replace battery status; LCD screen rotates for rack/tower viewing Switches 2 Switches control off/on power status and alarm-cancel/self-test operation; dimmer switch controls LCD brightness Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery status; alarm can be disabled using PowerAlert software LED Indicators Front panel LCD display SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 870 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Installation Form Factors Supported with Included Accessories Tower; Ultra-compact desktop 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary UPS Depth (mm) 183 Primary UPS Height (mm) 300 Primary UPS Width (mm) 94 Shipping Dimensions (hwd / in.) 15.50 x 4.70 x 10.50 Shipping Dimensions (hwd / cm) 39.37 x 11.94 x 26.67 Shipping Weight (lbs.) 16.50 Shipping Weight (kg) 7.48 UPS Housing Material ABS UPS Power Module Dimensions (hwd, cm) 29.97 x 9.40 x 18.29 UPS Power Module Dimensions (hwd, in.) 11.8 x 3.7 x 7.2 UPS Power Module Weight (kg) 6.85 UPS Power Module Weight (lbs.) 15.1 Unit Weight (lbs.) 15.0100 Unit Weight (kg) 6.81 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 61 Battery Mode BTU / Hr. (Full Load) 485 AC Mode Efficiency Rating (100% Load) 97% COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in USB port, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable User supplies USB cable WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network UPS Tools (NUT) Compatibility NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite Network Management Card Description Network management not supported Communications Interface USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 4 milliseconds (AC to Battery); 3 milliseconds (Battery to AC) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Low Voltage Transfer to Battery Power (Setpoint) 89 High Voltage Transfer to Battery Power (Setpoint) 139 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 3-year limited warranty Product Warranty Period (Latin America) 3-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 3-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $200,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
OMNI900LCD 价格&库存
很抱歉,暂时无法提供与“OMNI900LCD”相匹配的价格&库存,您可以联系我们找货
