INTERNET550U
INTERNET550U
    TRIPPLITE
    UPS 550VA 300W 120V 8OUT W/RJ11
INTERNET550U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 550VA 300W Standby UPS - 10 NEMA 5-15R Outlets, 120V, 50/60 Hz, USB, 5-15P Plug, Desktop/Wall Mount MODEL NUMBER: INTERNET550U Highlights ● Protects equipment against blackouts, brownouts, overvoltages, surges and line noise ● Keeps AC power running during blackouts to allow time for file saves and safe shutdown ● 10 NEMA 5-15R outlets power and protect PC, home theater or digital signage equipment ● Home-friendly alarm remains silent in backup mode, sounding only when imperative ● High >98% efficiency with low BTU ratings saves electricity and lowers your energy costs Applications ● Protect your PC and other sensitive electronics against power surges, line noise, brownouts, overvoltages and blackouts Compact desktop UPS with silent alarm provides battery backup support for your home/office network system or digital signage components. ● Operate essential equipment during short-term power outages using battery backup power Features ● Manual or automatic shutdown of desktop PCs without data loss during long term power outages ● Extended runtime for DVRs, wireless routers and other lowpower home networking equipment 550VA/300W/120V Battery Backup for PCs, Home Theater and Digital SignageThe standby INTERNET550U UPS system provides reliable battery backup and AC power protection against blackouts, brownouts, overvoltages, surges and line noise that can damage valuable electronics or destroy data. The 10-outlet 120V battery backup is ideal protection for your home office, media center or commerce components, including computers, routers, printers, NAS drives, HDTVs, Blu-ray players, game consoles, media players, DVRs and audio receivers. Allows Time to Back Up Critical Files During a Blackout Backup support allows you to work through short power failures and gives you enough time to safely save files and shut down your system in case of a prolonged blackout. Backup time varies according to load, but the INTERNET550U should keep an energy-efficient desktop computer with small LCD monitor powered as long as 16 minutes. During normal operation, incoming utility power keeps the replaceable internal battery fully charged, so backup power will always be available. 10 NEMA 5-15R Outlets Protect Your Connected ComponentsFive 5-15R outlets provide battery backup and surge protection for your computer, monitor and other crucial components. The other five 515R outlets provide surge suppression only for printers, speakers and other desktop equipment regarded as non-essential during a blackout. A high >98% line mode efficiency rating reduces BTU emissions, energy consumption and, ultimately, your energy costs. 316 Joules Fight Back Against Unexpected Power SurgesA 316-joule surge suppression rating protects connected components from the harmful effects of power surges. Dual network data line surge suppression jacks protect a wired peripheral from dangerous surges on a single 10/100Base-T or dial-up network connection. HID-Compliant USB Port Allows for Automatic Saves and ShutdownsThis USB port connects the INTERNET550U to a computer running Tripp Lite’s free downloadable PowerAlert® software to enable safe unattended file saves and system shutdown in case of a prolonged power failure. USB cable is included. 1/5 Package Includes ● INTERNET550U 550VA 300W 120V Standby UPS with 10 Outlets ● USB cable ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Combats Electromagnetic Interference That Can Harm EquipmentVarious electromagnetic and radio sources found in virtually every home and business can cause disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this line noise is a common cause of performance problems and can lead to incremental hardware damage, data corruption and audio/video transmission problems. The INTERNET550U incorporates technology that filters out disruptive line noise so that it won’t affect your equipment. Home-Friendly Alarm and Diagnostic LEDs Keep You Informed 24/7The UPS remains silent in both line and battery backup modes. The alarm sounds only to warn you of a low battery or fault condition. A front-panel green LED indicates operating mode and fault status. Compact Housing Compatible with Easy Desktop or Wall-Mount InstallationThe space-saving ABS housing fits on a desktop, shelf or anywhere else convenient to your workstation or home theater. Keyhole mounting tabs on the rear allow easy wall-mount installation. The five-foot power cord with NEMA 5-15P plug connects to any compatible AC outlet. Specifications OVERVIEW UPC Code 037332211026 UPS Type Standby INPUT Input Phase Single-Phase Rated input current (Maximum Load) 6A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 7A UPS Input Cord Length (ft.) 5 UPS Input Cord Length (m) 1.5 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 550 Output Capacity (kVA) 0.55 Output Capacity (Watts) 300 Output Capacity (kW) 0.3 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 50 / 60 Hz Output Voltage Regulation (Line Mode) 120V (±20%) Output Voltage Regulation (Battery Mode) 120V (±10%) 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Output Receptacles (Surge Suppression Only) 5 UPS outlets, 5 surge-only outlets Output AC Waveform (AC Mode) Pure sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (10) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 1.2 min. (300W) Runtime Half Load (min.) 5 min. (150W) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) 6.5 hours (10% to 90%) Battery Access Battery access door Internal UPS Replacement Battery Cartridge IMPORTANT BATTERY REPLACEMENT INFORMATION > If your INTERNET550U has no battery access door, please contact a local electronics repair technician to source and install a matching replacement battery; If your INTERNET550U UPS does have a battery replacement door and the original battery inside has a rating of 12V 3.6AH, please order Tripp Lite replacement battery Model Number  RBC36H  Battery Replacement Description Replaceable internal batteries (see manual) USER INTERFACE, ALERTS & CONTROLS Switches Switch controls power off/on status Audible Alarm UPS remains silent in battery backup mode; Alarm sounds only to report low-battery, fault, overload and replacebattery conditions LED Indicators 1 Status LED reports operating mode and fault status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 316 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL or Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Desktop 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Installation Form Factors Supported with Included Accessories Tower; Ultra-compact desktop; Wallmount Primary UPS Depth (mm) 185 Primary UPS Height (mm) 105 Primary UPS Width (mm) 110 Shipping Dimensions (hwd / in.) 7.36 x 5.67 x 10.86 Shipping Dimensions (hwd / cm) 18.69 x 14.40 x 27.58 Shipping Weight (lbs.) 4.92 Shipping Weight (kg) 2.23 UPS Housing Material ABS UPS Power Module Dimensions (hwd, cm) 10.49 x 11.00 x 18.49 UPS Power Module Dimensions (hwd, in.) 4.13 x 4.33 x 7.28 UPS Power Module Weight (kg) 1.80 UPS Power Module Weight (lbs.) 3.96 Unit Dimensions (hwd / in.) 4.130 x 4.330 x 7.280 Unit Weight (lbs.) 4.920 Unit Weight (kg) 2.23 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 113°F (-15° to 45°C ) Relative Humidity 0 to 90%, non-condensing AC Mode BTU / Hr. (Full Load) 13.1 AC Mode Efficiency Rating (100% Load) >98% Operating Elevation (ft.) Up to 10,000 ft. Operating Elevation (m) Up to 3000m COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in USB port, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB interface cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management not supported Communications Interface USB (HID enabled) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States LINE / BATTERY TRANSFER Transfer Time 6 milliseconds typical (10 milliseconds max) Low Voltage Transfer to Battery Power (Setpoint) 95 High Voltage Transfer to Battery Power (Setpoint) 145 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 107.3 (Canada); NOM (Mexico); RETIE (Colombia); UL 1778 Product Compliance FCC Part 15 Class B (USA); FCC Part 68; RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty; 3-year limited warranty Product Warranty Period (U.S. & Canada) 3-year limited warranty Product Warranty Period (Latin America) 3-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 3-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $100,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
INTERNET550U 价格&库存
很抱歉,暂时无法提供与“INTERNET550U”相匹配的价格&库存,您可以联系我们找货
