OMNIVS1500
OMNIVS1500
    TRIPPLITE
    UPS 1500VA 940W 8OUT USB RJ45
OMNIVS1500 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OmniVS 120V 1500VA 940W Line-Interactive UPS, Tower, USB port MODEL NUMBER: OMNIVS1500 Highlights ● 1500VA / 1.5kVA tower 120V line-interactive UPS ● Corrects brownouts and overvoltages from 75 to 147V ● 5 UPS battery supported outlets, 3 surge-only outlets ● USB port, TEL/DSL/Ethernet protection, 97% line mode efficiency ● NEMA 5-15P input plug and 8 NEMA 5-15R outlets Package Includes Description Tripp Lite's OMNIVS1500 line interactive UPS system offers voltage regulation, surge suppression and battery support for personal computers, internetworking equipment and other sensitive electronics. Internal UPS batteries support entry level PC systems for up to 75 minutes during power failures so that connected equipment can be shut down without data loss. Automatic Voltage Regulation (AVR) circuits regulate brownouts as low as 75 and overvoltages up to 147 volts back to usable 120V levels without using battery power. Offers complete desktop power protection in an attractive black tower configuration. Includes 5 battery supported outlets for computer, monitor and vital system peripherals, plus 3 additional surge suppression only outlets for printers and other system accessories not requiring battery support. USB port enables optional unattended system shutdown without data loss in the case of extended power failure (USB cable included). PowerAlert software available via free download. HID-compliant USB port also enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. Built-in data line suppression offers protection for equipment with single line TEL/DSL or network Ethernet connection. Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery low/replace, voltage regulation and overload. 1500VA power handling ability supports entry-level PCs, network workstations, point-of-sale equipment, small business phone systems, audio/video equipment and home theater systems. Offers 4.5 minutes battery runtime with a full load of 1500VA and 11.5 minutes with a half load of 750VA. Supports hot-swappable battery replacement via built-in access panel. Features ● OMNIVS1500 Uninterruptible Power Supply offers voltage regulation, surge suppression and long lasting battery support ● Supports entry level PCs up to 75 minutes during blackouts to enable shutdown without data loss ● Regulates brownouts as low as 75V and overvoltages to 147V back to usable 120V nominal levels without using battery power ● 5 UPS battery supported outlets, plus 3 additional surge suppression only outlets ● USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● HID-compliant USB port also enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● Data line surge suppression protects standard dialup/DSL or ethernet line connection ● Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery low/replace, voltage regulation and overload 1/5 ● OMNIVS1500 Line-Interactive UPS ● USB and telephone cable ● Owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States ● 1500VA power handling ability supports a variety of sensitive electronic equipment ● 4.5 minutes full load runtime (1500VA), 11.5 minutes half load runtime (750VA) ● Supports hot swappable battery replacement via built-in access panel ● Optional PDUB15 bypass PDU enables hot-swappable UPS replacement with no disruption to connected equipment Specifications OVERVIEW UPC Code 037332126382 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V Input Frequency 60Hz +/-5% OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 940 Output Capacity (kW) 0.94 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) +/- 5% UPS Output Receptacles (Surge Suppression Only) 5 UPS outlets, 3 surge-only outlets Hot-Swap PDU options PDUB15 (2U / 8 5-15R outlets) Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (8) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.5 min. (940W) Runtime Half Load (min.) 11.5 min. (470W) Expandable Runtime No DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) Less than 4 hours from 10% to 90% Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC24-SLT  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 93 and 107 are boosted by 14% Severe Undervoltage Correction Input voltages between 75 and 92 are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 510 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 191 Primary UPS Height (mm) 300 Primary UPS Width (mm) 183 Shipping Dimensions (hwd / in.) 15.75 x 11.22 x 10.83 Shipping Dimensions (hwd / cm) 40.00 x 28.50 x 27.51 Shipping Weight (lbs.) 30.16 Shipping Weight (kg) 13.68 UPS Housing Material Polycarbonate UPS Power Module Dimensions (hwd, cm) 29.97 x 18.29 x 19.05 UPS Power Module Dimensions (hwd, in.) 11.8 x 7.2 x 7.5 UPS Power Module Weight (kg) 10.07 UPS Power Module Weight (lbs.) 22.2 Unit Weight (lbs.) 22.2000 Unit Weight (kg) 10.07 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 109 Battery Mode BTU / Hr. (Full Load) 523 AC Mode Efficiency Rating (100% Load) 97% COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in USB port, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB interface cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network UPS Tools (NUT) Compatibility NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite Network Management Card Description Network management not supported Communications Interface USB (HID enabled) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 75 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 3-year limited warranty Product Warranty Period (Latin America) 3-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 3-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $200,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
OMNIVS1500
物料型号:OMNIVS1500 器件简介:OmniVS 1500VA 940W 交流在线互动式不间断电源(UPS),塔式,带USB端口。
引脚分配:5个UPS电池支持插座,3个仅浪涌保护插座。
参数特性:额定输入电流12A,输入电压120V AC,输出容量1500VA/940W,电池类型为阀控式铅酸电池(VRLA)。
功能详解:提供电压调节、浪涌抑制和电池支持,支持AVR电路,USB端口支持远程系统关机。
应用信息:适用于个人电脑、网络设备和其他敏感电子设备,支持热插拔电池更换。
封装信息:塔式设计,尺寸为300mm x 183mm x 191mm,重量为22.2磅或10.07千克。
OMNIVS1500 价格&库存
很抱歉,暂时无法提供与“OMNIVS1500”相匹配的价格&库存,您可以联系我们找货
