SMART1500LCD
SMART1500LCD
    TRIPPLITE
    UPS 1500VA 8OUT LCD DISP USB
SMART1500LCD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro LCD 120V 1500VA 900W LineInteractive UPS, AVR, 2U Rack/Tower, LCD, USB, DB9 Serial, 8 Outlets Highlights ● Supports a half-load (450W) up to 11.8 min. during power outage ● Supports a full load (900W) up to 4.4 min. during power outage ● High 98% efficiency in line power mode ● Features 8 protected NEMA 515R outlets ● Offers automatic voltage regulation (AVR) ● LCD screen reports real-time UPS and power status MODEL NUMBER: SMART1500LCD Package Includes Provides reliable 1500VA/900W power protection for your desktop computer, network workstation, audio/video components or media center. Protects against surges, line noise, blackouts and brownouts. Description The SMART1500LCD SmartPro LCD 120V, 1500VA/900W Line-Interactive Uninterruptible Power Supply provides battery backup and AC power protection against blackouts, brownouts, power surges and line noise that can damage electronics or destroy data. Ideal for backing up your desktop computer or audio/visual components, this line-interactive UPS switches to battery backup mode in milliseconds to keep your connected equipment running long enough to save files and shut down safely with no data loss. Eight NEMA 5-15R outlets protect against surges, as well as provide up to 11.8 minutes of UPS battery support at half load (450W) and 4.4 minutes of support at full load (900W). Automatic voltage regulation (AVR) corrects severe undervoltages as low as 75V and overvoltages as high as 147V without using any battery power. EMI/RFI noise filtering improves your equipment's performance and prevents damage. A 870-joule surge suppression rating protects your equipment from harmful power surges. NEMA 5-15P plug with 6-ft. (1.83 m) cord connects to any NEMA 5-15R socket. Large rotatable LCD screen with dimmer shows real-time input voltage, overload, AVR and battery statuses at a glance. Alarm sounds to indicate power loss or low battery. With Tripp Lite's free PowerAlert software (available via free download), the SMART1500LCD enables safe unattended system shutdown and file saves in case of a prolonged power failure. Features Reliable Battery Backup ● Provides 1500VA/900W high-performance power protection for desktop computers, audio/video components, media centers and other electronics ● Supports 50% load (450W) up to 11.8 minutes and full load (900W) up to 4.4 minutes ● Audible alarm indicates loss of utility power or low battery ● Battery access door enables hot-swappable, user-replaceable internal batteries Optimized Outlets ● 8 NEMA 5-15R outlets provide battery backup and protect against surges or spikes that can harm equipment or data 1/6 ● SMART1500LCD UPS ● USB cable ● DB9 serial cable ● Telephone cable ● Mounting hardware ● Owner’s Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Automatic Voltage Regulation (AVR) ● Corrects undervoltages as low as 75V and overvoltages as high as 147V without drawing battery backup power Rotatable LCD Status Screen ● Large LCD screen offers real-time status information regarding operating mode, voltage, load level, battery charge percentage and estimated runtime in minutes ● UPS configuration options via front panel LCD include battery self-test, external battery pack configuration, alarm on/off status and LCD brightness ● Rotates for easy viewing in both horizontal and vertical installations AC Line, Tel/DSL and Ethernet Surge Suppression ● Surge suppression rating of 870 joules protects connected equipment and data from harmful power surges ● Built-in RJ-45 jacks protect single-line tel/DSL or network Ethernet connection EMI/RFI Line Noise Filtering ● Removes electromagnetic and radio frequency interference that can disrupt or damage your equipment's performance USB and DB9 Communication Ports and Free PowerAlert Software ● HID-compliant USB port integrates with built-in power management and auto-shutdown of Windows and Mac OS X ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● DB9 port also supports contact closure messaging for AC Present and AC Fail status Flexible Installation Options ● NEMA 5-15P plug with 6-ft. (1.83 m) cord connects to any NEMA 5-15R socket ● Adapts to vertical or horizontal installation with included mounting hardware ● Includes 2U brackets for rack-mount installation in 2 or 4 post racks Specifications OVERVIEW UPC Code 037332126146 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 8.6A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P; Right-Angled Input Circuit Breakers 10A 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 900 Output Capacity (kW) 0.9 Power Factor 0.6 Nominal Voltage Details 115v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) 115V (+/- 5%) Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (8) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.4 min. (900W) Runtime Half Load (min.) 11.8 min. (450W) Expandable Runtime No DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% Battery Access Battery Access Door Internal UPS Replacement Battery Cartridge  RBC1500  Battery Replacement Description IMPORTANT BATTERY REPLACEMENT INFORMATION > If your SMART1500LCD UPS has no battery replacement door, please contact a local electronics repair technician to source and install a matching replacement battery; If your SMART1500LCD UPS is equipped with a battery access door, please order Tripp Lite RBC1500 (quantity 1) replacement battery cartridge VOLTAGE REGULATION 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 93 and 107 are boosted by 14% Severe Undervoltage Correction Input voltages between 75 and 92 are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Backlighted LCD screen offers detailed UPS status information, configuration options and Error message reporting; STATUS INFORMATION includes Input Voltage, Output Voltage, Estimated Runtime (minutes), Output Load Percentage, Output Load Wattage, Battery Charge Percentage, Graphical 5-Bar Battery Charge Level and UPS Operating Mode Display / CONFIGURATION OPTIONS include Power Sensitivity, LCD Status Information Scrolling, Alarm Disable, LCD Brightness and Self Test / REPORTED ERROR MESSAGES include Replace-Battery and Overload conditions; LCD Screen rotates for vertical or horizontal UPS placement Switches ON/OFF/MODE button provides UPS on/off power control (long-press) and advances the LCD screen display (short tap); MUTE/ENTER button provides temporary alarm cancel, plus selection and confirmation of on-screen configuration options Alarm Cancel Operation Press the MUTE/ENTER button during a power failure to silence the alarm; Once silenced, alarm will re-sound to indicate low-battery status Audible Alarm Audible alarm indicates power-failure and low-battery status; Alarm can be disabled entirely via front panel LCD interface (see manual) LED Indicators Front panel LCD display SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 870 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet UPS Dataline Suppression Details 168 joules; Compatible with POE applications EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Included mounting brackets enable installation in 2 and 4 post racks, plus upright tower configurations; Set of 4 rubber-feet enable no-slip horizontal desktop placement Installation Form Factors Supported with Included Accessories 2 post 19 inch rackmount; 2 post front mount; 4 post 19 inch rackmount; Tower Minimum Required Rack Depth (cm) 35.56 Minimum Required Rack Depth (inches) 14 Primary UPS Depth (mm) 267 Primary UPS Height (mm) 89 Primary UPS Width (mm) 438 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 7.10 x 14.90 x 21.30 Shipping Dimensions (hwd / cm) 18.03 x 37.85 x 54.10 Shipping Weight (lbs.) 31.90 Shipping Weight (kg) 14.47 UPS Housing Material ABS UPS Power Module Dimensions (hwd, cm) 8.89 x 43.82 x 26.67 UPS Power Module Dimensions (hwd, in.) 3.5 x 17.25 x 10.5 UPS Power Module Weight (kg) 13.61 UPS Power Module Weight (lbs.) 30 Unit Weight (lbs.) 30.0000 Unit Weight (kg) 13.61 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity Up to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 78 AC Mode Efficiency Rating (100% Load) 98% Operating Elevation (ft.) 6562 Operating Elevation (m) 2000 COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions; DB9 provides contact-closure notification of AC Present (pins 1,9 connected) and AC Fail (pins 1,8 connected) PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 Serial cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management not supported Communications Interface Contact closure; DB9 Serial; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 4 milliseconds (AC to battery mode); 1 millisecond (Battery to AC mode) Low Voltage Transfer to Battery Power (Setpoint) 75 High Voltage Transfer to Battery Power (Setpoint) 147 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 3-year limited warranty Product Warranty Period (Latin America) 3-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 3-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMART1500LCD 价格&库存
很抱歉,暂时无法提供与“SMART1500LCD”相匹配的价格&库存,您可以联系我们找货
SMART1500LCD
    • 1+4446.596001+574.58890
    • 10+4409.0635010+569.73900
    库存:2
