1000 Eaton Boulevard
Cleveland, OH 44122
United States
750VA 450W Standby UPS - 12 NEMA 5-15R
Outlets, 120V, 50/60 Hz, 5-15P Plug, ENERGY
STAR, Desktop/Wall
MODEL NUMBER: ECO750UPS
Highlights
Protects equipment against
blackouts, brownouts,
overvoltages, surges and line
noise
Keeps AC power running during
blackouts to allow time for file
saves and safe shutdown
12 NEMA 5-15R outlets power
and protect PC, home theater or
digital signage equipment
Home-friendly alarm remains
silent in backup mode, sounding
only when imperative
ENERGY STAR-certified to
save electricity, lower costs, and
protect the environment
Applications
Protect your PC and other
sensitive electronics against
power surges, line noise,
brownouts, overvoltages and
blackouts
Compact desktop UPS provides battery backup support for your home/office network system, home
theater or digital signage components.
Operate essential equipment
during short-term power outages
using battery backup power
Features
Shut down desktop PCs and
other equipment without data
loss during long-term power
outages
Turn off outlets connected to
printers, desk lamps and other
non-essential devices when not
in use to save energy
Extend runtime for DVRs,
wireless routers and other lowpower home networking
equipment
Energy-Saving 750VA/450W/120V Battery Backup for PCs, Home Theater and Digital Signage
The standby ECO750UPS UPS system provides reliable battery backup and AC power protection against
blackouts, brownouts, overvoltages, surges and line noise that can damage valuable electronics or
destroy data. The 12-outlet 120V battery backup is ideal protection for your home office, media center or
professional kiosk, security and small-business phone applications, including computers, routers, printers,
HDTVs, Blu-ray players, game consoles, ATMs, security systems and digital signage equipment.
Allows Time to Back Up Critical Files During a Blackout
Backup support allows you to work through short power failures and gives you enough time to safely save
files and shut down your system in case of a prolonged blackout. Backup time varies according to load,
but the ECO750UPS should keep an energy-efficient desktop computer with small LCD monitor powered
as long as 36 minutes. During normal operation, incoming utility power keeps the replaceable internal
battery fully charged, so backup power will always be available.
12 NEMA 5-15R Outlets Protect Your Connected Components
Six 5-15R outlets provide battery backup and surge protection for your computer, monitor and other
crucial components. The other six 5-15R outlets provide surge suppression only for printers, speakers and
other desktop equipment regarded as non-essential during a blackout.
ENERGY STAR-Certified to Help You Save Money and Protect the Environment
By meeting strict EPA efficiency guidelines, this ENERGY STAR-certified UPS system helps you save
money and energy. An ECO power-saving option features four switched ECO outlets (three surge-only,
one surge- and battery-protected) that turn off automatically when the device connected to the Battery
Backup Master Outlet is powered down or in sleep mode. These outlets are recommended for printers,
desk lamps and other non-essential peripherals that don’t need to be operational all the time.
316 Joules Fight Back Against Unexpected Power Surges
A 316-joule surge suppression rating protects connected components from the harmful effects of power
surges. Dual network data line jacks protect a wired peripheral from dangerous surges on a single
10/100Base-T or dial-up network connection.
1/6
Package Includes
ECO750UPS 750VA 450W
120V Standby ECO UPS with
12 Outlets
USB cable
Owner’s manual
Cleveland, OH 44122
United States
HID-Compliant USB Port Allows for Automatic Saves and Shutdowns
This USB port connects the ECO750UPS to a computer running Tripp Lite’s free downloadable
PowerAlert® software to enable safe unattended file saves and system shutdown in case of a prolonged
power failure. USB cable is included.
Combats Electromagnetic Interference That Can Harm Equipment
Various electromagnetic and radio sources found in virtually every home and business can cause
disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio
frequency interference), this line noise is a common cause of performance problems and can lead to
incremental hardware damage, data corruption and audio/video transmission problems. The ECO750UPS
incorporates technology that filters out disruptive line noise so that it won’t affect your equipment.
Home-Friendly Alarm and Diagnostic LEDs Keep You Informed 24/7
The UPS remains silent in both line and battery backup modes. The alarm sounds only to warn you of a
low battery, overload or fault condition. A front-panel green LED indicates operating mode, ECO mode
and fault status.
Compact Housing Compatible with Easy Desktop or Wall-Mount Installation
The space-saving ABS housing fits on a desktop, shelf or anywhere else convenient to your workstation
or home theater. Keyhole mounting tabs on the rear allow easy wall-mount installation. The five-foot
power cord with NEMA 5-15P plug connects to any compatible AC outlet.
Specifications
OVERVIEW
UPC Code
037332211118
UPS Type
Standby
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
10A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P
Input Circuit Breakers
10A
UPS Input Cord Length (ft.)
5
UPS Input Cord Length (m)
1.5
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
750
Output Capacity (kVA)
0.75
Output Capacity (Watts)
450
Output Capacity (kW)
0.45
Output Capacity Details
6.3A @ 120V. (LINE MODE) 110%+/- 10% @ 5 minutes; (BATTERY MODE) 110% +/- 10% @ 5 seconds
2/6
Cleveland, OH 44122
United States
Nominal Voltage Details
120V sinusoidal in line mode and 120V PWM in battery mode
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Output is regulated to +/-0.05Hz when input frequency exceeds +/-5Hz of nominal.
Output Voltage Regulation (Line
Mode)
120V (+6%/-12%)
Output Voltage Regulation (Battery
Mode)
120V (±10%)
UPS Output Receptacles (Surge
Suppression Only)
6 UPS outlets, 6 surge-only outlets
Load Management Receptacles
The ECO Energy-Saving option will automatically POWER OFF four designated ECO outlets when the device
connected to the MASTER load-sensing outlet is turned off (after approximately 3 minutes); ECO outlets will
immediately POWER ON when the device connected to the MASTER load-sensing outlet begins consuming 23
watts or more (see manual)
Output AC Waveform (AC Mode)
Pure sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(12) 5-15R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
2 min. (450W)
Runtime Half Load (min.)
8.6 min. (225W)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
6.5 hours (10% to 90%)
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC51
Battery Replacement Description
Replaceable internal batteries (see manual)
VOLTAGE REGULATION
Voltage Regulation Description
Input voltage range of 90 to 145
USER INTERFACE, ALERTS & CONTROLS
Switches
Switch controls power off/on status and ECO mode off/on status
Audible Alarm
UPS remains silent in battery backup mode; Alarm sounds only to report low-battery, fault, overload and replacebattery conditions
3/6
Cleveland, OH 44122
United States
LED Indicators
3 Status LEDs; GREEN #1 LED reports ECO mode off/on status; GREEN #2 LED reports line/battery mode
operation, low-battery condition, overload and replace-battery notifications; RED LED reports battery-low, overload,
replace-battery and fault conditions (see manual)
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
316
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL or Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Desktop
Installation Form Factors Supported
with Included Accessories
Tower; Ultra-compact desktop; Wallmount
Primary UPS Depth (mm)
310
Primary UPS Height (mm)
85
Primary UPS Width (mm)
130
Shipping Dimensions (hwd / in.)
7.83 x 5.98 x 14.92
Shipping Dimensions (hwd / cm)
19.89 x 15.19 x 37.90
Shipping Weight (lbs.)
7.48
Shipping Weight (kg)
3.39
UPS Housing Material
ABS
UPS Power Module Dimensions
(hwd, cm)
8.51 x 13.00 x 30.99
(hwd, in.)
3.35 x 5.12 x 12.2
UPS Power Module Weight (kg)
3.09
UPS Power Module Weight (lbs.)
6.82
Unit Weight (lbs.)
6.820
Unit Weight (kg)
3.09
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 113°F (-15° to 45°C )
Relative Humidity
0 to 90%, non-condensing
AC Mode BTU / Hr. (Full Load)
8.3
AC Mode Efficiency Rating (100%
Load)
>98%
Operating Elevation (ft.)
6561 ft. (2000 m) above sea level
4/6
Cleveland, OH 44122
United States
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB interface cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Network Management Card
Description
Network management not supported
Communications Interface
USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
6 milliseconds typical (10 milliseconds max)
Low Voltage Transfer to Battery
Power (Setpoint)
95
High Voltage Transfer to Battery
Power (Setpoint)
145
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS; Power saving auto-shutoff ECO outlets
STANDARDS & COMPLIANCE
Product Certifications
RETIE (Colombia); CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; ENERGY STAR Qualified; FCC Part 15 Class B (USA)
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
3-year limited warranty
Product Warranty Period (Latin
America)
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$100,000 Ultimate Lifetime
Insurance
5/6
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
