OMNIVSINT1500XL
OMNIVSINT1500XL
    TRIPPLITE
    BATTERY BACK UP TOWER AVR 230V
OMNIVSINT1500XL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OmniVS 230V 1500VA 940W Line-Interactive UPS, Extended Run, Tower, USB port, C13 Outlets Highlights ● 1500VA / 1.5kVA tower 230V line interactive extended-run UPS ● Corrects brownouts and overvoltages from 151 to 282V ● USB port, TEL/DSL/ethernet protection, External battery pack options ● C14 input and 8 C13 outlets MODEL NUMBER: OMNIVSINT1500XL Package Includes Description Tripp Lite's OMNIVSINT1500XL line interactive UPS system offers voltage regulation, surge suppression and long lasting, expandable battery support for personal computers, internetworking equipment and other sensitive electronics. Internal UPS circuits support entry level PC systems for up to 75 minutes during power failures so that connected equipment can be shut down without data loss. Automatic Voltage Regulation (AVR) circuits regulate brownouts as low as 151 and overvoltages up to 282 volts back to usable 230V levels without using battery power. Offers complete desktop power protection in an attractive black tower configuration. Includes 8 IEC320-C13 outlets with battery support and AC surge suppression. USB port enables optional unattended system shutdown without data loss in the case of extended power failure, USB cable included. PowerAlert software available via free download. Built-in single line RJ jacks protect modem, fax machine, Ethernet, cordless phone or other peripheral with a standard dialup/DSL phone connection. Built-in audible alarm and 4 front panel LEDs indicate line power status, battery power status, battery low/replace status and voltage boost operation. 1500VA power handling ability supports entry-level PCs, network workstations, point-of-sale equipment, small business phone systems, audio/video equipment and home theater systems. Offers 4.5 minutes battery runtime with a full load of 1500VA and 13 minutes with a half load of 750VA. Supports hot-swappable battery replacement via builtin access panel. Extended runtime available with optional BP24V15RT2U or BP24V28-2U external battery packs. Features ● OMNIVSINT1500XL Uninterruptible Power Supply offers voltage regulation, surge suppression and long lasting battery support ● Supports entry level PCs up to 75 minutes during blackouts to enable shutdown without data loss, runtime is further expandable by connecting an external battery pack ● Regulates brownouts as low as 151 and overvoltages to 282V back to usable 230V nominal levels without using battery power ● 8 IEC320 C13 outlets with complete AC surge suppression ● C14 inlet accepts user-supplied AC power cord with country-specific plug ● USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Dataline surge suppression protects standard dialup/DSL or Ethernet line connection ● Audible alarm and 4 front panel LEDs offer complete UPS and line power status information 1/5 ● OMNIVSINT1500XL line interactive UPS ● 2 C13 to C14 interconnection cables ● USB and phone line cables ● Owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States ● 1500VA power handling ability supports a variety of sensitive electronic equipment ● 4.5 minutes full load runtime (1500VA), 13 minutes half load runtime (750VA) ● Runtime is further expandable with the addition of external battery packs ● Supports hot swappable battery replacement via built-in access panel ● Optional PDUBHV10 bypass PDU enables hot-swappable UPS replacement with no disruption to connected equipment ● Attractive full color retail packaging Specifications OVERVIEW UPC Code 037332119780 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 5A Nominal Input Voltage(s) Supported 230V AC UPS Input Connection Type C14 inlet UPS Input Connection Description Attached 15cm line cord with C14 inlet. The C14 inlet accepts user-supplied AC power cord with country-specific plug. UPS Input Cord Length (ft.) 0.5 UPS Input Cord Length (m) 0.2 OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 940 Output Capacity (kW) 0.94 Nominal Voltage Details 230V nominal output in battery mode Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Automatic frequency selection Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Included Output Power Cables Includes 2 C13 to C14 output power cables Hot-Swap PDU options PDUBHV10 (2U / 8 C13 outlets) Output AC Waveform (AC Mode) Sine wave 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 220V; 230V; 240V Output Receptacles (8) C13 Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.5 min. (940W) Runtime Half Load (min.) 13 min. (470W) Expandable Runtime Yes External Battery Pack Compatibility  BP24V15RT2U  (limit 1);  BP24V28-2U  (limit 1);  BP24V70-3U  (multi-pack compatible) DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC51  (quantity 2) Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 151 to 282 Overvoltage Correction Input voltages between 245 and 282 are reduced by 12% Undervoltage Correction Input voltages between 177 and 199 are boosted by 14% Severe Undervoltage Correction Input voltages between 151 and 176 are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 340 UPS AC Suppression Response Time Instantaneous 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 191 Primary UPS Height (mm) 300 Primary UPS Width (mm) 183 Shipping Dimensions (hwd / in.) 15.60 x 10.40 x 10.80 Shipping Dimensions (hwd / cm) 39.62 x 26.42 x 27.43 Shipping Weight (lbs.) 32.50 Shipping Weight (kg) 14.74 UPS Housing Material Polycarbonate UPS Power Module Dimensions (hwd, cm) 29.97 x 18.29 x 19.05 UPS Power Module Dimensions (hwd, in.) 11.8 x 7.2 x 7.5 UPS Power Module Weight (kg) 14.51 UPS Power Module Weight (lbs.) 32 Unit Weight (lbs.) 32.0000 Unit Weight (kg) 14.51 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 99 Battery Mode BTU / Hr. (Full Load) 657 AC Mode Efficiency Rating (100% Load) 97% COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in USB port, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB interface cable included 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management not supported Communications Interface USB LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 151 High Voltage Transfer to Battery Power (Setpoint) 282 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS STANDARDS & COMPLIANCE Product Certifications GOST (Russia); IEC/EN 62040; IRAM (Argentina); UL 1778 Product Compliance RoHS; SASO (Saudi Arabia); CE (Europe) WARRANTY & SUPPORT Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 2-year limited warranty Product Warranty Period (Puerto Rico) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
OMNIVSINT1500XL
物料型号:OMNIVSINT1500XL
器件简介:这是一款1500VA / 1.5kVA的塔式不间断电源(UPS),适用于230V线路,具有扩展运行时间、USB端口和C13插座。
引脚分配:包括C14输入和8个C13插座。
参数特性: - 自动电压调节(AVR)电路:能够将151V至282V的电压调节至230V的可用水平,无需使用电池。 - USB端口:允许在长时间停电情况下进行数据保护的无人值守关机。 - 数据线浪涌保护:保护标准拨号/DSL或以太网线路连接。 - 声音报警和4个前面板LED指示器:提供UPS和线路电源状态信息。
功能详解: - 支持入门级PC在停电期间支持长达75分钟,以便在无数据丢失的情况下关机。 - 提供4.5分钟满载运行时间(1500VA)和13分钟半载运行时间(750VA),运行时间可通过外部电池包扩展。 - 支持热插拔电池更换。
应用信息:适用于家庭/办公室桌面、音视频、高端桌面/小型网络、零售销售点和酒店等应用场景。
封装信息: - UPS类型:线路互动式 - 输入电压:230V AC - 输出容量:1500VA / 1.5kVA / 940W - 频率兼容性:50/60Hz,自动频率选择 - 输出插座:8个IEC320 C13插座 - 电池类型:阀控铅酸(VRLA) - 电池续航时间:满载4.5分钟,半载13分钟 - 环境温度范围:0°C至40°C - 交流模式效率等级:97% - 产品认证:GOST (俄罗斯); IEC/EN 62040; IRAM (阿根廷); UL 1778
OMNIVSINT1500XL 价格&库存
很抱歉,暂时无法提供与“OMNIVSINT1500XL”相匹配的价格&库存,您可以联系我们找货
