SMART1500
SMART1500
    TRIPPLITE
    BATT BACKUP 980W W/CDROM SOFTWR
SMART1500 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 1.5kVA 980W Line-Interactive UPS, Tower, USB, DB9, 6 Outlets MODEL NUMBER: SMART1500 Highlights ● Corrects under- and overvoltages from 75V to 147V ● 6 NEMA 5-15R outlets—1 switchable via network interface ● Front-panel LEDs indicate load, power and battery statuses ● Monitoring of power conditions via PowerAlert® ● 20 min. runtime at half load; 7 min. at full load Package Includes Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts, brownouts, power surges and line noise. Ideal solution for point-of-sale applications, VoIP systems and small business networks. Description The SMART1500 SmartPro 120V 1.5kVA 980W Line-Interactive UPS provides battery backup and AC power protection against blackouts, brownouts, power surges and line noise that can damage electronics or destroy data. Ideal for backing up point-of-sale applications, VoIP systems and small business networks, the SMART1500 switches to battery mode in milliseconds to keep your connected equipment running long enough to save files and shut down safely with no data loss. Featuring six NEMA 5-15R outlets (one switchable) and a six-foot power cord with 120V NEMA 5-15P input, the SMART1500 has an internal battery that provides 20 minutes of support at half load and seven minutes at full load. Front-panel LEDs indicate line power, battery power, overload, voltage regulation and battery status. An alarm sounds to indicate power failure, overload or a low battery. Automatic voltage regulation (AVR) maintains 120V nominal output over an input range of 75V to 147V without using battery power. EMI/RFI noise filtering improves your equipment’s performance and prevents damage. A 480-joule surge suppression rating protects your equipment from harmful power surges. With Tripp Lite’s PowerAlert software (available via free download), the SMART1500 enables safe unattended system shutdown and file saves in case of a prolonged power failure. Features Protects Mission-Critical Equipment ● Provides fully regulated AC output for point-of-sale applications, VoIP systems and small business networks ● Audible alarm signals loss of utility power, overload or low battery ● 6 NEMA 5-15R outlets ● 6 ft. power cord with 120V NEMA 5-15P input ● 480-joule surge suppression rating Reliable Battery Backup ● Supports half load up to 20 min. and full load up to 7 min. ● Internal batteries designed for hot-swap field replacement ● 96% line-power efficiency rating saves money in energy costs 1/5 ● SMART1500 SmartPro 120V 1.5kVA 980W Line-Interactive UPS ● USB cable ● DB9 cable ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Cold-start capability enables turn-on in battery mode during blackouts Load Bank with Switchable Outlet ● Can control one outlet remotely to reboot equipment or shed nonessential loads Automatic Voltage Regulation (AVR) ● Maintains 120V nominal output over input range of 75V–147V without using battery power EMI/RFI Line Noise Filtering ● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment’s performance LED Indicators ● Front-panel LEDs indicate line power, battery power, overload, voltage regulation and battery status Communications Ports ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert Small-Footprint Tower Housing ● Mounts on wall with optional UPSWM accessory Specifications OVERVIEW UPC Code 037332115812 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 15A UPS Input Cord Length (ft.) 7 UPS Input Cord Length (m) 2.1 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Capacity (Watts) 980 Output Capacity (kW) 0.98 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles One switchable single-outlet 5-15R load bank Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 7 min. (980W) Runtime Half Load (min.) 20 min. (490W) Expandable Runtime No DC System Voltage (VDC) 36 Battery Recharge Rate (Included Batteries) Less than 4 hours from 10% to 90% (typical, full load discharge) Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC36-SLT  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 93 and 107 are boosted by 14% Severe Undervoltage Correction Input voltages between 75 and 92 are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Audible Alarm Audible alarm indicates power-failure, overload and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 510 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 235 Primary UPS Height (mm) 324 Primary UPS Width (mm) 191 Shipping Dimensions (hwd / in.) 17.10 x 11.10 x 13.00 Shipping Dimensions (hwd / cm) 43.43 x 28.19 x 33.02 Shipping Weight (lbs.) 40.50 Shipping Weight (kg) 18.37 UPS Housing Material PVC UPS Power Module Dimensions (hwd, cm) 32.38 x 19.05 x 23.50 UPS Power Module Dimensions (hwd, in.) 12.75 x 7.5 x 9.25 UPS Power Module Weight (kg) 17.69 UPS Power Module Weight (lbs.) 39 Unit Weight (lbs.) 39.0000 Unit Weight (kg) 17.69 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 139 Battery Mode BTU / Hr. (Full Load) 456 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States AC Mode Efficiency Rating (100% Load) 96% COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management not supported Communications Interface USB; DB9 Serial LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 75 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS; Individually controllable load banks STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SMART1500
物料型号:SMART1500
器件简介: - SMART1500是一款120V 1.5kVA 980W的在线互动式UPS,能够为关键任务设备提供电池备份和交流电源保护,防止因停电、电压波动、电力浪涌和线路噪声造成的损害。 - 适用于销售点应用、VoIP系统和小型企业网络。
引脚分配: - 提供六个NEMA 5-15R插座(其中一个可切换)和一个120V NEMA 5-15P输入的六英尺电源线。
参数特性: - 输出容量:1500VA,1.5kVA,980W。 - 电池类型:阀控铅酸(VRLA)。 - 满负载运行时间:7分钟(980W),半负载运行时间:20分钟(490W)。 - 自动电压调节(AVR):在75V到147V的输入电压范围内维持120V的标称输出,不使用电池电源。 - EMI/RFI噪声过滤:提高设备性能并防止损害。 - 浪涌抑制等级:480焦耳。
功能详解: - 保护关键任务设备:为销售点应用、VoIP系统和小型企业网络提供完全调节的交流输出。 - 可听见的报警信号:在失去公用电力、过载或电池电量低时发出声音报警。 - 冷启动能力:在停电期间可以在电池模式下启动。
应用信息: - UPS应用:适用于大型网络、高端桌面/小型网络。
封装信息: - 主要外形因素:塔式。 - 冷却方法:风扇。 - 安装方式:支持塔式安装,可选墙壁安装套件(UPSWM-塔式安装套件)。
其他信息: - 产品认证:CSA(加拿大)、NOM(墨西哥)、UL 1778。 - 产品符合性:RoHS;FCC第15部分A类(美国)。 - 产品保修期:全球2年保修,注册后3年保修。注意:需要注册以获得3年保修。 - 连接设备保险(美国、加拿大和波多黎各):250万美元终极终身保险。
SMART1500 价格&库存
很抱歉,暂时无法提供与“SMART1500”相匹配的价格&库存,您可以联系我们找货
