SMART1500XL
SMART1500XL
    TRIPPLITE
    UPS 1500VA 980W 6OUT W/SOFTWARE
SMART1500XL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 1.5kVA 980W Line-Interactive UPS, Tower, Extended Run, USB, DB9, 6 Outlets MODEL NUMBER: SMART1500XL Highlights ● Corrects under- and overvoltages from 75V to 147V ● 6 NEMA 5-15R outlets—1 switchable via network interface ● Front-panel LEDs indicate load, power and battery statuses ● Expandable runtime with optional external battery packs ● 20 min. runtime at half load; 7 min. at full load Package Includes Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts, brownouts, power surges and line noise. Ideal solution for VoIP systems, point-of-sale applications and network closets. Description The SMART1500XL SmartPro 120V 1.5kVA 980W Line-Interactive UPS provides battery backup and AC power protection against blackouts, brownouts, power surges and line noise that can damage electronics or destroy data. Ideal for backing up VoIP systems, point-of-sale applications and network closets, the SMART1500XL switches to battery mode in milliseconds to keep your connected equipment running long enough to save files and shut down safely with no data loss. Featuring six NEMA 5-15R outlets (one switchable) and a six-foot power cord with 120V NEMA 5-15P input, the SMART1500XL has an internal battery that provides 20 minutes of support at half load and seven minutes at full load. Adding external battery packs, such as Tripp Lite’s BP36V15-2U (sold separately), provides extended runtime. Front-panel LEDs indicate line power, battery power, overload, voltage regulation and battery status. An alarm sounds to indicate power failure, overload or a low battery. Automatic voltage regulation (AVR) maintains 120V nominal output over an input range of 75V to 147V without using battery power. EMI/RFI noise filtering improves your equipment’s performance and prevents damage. A 480-joule surge suppression rating protects your equipment from harmful power surges. With Tripp Lite’s PowerAlert® software (available via free download), SMART1500XL enables safe unattended system shutdown and file saves in case of a prolonged power failure. Features Protects Mission-Critical Equipment ● Provides fully regulated AC output for VoIP systems, point-of-sale applications and network closets ● Audible alarm signals loss of utility power, overload or low battery 1/6 ● SMART1500XL SmartPro 120V 1.5kVA 980W Line-Interactive UPS ● USB cable ● DB9 cable ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● 6 NEMA 5-15R outlets ● 6 ft. power cord with 120V NEMA 5-15P input ● 480-joule surge suppression rating Reliable Battery Backup with Expandable Runtime ● Supports half load up to 20 min. and full load up to 7 min. ● Internal batteries designed for hot-swap field replacement ● 95% line-power efficiency rating saves money in energy costs ● Expandable runtime with optional external battery packs, such as Tripp Lite’s BP36V15-2U Load Bank with Switchable Outlet ● Can control 1 outlet remotely to reboot equipment or shed nonessential loads Automatic Voltage Regulation (AVR) ● Maintains 120V nominal output over input range of 75V–147V without using battery power EMI/RFI Line Noise Filtering ● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment’s performance LED Indicators ● Front-panel LEDs signal indicate line power, battery power, overload, voltage regulation and battery status Communications Ports ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert Small-Footprint Tower Housing ● Mounts on wall with optional UPSWM accessory Specifications OVERVIEW UPC Code 037332100689 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Input Circuit Breakers 15A UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 980 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles One switchable single-outlet 5-15R load bank Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 7 min. (980w) Runtime Half Load (min.) 20 min. (490w) Expandable Runtime Yes External Battery Pack Compatibility  BP36V15-2U  (limit 1);  BP36V42-3U  (multi-pack compatible);  BP36V27-2US  (multi-pack compatible) DC System Voltage (VDC) 36 Battery Recharge Rate (Included Batteries) Less than 4 hours from 10% to 90% (typical, full load discharge) Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC53  Battery Replacement Description Hot-swappable, user replaceable batteries 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 93 and 107 are boosted by 14% Severe Undervoltage Correction Input voltages between 75 and 92 are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure, overload and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 241 Primary UPS Height (mm) 325 Primary UPS Width (mm) 191 Shipping Dimensions (hwd / in.) 17.00 x 11.00 x 13.12 Shipping Dimensions (hwd / cm) 43.18 x 27.94 x 33.32 Shipping Weight (lbs.) 43.40 Shipping Weight (kg) 19.69 UPS Housing Material PVC UPS Power Module Dimensions (hwd, cm) 32.51 x 19.05 x 24.13 UPS Power Module Dimensions (hwd, in.) 12.8 x 7.5 x 9.5 UPS Power Module Weight (kg) 18.87 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Power Module Weight (lbs.) 41.6 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 176 Battery Mode BTU / Hr. (Full Load) 456 AC Mode Efficiency Rating (100% Load) 95% COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management not supported Communications Interface USB; DB9 Serial LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 75 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic Voltage Regulation (AVR); Hot swappable batteries; Expandable battery backup; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS; Individually controllable load banks WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMART1500XL 价格&库存
很抱歉,暂时无法提供与“SMART1500XL”相匹配的价格&库存,您可以联系我们找货
