AVRX550U
AVRX550U
    TRIPPLITE
    BATTERY BACK UP AVR 230V RJ11
AVRX550U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States AVR Series 230V 550VA 300W Ultra-Compact Line-Interactive UPS with USB port, C13 Outlets MODEL NUMBER: AVRX550U Highlights ● 550VA ultra-compact 230V line interactive UPS ● Corrects brownouts and overvoltages from 159V to 282V ● 3 UPS battery supported outlets, 3 surge-only outlets ● USB port, TEL/DSL protection, Wall mountable ● C14 inlet and 6 C13 outlets Package Includes Description Tripp Lite's AVRX550U Ultra-Compact Line Interactive UPS offers complete power protection for desktop PCs, network workstations and a wide variety of professional and consumer electronic devices. Uninterruptible Power Supply / UPS circuits switch to battery backup mode within milliseconds to keep connected equipment running without interruption or data loss during power failures. Automatic Voltage Regulation / AVR power conditioning maintains smooth, continuous operation of connected equipment during brownouts and overvoltages. Surge-only outlets offer convenient protection for printers and other desktop accessories not requiring battery support. AC and dataline surge suppression prevents connected equipment damage. USB communications port supports built-in power management and auto-shutdown features of Windows and Mac OS X or full featured monitoring and data-saving auto-shutdown options using Tripp Lite's free PowerAlert monitoring software. Features ● AVRX550U ultra-compact 230V line interactive UPS offers complete AC power protection from blackouts, brownouts and transient surges ● 550VA / 300 watt UPS output capacity ● Uninterruptible Power Supply / UPS operation maintains battery-derived AC output during blackouts to prevent data loss and system downtime for connected equipment ● Built-in USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● HID-compliant USB port also enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● Automatic Voltage Regulation / AVR corrects extended brownouts and overvoltages from 159 to 282V, without using battery power ● 5.1 minutes runtime at 50% load (150 watts) ● Up to 10 minutes runtime for a small desktop computer system consuming 80 watts continuous ● 6 total C13 outlets; Includes two 2m C13 to C14 power cables ● 3 UPS battery backup outlets, plus 3 additional surge-only outlets ● C14 inlet supports a variety of site specific input cordsets ● Network grade AC surge protection is available from all outlets ● Built-in data line surge suppression protects a single dialup or DSL line 1/5 ● AVRX550U UPS System ● USB cable ● Two C13 to C14 power cables ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Supports Tripp Lite's Watchdog system service to restore operation to locked equipment through soft reboot of application/OS or hard power off/on reboot of connected equipment, ideal for unattended kiosk applications ● Built-in grounding lug ● Hot swappable user battery replacement supported via easy access battery access door ● Optional PDUBHV10 bypass PDU enables hot-swappable UPS replacement with no disruption to connected equipment ● Space saving, ultra-compact housing with support for wall-mount, desktop or floor placement Specifications OVERVIEW UPC Code 037332123473 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 10A Nominal Input Voltage(s) Supported 230V AC UPS Input Connection Type C14 inlet UPS Input Connection Description Attached 15cm line cord with C14 inlet. The C14 inlet accepts user-supplied AC power cord with country specific plug UPS Input Cord Length (ft.) 0.5 UPS Input Cord Length (m) 0.2 OUTPUT Output Capacity (VA) 550 Output Capacity (kVA) 0.55 Output Capacity (Watts) 300 Output Capacity (kW) 0.3 Nominal Voltage Details 230V nominal output in battery mode Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Automatic frequency selection Output Voltage Regulation (Line Mode) +8%, -21% Output Voltage Regulation (Battery Mode) +/- 5% Included Output Power Cables Includes 2 C13 to C14 output power cables UPS Output Receptacles (Surge Suppression Only) 3 UPS outlets, 3 surge-only outlets 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Hot-Swap PDU options PDUBHV10 (2U / 8 C13 outlets) Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 220V; 230V; 240V Output Receptacles (6) C13 Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 1.6 min. (300W) Runtime Half Load (min.) 5.1 min. (150W) Expandable Runtime No DC System Voltage (VDC) 12 Battery Access Battery access door Internal UPS Replacement Battery Cartridge IMPORTANT BATTERY REPLACEMENT INFORMATION > If the original battery inside your AVRX550U UPS has a rating of 12V 3.6AH, please order Tripp Lite  RBC36H  (quantity 1) replacement battery; If the original battery inside your AVRX550U UPS has a rating of 12V 5AH, please contact Tripp Lite for assistance Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 159 to 282VAC Overvoltage Correction Input voltages between 245 and 282 are reduced by 12% Undervoltage Correction Input voltages between 159 and 205 are boosted by 14% USER INTERFACE, ALERTS & CONTROLS Switches Combination switch controls on/off power status and self-test operation Audible Alarm Audible alarm indicates power-failure and overload status LED Indicators 2 LEDs indicate power status and overload/check battery status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 320 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out) EMI / RFI AC Noise Suppression Yes PHYSICAL 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary Form Factor Desktop Installation Form Factors Supported with Included Accessories Tower; Ultra-compact desktop; Wallmount Primary UPS Depth (mm) 147 Primary UPS Height (mm) 89 Primary UPS Width (mm) 279 Shipping Dimensions (hwd / in.) 4.60 x 13.40 x 8.80 Shipping Dimensions (hwd / cm) 11.68 x 34.04 x 22.35 Shipping Weight (lbs.) 10.20 Shipping Weight (kg) 4.63 UPS Housing Material ABS UPS Power Module Dimensions (hwd, cm) 8.89 x 27.94 x 14.73 UPS Power Module Dimensions (hwd, in.) 3.5 x 11 x 5.8 UPS Power Module Weight (kg) 3.86 UPS Power Module Weight (lbs.) 8.5 Unit Weight (lbs.) 8.4900 Unit Weight (kg) 3.85 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 54 AC Mode Efficiency Rating (100% Load) 95% COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB interface cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network UPS Tools (NUT) Compatibility NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite Network Management Card Description Network management not supported Communications Interface USB (HID enabled) LINE / BATTERY TRANSFER 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Transfer Time 4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 159 High Voltage Transfer to Battery Power (Setpoint) 282 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS Grounding Details Included STANDARDS & COMPLIANCE Product Certifications GOST (Russia) Product Compliance RoHS; SASO (Saudi Arabia); CE (Europe); FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (International) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
AVRX550U 价格&库存
很抱歉,暂时无法提供与“AVRX550U”相匹配的价格&库存,您可以联系我们找货
