SMART1000RM1U
SMART1000RM1U
    TRIPPLITE
    UPS 1KVA 800W 6OUT RACK MOUNT
SMART1000RM1U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 1kVA 800W Line-Interactive Sine Wave UPS, Network Card Option, USB, DB9, 6 Outlets, 1U Rack/Vertical MODEL NUMBER: SMART1000RM1U Highlights ● Corrects under- and overvoltages from 83V to 147V ● 6 NEMA 5-15R outlets—2 switchable via network interface ● Network power management and control capability ● High 99% efficiency rating saves energy ● Requires WEBCARDLX network interface running firmware update 15.5.2 or later to use Auto Probe Package Includes Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts, brownouts, power surges and line noise. Features Protects Mission-Critical Rack-Mounted EquipmentProvides fully regulated sine wave AC output for servers, network storage devices and telecom hardwareAudible alarm signals loss of utility power, overload and low battery6 NEMA 5-15R outlets10 t. (3.1 m) power cord with 120V NEMA 5-15P input450joule surge suppression rating Reliable Battery BackupSupports half load up to 14 min. and full load up to 4 min.Internal batteries designed for hot-swap field replacement Switchable Outlets2 load banks, each with one outlet individually controllable via software interface to reboot equipment or shed nonessential loads Automatic Voltage Regulation (AVR)Maintains 120V nominal output over input range of 83V-147V without using battery power EMI/RFI Line Noise FilteringRemoves electromagnetic and radio frequency interference that can disrupt or damage equipment's performance High Efficiency Operation99% line mode efficiency saves money, energy and protects the environment LED IndicatorsFront-panel LEDs signal power, voltage correction, load level and battery charge state Network Management CardsCompatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX and SNMPWEBCARD Communications PortsUSB and DB9 ports combine with PowerAlert software (available via free download from tripplite.eaton.com/products/power-alert) to monitor operating conditions, monitor AC power, and enable safe unattended system shutdown and file saves in case of a prolonged power failureEPO port supports emergency shutdown in large facilities 1/5 ● SMART1000RM1U SmartPro 120V 1kVA 800W LineInteractive Sine Wave UPS ● USB cable ● DB9 cable ● EPO cable ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Versatile Installation OptionsHardware included for mounting in 1U of EIA-standard 19 in. 2- or 4-post rackOptional 4POSTRAILKIT1U accessory available for extra support in 4-post installationsCompatible with vertical mount cabinets Specifications OVERVIEW UPC Code 037332118820 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 9A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 15A Recommended Electrical Service 15A 120V Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity (VA) 1000 Output Capacity (kVA) 1 Output Capacity (Watts) 800 Output Capacity (kW) 0.8 Power Factor 0.8 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -21%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Two switchable single-outlet 5-15R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15R 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4 min. (800W) Runtime Half Load (min.) 14 min. (400W) Expandable Runtime No DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) 4.5 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC69-1U  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 83 and 107 are boosted by 14% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure, overload and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 450 EMI / RFI AC Noise Suppression Yes AC Suppression Response Time Instantaneous PHYSICAL Primary Form Factor Rackmount; Vertical Rack Height 1U Cooling Method Fan Included Mounting Accessory Description Included mounting brackets provide front-rail installation in 2 or 4 post racks; For additional stability in 4 post racks, consider optional 4 post mounting accessories 4POSTRAILKIT1U & 4POSTRAILKITWM Installation Form Factors Supported with Included Accessories 2 post 19 inch rackmount; 2 post front mount; 4 post 19 inch rackmount 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Installation Form Factors Supported with Optional Accessories Vertical Mount Enclosures ( SRWF5U36 ,  SRWF5U ,  SRWF10UMOD ) Minimum Required Rack Depth (cm) 50.80 Minimum Required Rack Depth (inches) 20 Optional Mounting Accessory Notes Optional  4POSTRAILKITWM  enables installation in 4-port short-depth racks from 14.5 to 23.5 inches (368 to 597mm); Optional  4POSTRAILKIT1U  enables installation in 4-post full-depth racks from 20.5 to 36 inches (521 to 914mm) Primary UPS Depth (mm) 425 Primary UPS Height (mm) 44 Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 5.30 x 21.30 x 22.90 Shipping Dimensions (hwd / cm) 13.46 x 54.10 x 58.17 Shipping Weight (lbs.) 35.00 Shipping Weight (kg) 15.88 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 4.44 x 44.45 x 42.54 UPS Power Module Dimensions (hwd, in.) 1.75 x 17.5 x 16.75 UPS Power Module Weight (kg) 14.51 UPS Power Module Weight (lbs.) 32 Unit Weight (lbs.) 32.0000 Unit Weight (kg) 14.51 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 39 AC Mode Efficiency Rating (100% Load) 99% Audible Noise 45 dBA maximum, front side 1m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX  4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communications ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB LINE / BATTERY TRANSFER Transfer Time 5 milliseconds AC to DC; 1 millisecond DC to AC Low Voltage Transfer to Battery Power (Setpoint) 83 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS; Individually controllable load banks Grounding Lug Back panel grounding lug STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SMART1000RM1U 价格&库存
很抱歉,暂时无法提供与“SMART1000RM1U”相匹配的价格&库存,您可以联系我们找货
