SMART750RM1U
SMART750RM1U
    TRIPPLITE
    UPS 600W 6OUT RACKMNT W/SOFTWARE
SMART750RM1U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 750VA 600W Line-Interactive Sine Wave UPS, 1U Rack/Vertical, Network Management Card Options, USB, DB9 Serial Highlights ● .75kVA / 750VA / 600W line interactive 1U rack/vertical UPS, Sine wave output ● 120V output, Corrects brownouts and overvoltages from 83V to 147V ● 0.8 Power Factor, Front panel status LEDs ● Mounting brackets support 2 and 4 post installation ● 98% line-mode efficiency, 2 switched load banks ● USB, RS232, EPO and slot for Network Management Card options ● 120V NEMA 5-15P input, 6 NEMA 5-15R outlets ● To use the Auto Probe feature, this product requires a WEBCARDLX network interface (sold separately) running LX firmware update 15.5.2 or later MODEL NUMBER: SMART750RM1U Package Includes Description Tripp Lite SMART750RM1U 750VA / .75kVA / 600 watt line interactive, sine wave UPS system offers complete power protection for critical network applications in a highly efficient 1U total rack/vertical configuration. Simultaneous-use network management interfaces include USB, RS-232 and slot for optional Network Management Card options. Line interactive voltage regulation, network-grade surge suppression and long-lasting sine wave AC output during blackouts make this UPS ideal for advanced networking applications in datacenters, computer rooms and network closets. Features ● Tripp Lite SMART750RM1U .75kVA / 750VA / 600 watt line interactive UPS ● 1U rack/vertical compatible form factor ● Included mounting brackets support 2 and 4 post rackmount installation; Optional 4POSTRAILKIT1U is available for additional support ● NEMA 5-15P input; 6 5-15R output receptacles ● Installed depth of only 16.75 in. / 42.5cm ● Sine wave output in both AC and battery backup modes ● Line Interactive UPS provides Automatic Voltage Regulation / AVR to maintain 120V nominal output during brownouts to 83V and overvoltages to 147V without using battery power ● Full load efficiency rating of 98% saves energy and ensures cool operating temperatures ● Integrated 2 bank switched PDU enables remote outlet management for load shedding or remote reboot of individual devices ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX and SNMPWEBCARD ● 3 stage metered LEDs offer current monitoring and battery charge level ● Mains power and voltage regulation LEDs offer at-a-glance power status information 1/6 ● SMART750RM1U UPS System ● Mounting hardware ● USB, DB9 and EPO Cabling ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Front panel switches support self-test and alarm cancel functions ● Field replaceable, hot-swappable internal UPS batteries Specifications OVERVIEW UPC Code 037332118813 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 7A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 15A Recommended Electrical Service 15A 120V Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 OUTPUT Output Capacity (VA) 750 Output Capacity (kVA) 0.75 Output Capacity (Watts) 600 Output Capacity (kW) 0.6 Power Factor 0.8 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -21%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Two switchable single-outlet 5-15R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15R 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.9 min. (600W) Runtime Half Load (min.) 13.2 min. (300W) Expandable Runtime No DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) Less than 4 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC64-1U  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 83 and 107 are boosted by 14% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure, overload and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 450 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount; Vertical Rack Height 1U Cooling Method Fan Included Mounting Accessory Description Included mounting brackets provide front-rail installation in 2 or 4 post racks; For additional stability in 4 post racks, consider optional 4 post mounting accessories 4POSTRAILKIT1U & 4POSTRAILKITWM 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Installation Form Factors Supported with Included Accessories 2 post 19 inch rackmount; 2 post front mount; 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 4 post rackmount full-depth ( 4POSTRAILKIT1U ); 4 post rackmount shortdepth ( 4POSTRAILKITWM ); Vertical Mount Enclosures ( SRWF5U36 ,  SRWF5U ,  SRWF10UMOD ) Minimum Required Rack Depth (cm) 50.80 Minimum Required Rack Depth (inches) 20 Optional Mounting Accessory Notes Optional  4POSTRAILKITWM  enables installation in 4-port short-depth racks from 14.5 to 23.5 inches (368 to 597mm); Optional  4POSTRAILKIT1U  enables installation in 4-post full-depth racks from 20.5 to 36 inches (521 to 914mm) Primary UPS Depth (mm) 425 Primary UPS Height (mm) 44 Primary UPS Width (mm) 445 Shipping Dimensions (hwd / in.) 5.20 x 23.10 x 20.70 Shipping Dimensions (hwd / cm) 13.21 x 58.67 x 52.58 Shipping Weight (lbs.) 34.10 Shipping Weight (kg) 15.47 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 4.44 x 44.45 x 42.54 UPS Power Module Dimensions (hwd, in.) 1.75 x 17.5 x 16.75 UPS Power Module Weight (kg) 13.61 UPS Power Module Weight (lbs.) 30 Unit Weight (lbs.) 30.0000 Unit Weight (kg) 13.61 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 38 Battery Mode BTU / Hr. (Full Load) 545 AC Mode Efficiency Rating (100% Load) 98% 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Audible Noise 45 dBA maximum, front side 1m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB LINE / BATTERY TRANSFER Transfer Time 5 milliseconds AC to DC; 1 millisecond DC to AC Low Voltage Transfer to Battery Power (Setpoint) 83 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection Grounding Lug Back panel grounding lug STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMART750RM1U 价格&库存
很抱歉,暂时无法提供与“SMART750RM1U”相匹配的价格&库存,您可以联系我们找货
