INTERNET550SER
INTERNET550SER
    TRIPPLITE
    UPS 550VA 300W 8OUT SERIAL RJ/11
INTERNET550SER 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 550VA 300W Standby UPS - 8 NEMA 5-15R Outlets, 120V, 50/60 Hz, DB9, 5-15P Plug, Desktop/Wall Mount MODEL NUMBER: INTERNET550SER Highlights ● Protects equipment against blackouts, brownouts, overvoltages, surges and line noise ● Keeps AC power running during blackouts to allow time for file saves and safe shutdown ● 8 NEMA 5-15R outlets power and protect PC, home theater or digital signage equipment ● Home-friendly alarm remains silent in backup mode, sounding only when imperative ● Built-in DB9 serial port provides remote notification of site power and UPS status Applications Compact desktop UPS with silent alarm provides battery backup support for your home/office network system or digital signage components. ● Protect equipment in point-ofsale, hospitality, casino gaming, kiosk, digital signage and other PC-based professional applications against power surges, line noise, brownouts, overvoltages and blackouts ● Operate essential equipment during short-term power outages using battery backup power ● Shut down desktop PCs and other equipment without data loss during long-term power outages ● Extend runtime for DVRs, wireless routers and other lowpower home network equipment Features 550VA/300W/120V Battery Backup for PCs, Home Theater and Digital Signage The standby INTERNET550SER UPS system provides reliable battery backup and AC power protection against blackouts, brownouts, overvoltages, surges and line noise that can damage valuable electronics or destroy data. The eight-outlet 120V battery backup is ideal protection for your home office, media center or professional kiosk, security and small-business phone applications that rely on a DB9 serial port for remote notification of site power and UPS operating status information. Allows Time to Back Up Critical Files During a Blackout Backup support allows you to work through short power failures and gives you enough time to safely save files and shut down your system in case of a prolonged blackout. Backup time varies according to load, but the INTERNET550SER should keep an energy-efficient desktop computer with small LCD monitor powered as long as 16 minutes. During normal operation, incoming utility power keeps the replaceable internal battery fully charged, so backup power will always be available. 8 NEMA 5-15R Outlets Protect Your Connected Components Four 5-15R outlets provide battery backup and surge protection for your computer, monitor and other crucial components. The other four 5-15R outlets provide surge suppression only for printers, speakers and other desktop equipment regarded as non-essential during a blackout. A high >98% line mode efficiency rating reduces BTU emissions, energy consumption and, ultimately, your energy costs. 316 Joules Fight Back Against Unexpected Power Surges A 316-joule surge suppression rating protects connected components from the harmful effects of power surges. Dual network data line surge suppression jacks protect a wired peripheral from dangerous surges on a single 10/100Base-T or dial-up network connection. DB9 Serial Port Allows for Automatic Saves and Shutdowns This DB9 port connects the INTERNET550SER to a computer running Tripp Lite’s free downloadable PowerAlert® software to enable safe unattended file saves and system shutdown in case of a prolonged power failure. DB9 cable is included. 1/5 Package Includes ● INTERNET550SER 550VA 300W 120V Standby UPS with 8 Outlets ● DB9 serial interface cable ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Combats Electromagnetic Interference That Can Harm Equipment Various electromagnetic and radio sources found in virtually every home and business can cause disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this line noise is a common cause of performance problems and can lead to incremental hardware damage, data corruption and audio/video transmission problems. The INTERNET550SER incorporates technology that filters out disruptive line noise so that it won’t affect your equipment. Home-Friendly Alarm and Diagnostic LEDs Keep You Informed 24/7 The UPS remains silent in both line and battery backup modes. The alarm sounds only to warn you of a low battery or fault condition. A front-panel green LED indicates line/battery mode status, overloads and low/replace battery alert. Compact Housing Compatible with Easy Desktop or Wall-Mount Installation The space-saving ABS housing fits on a desktop, shelf or anywhere else convenient to your workstation or home theater. Keyhole mounting tabs on the rear allow easy wall-mount installation. The five-foot power cord with NEMA 5-15P plug connects to any compatible AC outlet. Specifications OVERVIEW UPC Code 037332211019 UPS Type Standby INPUT Input Phase Single-Phase Rated input current (Maximum Load) 6A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 7A UPS Input Cord Length (ft.) 5 UPS Input Cord Length (m) 1.5 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 550 Output Capacity (kVA) 0.55 Output Capacity (Watts) 300 Output Capacity (kW) 0.3 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 50 / 60 Hz Output Voltage Regulation (Line Mode) 120V (±20%) 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Voltage Regulation (Battery Mode) 120V (±10%) UPS Output Receptacles (Surge Suppression Only) 4 UPS outlets, 4 surge-only outlets Output AC Waveform (AC Mode) Pure sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (8) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 1.2 min. (300W) Runtime Half Load (min.) 5 min. (150W) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) 6.5 hours (10% to 90%) Battery Access Battery access door Internal UPS Replacement Battery Cartridge IMPORTANT BATTERY REPLACEMENT INFORMATION > If your INTERNET550SER has no battery access door, please contact a local electronics repair technician to source and install a matching replacement battery; If your INTERNET550SER UPS does have a battery replacement door and the original battery inside has a rating of 12V 3.6AH, please order Tripp Lite replacement battery Model Number  RBC36H  Battery Replacement Description Replaceable internal batteries (see manual) USER INTERFACE, ALERTS & CONTROLS Switches Switch controls power off/on status Audible Alarm UPS remains silent in battery backup mode; Alarm sounds only to report low-battery, fault, overload and replacebattery conditions LED Indicators 1 Status LED reports operating mode and fault status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 316 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL or Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary Form Factor Desktop Installation Form Factors Supported with Included Accessories Tower; Ultra-compact desktop; Wallmount Primary UPS Depth (mm) 185 Primary UPS Height (mm) 105 Primary UPS Width (mm) 110 Shipping Dimensions (hwd / in.) 7.36 x 5.67 x 10.86 Shipping Dimensions (hwd / cm) 18.69 x 14.40 x 27.58 Shipping Weight (lbs.) 4.40 Shipping Weight (kg) 2.00 UPS Housing Material ABS UPS Power Module Dimensions (hwd, cm) 10.49 x 11.00 x 18.49 UPS Power Module Dimensions (hwd, in.) 4.13 x 4.33 x 7.28 UPS Power Module Weight (kg) 1.80 UPS Power Module Weight (lbs.) 3.96 Unit Weight (lbs.) 3.960 Unit Weight (kg) 1.80 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 113°F (-15° to 45°C ) Relative Humidity 0 to 90%, non-condensing AC Mode BTU / Hr. (Full Load) 13.1 AC Mode Efficiency Rating (100% Load) >98% Operating Elevation (ft.) Up to 10,000 ft. Operating Elevation (m) Up to 3000m COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in DB9 Serial port, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable DB9 serial interface cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management not supported Communications Interface DB9 Serial 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States LINE / BATTERY TRANSFER Transfer Time 6 milliseconds typical (10 milliseconds max) Low Voltage Transfer to Battery Power (Setpoint) 95 High Voltage Transfer to Battery Power (Setpoint) 145 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 3-year limited warranty Product Warranty Period (Latin America) 3-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 3-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $100,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
INTERNET550SER
### 物料型号 - 型号编号:INTERNET550SER - UPC代码:037332211019
### 器件简介 - 550VA 300W 备用UPS:提供550VA/300W/120V的电池备份,适用于个人电脑、家庭影院和数字标牌。 - 保护功能:防止停电、电压骤降、过电压、浪涌和线路噪声,保护贵重电子设备和数据安全。 - 输出插座:8个NEMA 5-15R插座,其中4个提供电池备份和浪涌保护,另外4个仅提供浪涌抑制。
### 引脚分配 - DB9串行端口:用于远程通知站点电源和UPS操作状态信息,支持自动保存文件和系统关闭。
### 参数特性 - 输入参数: - 输入相位:单相 - 额定输入电流:6A - 名义输入电压:120V AC - 输入电路断路器:7A - UPS输入连接类型:5-15P - UPS输入线长度:5英尺(1.5米) - 输出参数: - 输出容量(VA):550 - 输出容量(W):300 - 名义输出电压:120V - 频率兼容性:50/60Hz - 输出电压调节(线路模式):1 120V(±20%) - 输出电压调节(电池模式):120V(±10%) - 电池参数: - 电池类型:阀控铅酸(VRLA) - 全负载运行时间(分钟):1.2(300W) - 半负载运行时间(分钟):5(150W) - 系统直流电压:12V - 电池充电率:6.5小时(10%至90%)
### 功能详解 - 浪涌保护:316焦耳浪涌抑制等级,保护连接设备免受浪涌损害。 - 电磁干扰抑制:内置技术过滤破坏性线路噪声,保护设备。 - 静音报警和诊断LED:UPS在线路和电池备份模式下保持静音,仅在低电池或故障时发出警报。 - 紧凑设计:适合桌面或壁挂安装,节省空间。
### 应用信息 - 应用场景:销售、酒店、赌场游戏、自助服务亭、数字标牌等基于PC的专业应用,保护设备免受浪涌、线路噪声、电压骤降、过电压和停电的影响。
### 封装信息 - 主要UPS尺寸:长110mm x 宽185mm x 高105mm - 运输尺寸:7.36x5.67x10.86英寸(18.69x14.40x27.58厘米) - 运输重量:4.40磅(2.00千克)
INTERNET550SER 价格&库存
很抱歉,暂时无法提供与“INTERNET550SER”相匹配的价格&库存,您可以联系我们找货
