1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 230V 500VA 300W Line-Interactive
UPS, 1U Rack/Tower, Network Card Options,
USB, DB9 Serial
MODEL NUMBER: SMX500RT1U
Highlights
500VA line interactive 1U
rack/tower UPS
230V 50 / 60Hz nominal output
Optional WEBCARDLX with
latest version of PADM20
supports Auto Probe feature
Front panel status LEDs; 1
switched output load bank
C14 input; 6 C13 outlets; 2 C13
to C14 cables
Applications
Provides complete battery backup and power protection for connected equipment in a network closet or
small business network.
Deliver battery-derived AC
output to connected equipment
in a network closet or small
business network
Protect point-of-sale and VoIP
networks against power surges,
line noise and spikes
Operate essential equipment
during short-term power outages
using battery backup power
Shut down desktop PCs and
other equipment without data
loss during long-term power
outages
Features
Tripp Lite SMX500RT1U .5 kVA / 500VA / 300 watt line interactive UPS
1U rack / tower compatible form factor
IEC C14 input; 6 IEC C13 output receptacles
Installed depth of only 11.8 in / 29.8 cm
Large internal batteries offer runtimes of 14.6 minutes at half load (250VA/150 watts) and 3.2 minutes at
full load (500VA/300 watts)
Package Includes
SMX500RT1U 500VA 300W
230V Line-Interactive UPS with
6 Outlets
USB cable
DB9 cable
EPO cable
Intelligent battery management system extends battery life
Maintains regulated 230V nominal output during brownouts as low as 187V
(2) C13-to-C14 AC power cords,
1.8 m
Includes 6 UPS-supported outlets, with one single-outlet load bank for remote load shedding or
rebooting of an individual device
Rack-mounting hardware
Owner’s manual
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX and
SNMPWEBCARD
Optional WEBCARDLX (sold separately) with the latest version of PowerAlert Device Manager firmware
(PADM20) provides enhanced remote management capabilities
PADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance
functions in large installations, including firmware update checks and backup and restoration of device
configurations
IP-based Auto Probe detects lost connectivity and restores service autonomously
Supports Tripp Lite's WatchDog software application to restore operation to locked equipment through
soft reboot of application, OS or hard power off/on reboot of connected equipment - ideal for unattended
kiosk applications (requires optional WATCHDOGSW)
Emergency Power Off (EPO) interface with cable
Multi-function audible alarms and set of 5 front panel LEDs
1/5
Cleveland, OH 44122
United States
C14 inlet accepts user-supplied AC power cord with country specific plug
Network-grade AC surge suppression
Field-replaceable, hot-swappable internal UPS batteries
Optional PDUBHV10 bypass PDU enables hot-swappable UPS replacement with no disruption to
connected equipment
Specifications
OVERVIEW
UPC Code
037332119254
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
7A (Maximum input with 300W UPS and 1310W surge-only loads)
Nominal Input Voltage(s) Supported
230V AC
Nominal Input Voltage Description
Accepts inputs between 187 and 265V for AC mode operation
UPS Input Connection Type
C14 inlet
UPS Input Connection Description
C14 inlet accepts user-supplied AC power cord with country-specific plug; Includes 2 1.8m C13 to C14 power cables
Input Circuit Breakers
7A thermal breaker
OUTPUT
Output Capacity (VA)
500
Output Capacity (kVA)
0.5
Output Capacity (Watts)
300
Output Capacity (kW)
0.3
Power Factor
0.6
Nominal Voltage Details
230v nominal inverter output voltage
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Automatic frequency selection; 50Hz (46-54Hz) / 60Hz (56-64Hz)
Output Voltage Regulation (Line
Mode)
-8%, +15%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Included Output Power Cables
Two 1.8m IEC320-C13 to C14 load jumper cables
UPS Output Receptacles (Surge
Suppression Only)
5 UPS outlets, 1 surge-only outlet
Load Management Receptacles
One switchable single-outlet C13 load bank
Hot-Swap PDU options
PDUBHV10 (2U / 8 C13 outlets)
2/5
Cleveland, OH 44122
United States
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
220V; 230V; 240V
Output Receptacles
(6) C13
Output Amp Capacity
2.17A maximum (UPS outlets) / 7A maximum (UPS + Surge-only Outlets)
Individually Controllable Load Banks
Yes
BATTERY
Runtime Full Load (min.)
3 min. (300W)
Runtime Half Load (min.)
14 min. (150W)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
Less than 12 hours to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
IMPORTANT BATTERY REPLACEMENT INFORMATION > Use Tripp Lite RBC12V-1U replacement battery for
SMX500RT1U models with the Series Number AG-03AD listed on the UPS nameplate (Sold since 2021); For all
prior versions of SMX500RT1U, use Tripp Lite RBC62-1U
replacement battery; Contact Tripp Lite customer service for additonal information
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 187
Undervoltage Correction
Input voltages between 187 and 215 are boosted by 14%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates power-failure, overload and low-battery conditions
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
480
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount; Tower
Rack Height
1U
3/5
Cleveland, OH 44122
United States
Included Mounting Accessory
Description
Included mounting brackets provide front-rail installation in 2 or 4 post racks, plus upright tower configurations
Installation Form Factors Supported
with Included Accessories
2 post 19 inch rackmount; 2 post front mount; 4 post 19 inch rackmount; Tower
Minimum Required Rack Depth (cm)
38.10
(inches)
15
Primary UPS Depth (mm)
286
Primary UPS Height (mm)
44
Primary UPS Width (mm)
440
Shipping Dimensions (hwd / in.)
4.20 x 15.80 x 21.00
Shipping Dimensions (hwd / cm)
10.67 x 40.13 x 53.34
Shipping Weight (lbs.)
17.70
Shipping Weight (kg)
8.03
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
4.39 x 43.99 x 28.60
(hwd, in.)
1.73 x 17.32 x 11.26
UPS Power Module Weight (kg)
8.03
UPS Power Module Weight (lbs.)
17.7
Unit Weight (lbs.)
16.310
Unit Weight (kg)
7.40
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
35
AC Mode Efficiency Rating (100%
Load)
97%
Audible Noise
45 dBA maximum, front side 1m
COMMUNICATIONS
Network Management Cards
WEBCARDLX
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
4/5
Cleveland, OH 44122
United States
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
USB (HID enabled); DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
187
High Voltage Transfer to Battery
Power (Setpoint)
264
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable
batteries; Remote management; Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS; Individually controllable load banks
Grounding Lug
Back panel grounding lug
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); IEC/EN 62040; UL 1778
Product Compliance
RoHS; CE (Europe); EAC (Belarus, Kazakhstan, Russia)
WARRANTY & SUPPORT
Product Warranty Period
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“SMX500RT1U”相匹配的价格&库存,您可以联系我们找货
