AVR550U
AVR550U
    TRIPPLITE
    UPS 550VA 300W 8OUT USB RJ/11
AVR550U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 550VA 300W Line-Interactive UPS - 8 NEMA 515R Outlets, AVR, 120V, 50/60 Hz, USB, Desktop/Wall Mount MODEL NUMBER: AVR550U Highlights ● Protects equipment against blackouts, brownouts, overvoltages, surges and line noise ● Keeps AC power running during blackouts to allow time for file saves and safe shutdown ● 8 NEMA 5-15R outlets power and protect PC, home theater or digital signage equipment ● Home-friendly alarm remains silent in backup mode, sounding only when imperative ● High >95% efficiency with low BTU ratings saves electricity and lowers your energy costs Applications ● Protect your PC and other sensitive electronics against power surges, line noise, brownouts, overvoltages and blackouts Desktop UPS provides battery backup support with automatic voltage regulation (AVR) for your home/office network system or home theater. ● Operate essential equipment during short-term power outages using battery backup power Features ● Shut down desktop PCs and other equipment without data loss during long-term power outages ● Extend runtime for DVRs, wireless routers and other lowpower home network equipment 550VA/300W/120V Battery Backup for PCs, Home Theater or Digital Signage The line-interactive AVR550U UPS system with AVR protection provides reliable battery backup and AC power protection against blackouts, brownouts, overvoltages, surges and line noise that can damage valuable electronics or destroy data. The eight-outlet 120V battery backup is ideal protection for your home office, media center or commerce components, including computers, routers, printers, HDTVs, Bluray players, game consoles, ATMs, security systems and digital signage equipment. Allows Time to Back Up Critical Files During a Blackout Backup support allows you to work through short power failures and gives you enough time to safely save files and shut down your system in case of a prolonged blackout. Backup time varies according to load, but the line-interactive UPS system should keep an energy-efficient desktop computer with small LCD monitor powered as long as 32 minutes. During normal operation, incoming utility power keeps the replaceable internal battery fully charged, so backup power will always be available. 8 NEMA 5-15R Outlets Protect Your Connected Components Four 5-15R outlets provide battery backup, surge protection and voltage regulation for your computer, monitor and other crucial components. The other four 5-15R outlets provide surge suppression only for printers, speakers and other desktop equipment regarded as non-essential during a blackout. A high >95% line mode efficiency rating reduces BTU emissions, energy consumption and, ultimately, your energy costs. Automatic Voltage Regulation (AVR) Corrects Low- and High-Voltage Conditions AVR protects your equipment from incremental hardware damage, data loss and performance problems caused by brownouts and overvoltages. The AVR550U can correct brownouts as low as 89V and overvoltages as high as 145V back to nominal 120V power continuously, all while keeping the battery fully charged and ready to take over in case of power failure. 316 Joules Fight Back Against Unexpected Power Surges A 316-joule surge suppression rating protects connected components from the harmful effects of power surges. 1/6 Package Includes ● AVR550U 550VA 300W 120V Line-Interactive UPS with 8 Outlets ● USB cable ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Combats Electromagnetic Interference That Can Harm Equipment Various electromagnetic and radio sources found in virtually every home and business can cause disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this line noise is a common cause of performance problems and can lead to incremental hardware damage, data corruption and audio/video transmission problems. The AVR550U incorporates technology that filters out disruptive line noise so that it won’t affect your equipment. Home-Friendly Alarm and Diagnostic LEDs Keep You Informed 24/7 The UPS remains silent in both line and battery backup modes. The alarm sounds only to report low battery, battery replace, overload and fault condition. Dual front-panel LEDs report line and battery mode operation. HID-Compliant USB Port Allows for Automatic Saves and Shutdowns This USB port connects the AVR550U to a computer running Tripp Lite’s free downloadable PowerAlert® software to enable safe unattended file saves and system shutdown in case of a prolonged power failure. USB cable is included. Compact Housing Compatible with Easy Desktop or Wall-Mount Installation The space-saving ABS housing fits on a desktop, shelf or anywhere else convenient to your workstation or home theater. Keyhole mounting tabs on the rear allow easy wall-mount installation. The five-foot power cord with NEMA 5-15P plug connects to any compatible AC outlet. Specifications OVERVIEW UPC Code 037332211453 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 6A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 7A UPS Input Cord Length (ft.) 5 UPS Input Cord Length (m) 1.5 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 550 Output Capacity (kVA) 0.55 Output Capacity (Watts) 300 Output Capacity (kW) 0.3 Nominal Voltage Details 120v nominal output in battery mode 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Frequency Compatibility 50 / 60 Hz Output Voltage Regulation (Line Mode) 120V (+6%/-12%) Output Voltage Regulation (Battery Mode) 120V (±10%) UPS Output Receptacles (Surge Suppression Only) 4 UPS outlets, 4 surge-only outlets Output AC Waveform (AC Mode) Pure sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (8) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 2 min. (300W) Runtime Half Load (min.) 9 min. (150W) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) 8 hours (10% to 90%) Battery Access Battery access door Internal UPS Replacement Battery Cartridge IMPORTANT BATTERY REPLACEMENT INFORMATION > If the original battery inside your AVR550U UPS has a rating of 12V 7AH, please order Tripp Lite  RBC51  (quantity 1) replacement battery; If the original battery inside your AVR550U UPS has a rating of 12V 3.6AH, please order Tripp Lite  RBC36H  (quantity 1) replacement battery; If the original battery inside your AVR550U UPS has a rating of 12V 5AH, please contact Tripp Lite for assistance Battery Replacement Description Replaceable internal batteries (see manual) VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 89 to 145 Overvoltage Correction Input voltages between 128 and 145 are reduced by 15% Undervoltage Correction Input voltages between 89 and 108 are boosted by 18% USER INTERFACE, ALERTS & CONTROLS Switches Power off/on switch Audible Alarm UPS remains silent in battery backup mode; Alarm sounds only to report low-battery, fault, overload and replacebattery conditions 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States LED Indicators 2 Status LEDs; GREEN indicates power status and operating mode / RED indicates battery-low, overload, replacebattery and fault conditions (see manual) SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 316 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL or Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Desktop Installation Form Factors Supported with Included Accessories Tower; Ultra-compact desktop; Wallmount Primary UPS Depth (mm) 305 Primary UPS Height (mm) 110 Primary UPS Width (mm) 163 Shipping Dimensions (hwd / in.) 6.00 x 9.30 x 14.70 Shipping Dimensions (hwd / cm) 15.24 x 23.62 x 37.34 Shipping Weight (lbs.) 13.11 Shipping Weight (kg) 5.95 UPS Housing Material ABS UPS Power Module Dimensions (hwd, cm) 11.00 x 16.26 x 30.48 UPS Power Module Dimensions (hwd, in.) 4.33 x 6.4 x 12 UPS Power Module Weight (kg) 6.21 UPS Power Module Weight (lbs.) 13.7 Unit Weight (lbs.) 13.110 Unit Weight (kg) 5.95 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 113°F (-15° to 45°C ) Relative Humidity 0 to 90%, non-condensing AC Mode BTU / Hr. (Full Load) 61 AC Mode Efficiency Rating (100% Load) >95% Operating Elevation (ft.) Up to 10,000 ft. 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Elevation (m) Up to 3000m COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB interface cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network UPS Tools (NUT) Compatibility NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite Network Management Card Description Network management not supported Communications Interface USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 6 milliseconds typical (10 milliseconds max) Low Voltage Transfer to Battery Power (Setpoint) 89 High Voltage Transfer to Battery Power (Setpoint) 145 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic Voltage Regulation (AVR); Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS Grounding Details Includes side-panel grounding lug STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 3-year limited warranty Product Warranty Period (Latin America) 3-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 3-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $100,000 Ultimate Lifetime Insurance  5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
AVR550U 价格&库存
很抱歉,暂时无法提供与“AVR550U”相匹配的价格&库存,您可以联系我们找货
AVR550U
  • 1+441.37732
库存:3
