AVRX750U
AVRX750U
    TRIPPLITE
    UPS LOW PROFILE AVR 230V 6 OUT
AVRX750U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States AVR Series 230V 750VA 450W Ultra-Compact Line-Interactive UPS with USB port, C13 Outlets MODEL NUMBER: AVRX750U Highlights ● 750VA ultra-compact 230V line interactive UPS ● Corrects brownouts and overvoltages from 159V to 282V ● 3 UPS battery supported outlets, 3 surge-only outlets ● USB port, TEL/DSL protection, Wall mountable ● C14 inlet and 6 C13 outlets Package Includes Description Tripp Lite's AVRX750U Ultra-Compact Line Interactive UPS offers complete power protection for desktop PCs, network workstations and a wide variety of professional and consumer electronic devices. Uninterruptible Power Supply / UPS circuits switch to battery backup mode within milliseconds to keep connected equipment running without interruption or data loss during power failures. Automatic Voltage Regulation / AVR power conditioning maintains smooth, continuous operation of connected equipment during brownouts and overvoltages. Surge-only outlets offer convenient protection for printers and other desktop accessories not requiring battery support. AC and dataline surge suppression prevents connected equipment damage. USB communications port supports built-in power management and auto-shutdown features of Windows and Mac OS X or full featured monitoring and data-saving auto-shutdown options using Tripp Lite's free PowerAlert monitoring software. Features ● AVRX750U ultra-compact 230V line interactive UPS offers complete AC power protection from blackouts, brownouts and transient surges ● 750VA / 450 watt UPS output capacity ● Uninterruptible Power Supply / UPS operation maintains battery-derived AC output during blackouts to prevent data loss and system downtime for connected equipment ● Built-in USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● HID-compliant USB port also enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● Automatic Voltage Regulation / AVR corrects extended brownouts and overvoltages from 159 to 282V, without using battery power ● 2.4 minutes runtime at 100% load (450 watts), 8.6 minutes runtime at 50% load (225 watts) ● 32 minutes runtime for a desktop computer system consuming 80 watts continuous ● 6 total C13 outlets; Includes two 2m C13 to C14 power cables ● 3 UPS battery backup outlets, plus 3 additional surge-only outlets ● C14 inlet supports a variety of site specific input cordsets ● Network grade AC surge protection is available from all outlets ● Built-in data line surge suppression protects a single dialup or DSL line 1/5 ● AVRX750U UPS System ● USB cable ● Two C13 to C14 power cables ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Supports Tripp Lite's Watchdog system service to restore operation to locked equipment through soft reboot of application/OS or hard power off/on reboot of connected equipment, ideal for unattended kiosk applications ● Built-in grounding lug ● Hot swappable user battery replacement ● Optional PDUBHV10 bypass PDU enables hot-swappable UPS replacement with no disruption to connected equipment ● Space saving, ultra-compact housing with support for wall-mount, desktop or floor placement Specifications OVERVIEW UPC Code 037332123138 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 10A Nominal Input Voltage(s) Supported 230V AC UPS Input Connection Type C14 inlet UPS Input Connection Description Attached 15cm line cord with C14 inlet. The C14 inlet accepts user-supplied AC power cord with country specific plug. UPS Input Cord Length (ft.) 0.5 UPS Input Cord Length (m) 0.2 OUTPUT Output Capacity (VA) 750 Output Capacity (kVA) 0.75 Output Capacity (Watts) 450 Output Capacity (kW) 0.45 Nominal Voltage Details 230V nominal output in battery mode Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Automatic frequency selection Output Voltage Regulation (Line Mode) +8%, -21% Output Voltage Regulation (Battery Mode) +/- 5% Included Output Power Cables Includes 2 C13 to C14 output power cables UPS Output Receptacles (Surge Suppression Only) 3 UPS outlets, 3 surge-only outlets 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Hot-Swap PDU options PDUBHV10 (2U / 8 C13 outlets) Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 220V; 230V; 240V Output Receptacles (6) C13 Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 2.4 min. (450W) Runtime Half Load (min.) 8.6 min. (225W) Expandable Runtime No DC System Voltage (VDC) 12 Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC51  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 159 to 282VAC Overvoltage Correction Input voltages between 245 and 282 are reduced by 12% Undervoltage Correction Input voltages between 159 and 205 are boosted by 14% USER INTERFACE, ALERTS & CONTROLS Switches Combination switch controls on/off power status and self-test operation Audible Alarm Audible alarm indicates power-failure and overload status LED Indicators 2 LEDs indicate power status and overload/check battery status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 320 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out) EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Desktop 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Installation Form Factors Supported with Included Accessories Tower; Ultra-compact desktop; Wallmount Primary UPS Depth (mm) 178 Primary UPS Height (mm) 102 Primary UPS Width (mm) 305 Shipping Dimensions (hwd / in.) 5.40 x 9.80 x 14.50 Shipping Dimensions (hwd / cm) 13.72 x 24.89 x 36.83 Shipping Weight (lbs.) 14.89 Shipping Weight (kg) 6.75 UPS Housing Material ABS UPS Power Module Dimensions (hwd, cm) 10.16 x 30.48 x 17.78 UPS Power Module Dimensions (hwd, in.) 4 x 12 x 7 UPS Power Module Weight (kg) 6.49 UPS Power Module Weight (lbs.) 14.3 Unit Weight (lbs.) 14.3000 Unit Weight (kg) 6.49 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 20 Battery Mode BTU / Hr. (Full Load) 459 AC Mode Efficiency Rating (100% Load) 98% COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB interface cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network UPS Tools (NUT) Compatibility NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite Network Management Card Description Network management not supported Communications Interface USB (HID enabled) LINE / BATTERY TRANSFER 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 159 High Voltage Transfer to Battery Power (Setpoint) 282 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS Grounding Details Yes STANDARDS & COMPLIANCE Product Certifications GOST (Russia) Product Compliance RoHS; SASO (Saudi Arabia); CE (Europe); FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (International) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
AVRX750U
物料型号: - 型号:AVRX750U
器件简介: - AVRX750U是一款超紧凑型230V 750VA 450W在线互动式UPS,为桌面电脑、网络工作站和各种专业及消费类电子设备提供全面的电源保护。在电源故障期间,不间断电源/UPS电路在几毫秒内切换到电池备份模式,以保持连接设备的运行,防止数据丢失和系统停机。自动电压调节/AVR电源调节功能在电压过低和过压期间维持连接设备的平稳、连续运行。仅防浪涌插座为不需要电池支持的打印机和其他桌面配件提供方便的保护。AC和数据线浪涌抑制可防止连接设备损坏。USB通信端口支持Windows和macOS的内置电源管理和自动关机功能,或使用免费的PowerAlert®监控软件实现全功能监控和数据保存自动关机选项。
引脚分配: - 6个C13插座,包括3个UPS电池备份插座和3个额外的仅浪涌保护插座。 - C14输入支持各种特定场所的输入线缆。
参数特性: - 输入相位:单相 - 额定输入电流(最大负载):10A - 支持的额定输入电压:230V AC - 输出容量(VA):750 - 输出容量(W):450 - 电池模式下的标称输出电压:230V - 频率兼容性:50/60Hz,自动频率选择 - 线模式下的输出电压调节:+8%,-21% - 电池模式下的输出电压调节:±5%
功能详解: - 提供针对停电、电压暂降和瞬态浪涌的完整交流电源保护。 - 750VA/450瓦特UPS输出能力。 - 在停电期间维持电池派生的交流输出,以防止连接设备的数据显示和系统停机。 - 内置USB端口,在使用PowerAlert软件时可实现数据保存的无人值守关机,该软件可从Tripp Lite官网免费下载。 - HID兼容USB端口也支持Windows和macOS的内置电源管理和自动关机功能。 - 自动电压调节/AVR功能可纠正从159到282V的长时电压过低和过电压,而不使用电池电源。 - 在100%负载(450瓦特)时运行时间为2.4分钟,在50%负载(225瓦特)时运行时间为8.6分钟。 - 为连续消耗80瓦特的桌面计算机系统提供32分钟的运行时间。 - 包括2个2米C13至C14电源线。
应用信息: - UPS应用:家庭/办公室桌面、音视频、零售销售点、酒店。
封装信息: - 物理尺寸:305mm宽。 - 发货尺寸:5.40x9.80x14.50英寸/13.72x24.89x36.83厘米。 - 发货重量:14.89磅/6.75千克。 - UPS外壳材料:ABS。
AVRX750U 价格&库存
很抱歉,暂时无法提供与“AVRX750U”相匹配的价格&库存,您可以联系我们找货
