ECO550UPS
ECO550UPS
    TRIPPLITE
    UPS ECO GREEN BATTERY BACK UP
ECO550UPS 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 550VA 300W Standby UPS - 10 NEMA 5-15R Outlets, 120V, 50/60 Hz, 5-15P Plug, ENERGY STAR, Desktop/Wall MODEL NUMBER: ECO550UPS Highlights ● Protects equipment against blackouts, brownouts, overvoltages, surges and line noise ● Keeps AC power running during blackouts to allow time for file saves and safe shutdown ● 10 NEMA 5-15R outlets power and protect PC, home theater or digital signage equipment ● Home-friendly alarm remains silent in backup mode, sounding only when imperative ● ENERGY STAR-certified to save electricity, lower costs, and protect the environment Applications ● Protect your PC and other sensitive electronics against power surges, line noise, brownouts, overvoltages and blackouts Compact desktop UPS provides battery backup support for your home/office network system, home theater or digital signage components. ● Operate essential equipment during short-term power outages using battery backup power Features ● Shut down desktop PCs and other equipment without data loss during long-term power outages ● Turn off outlets connected to printers, desk lamps and other non-essential devices when not in use to save energy Energy-Saving 550VA/300W/120V Battery Backup for PCs, Home Theater and Digital Signage The standby ECO550UPS UPS system provides reliable battery backup and AC power protection against blackouts, brownouts, overvoltages, surges and line noise that can damage valuable electronics or destroy data. The 10-outlet 120V battery backup is ideal protection for your home office, media center or professional kiosk, security and small-business phone applications, including computers, routers, printers, HDTVs, Blu-ray players, game consoles, ATMs, security systems and digital signage equipment. Allows Time to Back Up Critical Files During a Blackout Backup support allows you to work through short power failures and gives you enough time to safely save files and shut down your system in case of a prolonged blackout. Backup time varies according to load, but the ECO550UPS should keep an energy-efficient desktop computer with small LCD monitor powered as long as 16 minutes. During normal operation, incoming utility power keeps the replaceable internal battery fully charged, so backup power will always be available. 10 NEMA 5-15R Outlets Protect Your Connected Components Five 5-15R outlets provide battery backup and surge protection for your computer, monitor and other crucial components. The other five 5-15R outlets provide surge suppression only for printers, speakers and other desktop equipment regarded as non-essential during a blackout. ENERGY STAR-Certified to Help You Save Money and Protect the Environment By meeting strict EPA efficiency guidelines, this ENERGY STAR-certified UPS system helps you save money and energy. An ECO power-saving option features three switched ECO outlets (two surge-only, one surge- and battery-protected) that turn off automatically when the device connected to the Battery Backup Master Outlet is powered down or in sleep mode. These outlets are recommended for printers, desk lamps and other non-essential peripherals that don’t need to be operational all the time. 316 Joules Fight Back Against Unexpected Power Surges A 316-joule surge suppression rating protects connected components from the harmful effects of power surges. 1/6 Package Includes ● ECO550UPS 550VA 300W 120V Standby ECO UPS with 10 Outlets ● USB cable ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States HID-Compliant USB Port Allows for Automatic Saves and Shutdowns This USB port connects the ECO550UPS to a computer running Tripp Lite’s free downloadable PowerAlert® software to enable safe unattended file saves and system shutdown in case of a prolonged power failure. USB cable is included. Combats Electromagnetic Interference That Can Harm Equipment Various electromagnetic and radio sources found in virtually every home and business can cause disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this line noise is a common cause of performance problems and can lead to incremental hardware damage, data corruption and audio/video transmission problems. The ECO550UPS incorporates technology that filters out disruptive line noise so that it won’t affect your equipment. Home-Friendly Alarm and Diagnostic LEDs Keep You Informed 24/7 The UPS remains silent in both line and battery backup modes. The alarm sounds only to warn you of a low battery, overload or fault condition. A front-panel green LED indicates operating mode, ECO mode and fault status. Compact Housing Compatible with Easy Desktop or Wall-Mount Installation The space-saving ABS housing fits on a desktop, shelf or anywhere else convenient to your workstation or home theater. Keyhole mounting tabs on the rear allow easy wall-mount installation. The five-foot power cord with NEMA 5-15P plug connects to any compatible AC outlet. Specifications OVERVIEW UPC Code 037332211064 UPS Type Standby INPUT Input Phase Single-Phase Rated input current (Maximum Load) 10A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 10A UPS Input Cord Length (ft.) 5 UPS Input Cord Length (m) 1.5 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 550 Output Capacity (kVA) 0.55 Output Capacity (Watts) 300 Output Capacity (kW) 0.3 Output Capacity Details 4.6A @ 120V. (LINE MODE) 110%+/- 10% @ 5 minutes; (BATTERY MODE) 110% +/- 10% @ 5 seconds 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Nominal Voltage Details 120V sinusoidal in line mode and 120V PWM in battery mode Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Output is regulated to +/-0.05Hz when input frequency exceeds +/-5Hz of nominal. Output Voltage Regulation (Line Mode) 120V (+6%/-12%) Output Voltage Regulation (Battery Mode) 120V (±10%) UPS Output Receptacles (Surge Suppression Only) 5 UPS outlets, 5 surge-only outlets Load Management Receptacles The ECO Energy-Saving option will automatically POWER OFF three designated ECO outlets when the device connected to the MASTER load-sensing outlet is turned off (after approximately 3 minutes); ECO outlets will immediately POWER ON when the device connected to the MASTER load-sensing outlet begins consuming 21 watts or more (see manual) Output AC Waveform (AC Mode) Pure sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (10) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 1.2 min. (300W) Runtime Half Load (min.) 5 min. (150W) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) 6.5 hours (10% to 90%) Battery Access Battery access door Internal UPS Replacement Battery Cartridge IMPORTANT BATTERY REPLACEMENT INFORMATION > If your ECO550UPS has no battery access door, please contact a local electronics repair technician to source and install a matching replacement battery; If your ECO550UPS does have a battery replacement door and the original battery inside has a rating of 12V 3.6AH, please order Tripp Lite # RBC36H  replacement battery Battery Replacement Description Replaceable internal batteries (see manual) VOLTAGE REGULATION Voltage Regulation Description Input voltage range of 90 to 145 USER INTERFACE, ALERTS & CONTROLS Switches Switch controls power off/on status and ECO mode off/on status Audible Alarm Alarm remains silent in battery backup mode; Alarm sounds only to report low-battery, fault, overload and replacebattery conditions 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States LED Indicators 1 Status LED reports operating mode, ECO mode and fault status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 316 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL or Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Desktop Installation Form Factors Supported with Included Accessories Tower; Ultra-compact desktop; Wallmount Primary UPS Depth (mm) 185 Primary UPS Height (mm) 105 Primary UPS Width (mm) 110 Shipping Dimensions (hwd / in.) 7.36 x 5.67 x 10.86 Shipping Dimensions (hwd / cm) 18.69 x 14.40 x 27.58 Shipping Weight (lbs.) 5.20 Shipping Weight (kg) 2.36 UPS Housing Material ABS UPS Power Module Dimensions (hwd, cm) 10.49 x 11.00 x 18.49 UPS Power Module Dimensions (hwd, in.) 4.13 x 4.33 x 7.28 UPS Power Module Weight (kg) 1.80 UPS Power Module Weight (lbs.) 3.96 Unit Weight (lbs.) 3.960 Unit Weight (kg) 1.80 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 113°F (-15° to 45°C ) Relative Humidity 0 to 90%, non-condensing AC Mode BTU / Hr. (Full Load) 13.1 AC Mode Efficiency Rating (100% Load) >98% Operating Elevation (ft.) 6561 ft. (2000 m) above sea level Operating Elevation (m) Up to 3000m 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB interface cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management not supported Communications Interface USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 6 milliseconds typical (10 milliseconds max) Low Voltage Transfer to Battery Power (Setpoint) 95 High Voltage Transfer to Battery Power (Setpoint) 145 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS; Power saving auto-shutoff ECO outlets STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; ENERGY STAR Qualified; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 3-year limited warranty Product Warranty Period (Latin America) 3-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 3-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $100,000 Ultimate Lifetime Insurance  5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
ECO550UPS 价格&库存
很抱歉,暂时无法提供与“ECO550UPS”相匹配的价格&库存,您可以联系我们找货
