1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 208V 5kVA 3.75kW Line-Interactive
Sine Wave UPS, 3U Rack/Tower, Network Card
Options, USB, DB9 Serial
Highlights
5kVA / 5000VA line interactive
3U rack/tower UPS; Sine wave
output
208V nominal output during
inputs of 174-282V; Supports
600VA 120V output
USB, Serial, EPO & slot for
Network Management Card
options
97% line-mode efficiency; Hotswappable internal batteries;
Energy Star Compliant
NEMA L6-30P input; 2 NEMA 515R, 2 L6-20R & 1 L6-30R
outlets
MODEL NUMBER: SMART5000TEL3U
Package Includes
Description
Tripp Lite's SMART5000TEL3U intelligent, line interactive UPS protects server, networking and
telecommunications equipment from blackouts, voltage fluctuations and surges in a compact rackmount
housing. Completely self-contained UPS system occupies only 3 rack spaces (3U) in a standard 19 inch
rack, making this model one of the smallest 5kVA UPS systems available. Included accessories support
mounting 4 post rack enclosures. Large capacity 5000 VA/3750 watt UPS system accepts raw AC input,
adjusting output to regulated 208V levels. One pair of 120V outlets support up to 600VA monitors and
other low voltage accessories. Includes slot for internal Network Management Card option. Includes USB
and 2 DB9 monitoring ports for unattended shutdown, remote control and monitoring of UPS system and
power data. Five outlets (two L6-20R, one L6-30R and two 5-15R) allow the connection of high current 20
and 30 amp 208V connectors and up to two 120V devices (max 600VA at 120V).
Features
Large 5000VA/3750-watt output capacity accommodates solitary large loads or multiple low-power
loads
High power density 5kVA power module occupies only 3 rack spaces (3U)
16 minutes half-load runtime (with a continuous load 2500VA; much longer runtime available at smaller
loads)
Line-interactive voltage regulation corrects severe brownouts and overvoltages without using battery
power
High voltage output supports 208V server, internetworking and telecom applications
Pair of 120V outlets supports up to 600VA for standard 120V monitors, voicemail and other low-power
networking devices
Five total outlets (two L6-20R, one L6-30R and two 5-15R)
Diagnostic LEDs provide visual indication of 17 separate performance conditions
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
Built-in USB, DB9 RS-232 and DB9 contact closure communications ports for remote monitoring and
unattended shutdown
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX and
SNMPWEBCARD
1/5
SMART5000TEL3U UPS
System
USB & DB9 Serial cabling
Mounting hardware
Instruction manual
Cleveland, OH 44122
United States
Emergency Power Off (EPO) interface for emergency shutoff in large facilities
Hot-swappable/user-replaceable batteries allow on-site battery replacement through the front panel
without powering off connected equipment or removing the UPS from the rack
Intelligent battery management system extends battery life
UPS ships fully assembled and ready for installation; no time-consuming user battery connections
required
Specifications
OVERVIEW
UPC Code
037332116116
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
24A
Nominal Input Voltage(s) Supported
208V AC
UPS Input Connection Type
L6-30P
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
30A 208V
OUTPUT
Output Capacity (VA)
5000
Output Capacity (kVA)
5
Output Capacity (Watts)
3750
Output Capacity (kW)
3.75
Output Capacity Details
120V 5-15R outlets are limited to 450 watts (max.)
Power Factor
0.75
Nominal Voltage Details
120V output is limited to 450 watts
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
208 & 120V (-6%, +20%)
Output Voltage Regulation (Battery
Mode)
+/- 5%
Output Circuit Breakers
20A double pole breaker supports L6-20R outlets, 5A breaker supports 5-15R outlets, L6-30R outlet is unbreakered
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
2/5
Cleveland, OH 44122
United States
Nominal Output Voltage(s)
Supported
208V
Output Receptacles
(2) 5-15R; (2) L6-20R; (1) L6-30R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
8.5 min. (3750W)
Runtime Half Load (min.)
20 min. (1875W)
Expandable Runtime
No
DC System Voltage (VDC)
48
Battery Recharge Rate (Included
Batteries)
Less than 4 hours from 10% to 90% (typical, full load discharge)
Battery Access
Front panel battery access door
Internal UPS Replacement Battery
Cartridge
RBC94-3U (quantity 3)
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 167 to 260
Overvoltage Correction
Input voltages between 228V and 260V are reduced by 12%
Undervoltage Correction
Input voltages between 167V and 194V are boosted by 12%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure, overload and low-battery conditions
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
1020
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
3U
Cooling Method
Fan
3/5
Cleveland, OH 44122
United States
Installation Form Factors Supported
with Included Accessories
4 post 19 inch rackmount
with Optional Accessories
2 post rackmount ( 2POSTRMKITHD ); Tower
( 2-9USTAND )
Minimum Required Rack Depth (cm)
76.20
(inches)
30
Primary UPS Depth (mm)
635
Primary UPS Height (mm)
133
Primary UPS Width (mm)
445
Shipping Dimensions (hwd / in.)
12.00 x 23.00 x 33.00
Shipping Dimensions (hwd / cm)
30.48 x 58.42 x 83.82
Shipping Weight (lbs.)
182.00
Shipping Weight (kg)
82.55
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
13.34 x 44.45 x 63.50
(hwd, in.)
5.25 x 17.5 x 25
UPS Power Module Weight (kg)
65.00
UPS Power Module Weight (lbs.)
143.3
Unit Weight (lbs.)
143.3000
Unit Weight (kg)
65.00
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
366
Battery Mode BTU / Hr. (Full Load)
1423
AC Mode Efficiency Rating (100%
Load)
97%
Audible Noise
45 dBA maximum, front side 1m
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
4/5
Cleveland, OH 44122
United States
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB
LINE / BATTERY TRANSFER
Transfer Time
7 milliseconds (AC to Battery), 1 millisecond (Battery to AC)
Low Voltage Transfer to Battery
Power (Setpoint)
167
High Voltage Transfer to Battery
Power (Setpoint)
260
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries;
Remote management; Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
Grounding Lug
Back panel grounding lug
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); UL 1778
Product Compliance
RoHS; ENERGY STAR Qualified; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year warranty, 3 year with registration. Note: Registration is required for 3-year
warranty.
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
