INTERNET350SER
INTERNET350SER
    TRIPPLITE
    UPS 350VA 180W 120V 6OUT W/RJ11
INTERNET350SER 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 350VA 210W Standby UPS - 6 NEMA 5-15R Outlets, 120V, 50/60 Hz, DB9, 5-15P Plug, Desktop/Wall Mount MODEL NUMBER: INTERNET350SER Highlights ● Protects equipment against blackouts, brownouts, overvoltages, surges and line noise ● Keeps AC power running during blackouts to allow time for file saves and safe shutdown ● 6 NEMA 5-15R outlets power and protect PC, home theater or digital signage equipment ● Home-friendly alarm remains silent in backup mode, sounding only when imperative ● Built-in DB9 serial port provides remote notification of site power and UPS status Applications Compact desktop UPS with silent alarm provides battery backup support for your home/office network system or digital signage components. ● Protect equipment in point-ofsale, hospitality, casino gaming, kiosk, digital signage and other PC-based professional applications against power surges, line noise, brownouts, overvoltages and blackouts ● Operate essential equipment during short-term power outages using battery backup power ● Shut down desktop PCs and other equipment without data loss during long-term power outages ● Extend runtime for DVRs, wireless routers and other lowpower home network equipment Features 350VA/210W/120V Battery Backup for PCs, Home Theater and Digital Signage The standby INTERNET350SER UPS system provides reliable battery backup and AC power protection against blackouts, brownouts, overvoltages, surges and line noise that can damage valuable electronics or destroy data. The six-outlet 120V battery backup is ideal protection for your home office, media center or professional kiosk, security and small-business phone applications that rely on a DB9 serial port for remote notification of site power and UPS operating status information. Allows Time to Back Up Critical Files During a Blackout Backup support allows you to work through short power failures and gives you enough time to safely save files and shut down your system in case of a prolonged blackout. Backup time varies according to load, but the INTERNET350SER should keep an energy-efficient desktop computer with small LCD monitor powered as long as 13 minutes. During normal operation, incoming utility power keeps the replaceable internal battery fully charged, so backup power will always be available. 6 NEMA 5-15R Outlets Protect Your Connected Components Three 5-15R outlets provide battery backup and surge protection for your computer, monitor and other crucial components. The other three 5-15R outlets provide surge suppression only for printers, speakers and other desktop equipment regarded as non-essential during a blackout. Each outlet offers wide spacing to accommodate bulky transformer plugs. A high >98% line mode efficiency rating reduces BTU emissions, energy consumption and, ultimately, your energy costs. 316 Joules Fight Back Against Unexpected Power Surges A 316-joule surge suppression rating protects connected components from the harmful effects of power surges. Dual network data line surge suppression jacks protect a wired peripheral from dangerous surges on a single 10/100Base-T or dial-up network connection. DB9 Serial Port Allows for Automatic Saves and Shutdowns This DB9 port connects the INTERNET350SER to a computer running Tripp Lite’s free downloadable PowerAlert® software to enable safe unattended file saves and system shutdown in case of a prolonged power failure. DB9 cable is included. 1/5 Package Includes ● INTERNET350SER 350VA 210W 120V Standby UPS with 6 Outlets ● DB9 serial interface cable ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Combats Electromagnetic Interference That Can Harm Equipment Various electromagnetic and radio sources found in virtually every home and business can cause disruptive interference on the AC line. Known as EMI (electromagnetic interference) and RFI (radio frequency interference), this line noise is a common cause of performance problems and can lead to incremental hardware damage, data corruption and audio/video transmission problems. The INTERNET350SER incorporates technology that filters out disruptive line noise so that it won’t affect your equipment. Home-Friendly Alarm and Diagnostic LEDs Keep You Informed 24/7 The UPS remains silent in both line and battery backup modes. The alarm sounds only to warn you of a low battery or fault condition. A front-panel green LED indicates line/battery mode status, overloads and low/replace battery alert. Compact Housing Compatible with Easy Desktop or Wall-Mount Installation The space-saving ABS housing fits on a desktop, shelf or anywhere else convenient to your workstation or home theater. Keyhole mounting tabs on the rear allow easy wall-mount installation. The five-foot power cord with NEMA 5-15P plug connects to any compatible AC outlet. Specifications OVERVIEW UPC Code 037332211002 UPS Type Standby INPUT Input Phase Single-Phase Rated input current (Maximum Load) 5A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 5A UPS Input Cord Length (ft.) 5 UPS Input Cord Length (m) 1.5 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 350 Output Capacity (kVA) 0.35 Output Capacity (Watts) 210 Output Capacity (kW) 0.21 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 50 / 60 Hz 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Voltage Regulation (Line Mode) 120V (±20%) Output Voltage Regulation (Battery Mode) 120V (±10%) UPS Output Receptacles (Surge Suppression Only) 3 UPS outlets, 3 surge-only outlets Output AC Waveform (AC Mode) Pure sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 2 min. (210W) Runtime Half Load (min.) 7 min. (105W) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) 6.5 hours (10% to 90%) Battery Access Battery access door Battery Replacement Description Replaceable internal batteries (see manual) USER INTERFACE, ALERTS & CONTROLS Switches Switch controls power off/on status Audible Alarm UPS remains silent in battery backup mode; Alarm sounds only to report low-battery, fault, overload and replacebattery conditions LED Indicators 1 Status LED reports operating mode and fault status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 316 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL or Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Desktop Installation Form Factors Supported with Included Accessories Tower; Ultra-compact desktop; Wallmount 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary UPS Depth (mm) 185 Primary UPS Height (mm) 105 Primary UPS Width (mm) 110 Shipping Dimensions (hwd / in.) 7.36 x 5.67 x 10.86 Shipping Dimensions (hwd / cm) 18.69 x 14.40 x 27.58 Shipping Weight (lbs.) 4.40 Shipping Weight (kg) 2.00 UPS Housing Material ABS UPS Power Module Dimensions (hwd, cm) 10.49 x 11.00 x 18.49 UPS Power Module Dimensions (hwd, in.) 4.13 x 4.33 x 7.28 UPS Power Module Weight (kg) 2.00 UPS Power Module Weight (lbs.) 4.4 Unit Weight (lbs.) 3.960 Unit Weight (kg) 1.80 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 113°F (-15° to 45°C ) Relative Humidity 0 to 90%, non-condensing AC Mode BTU / Hr. (Full Load) 13.1 AC Mode Efficiency Rating (100% Load) >98% Operating Elevation (ft.) Up to 10,000 ft. Operating Elevation (m) Up to 3000m COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable DB9 serial interface cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management not supported Communications Interface DB9 Serial LINE / BATTERY TRANSFER Transfer Time 6 milliseconds typical (10 milliseconds max) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Low Voltage Transfer to Battery Power (Setpoint) 95 High Voltage Transfer to Battery Power (Setpoint) 145 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); CSA (Canada); CAN/CSA-C22.2 No. 107.3 (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 3-year limited warranty Product Warranty Period (Latin America) 3-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 3-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $100,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
INTERNET350SER
- 物料型号:INTERNET350SER - 器件简介:这是一款350VA/210W的备用UPS系统,适用于保护电脑、家庭影院或数字标牌设备免受电力中断、电压波动、过电压、电涌和线路噪声的影响。 - 引脚分配:提供6个NEMA 5-15R插座,其中3个提供电池备份和电涌保护,另外3个仅提供电涌抑制。 - 参数特性: - UPS类型:备用(Standby) - 输入电压:120V AC - 输出容量:350VA/210W - 频率兼容性:50/60Hz - 电池类型:阀控铅酸(VRLA) - 电涌抑制等级:316焦耳 - 功能详解: - 在电力中断期间保持交流电源运行,以便保存文件和安全关机。 - 内置DB9串行端口,用于远程通知站点电源和UPS状态。 - 适合在短期电力中断期间操作重要设备。 - 提供足够的备份时间来安全保存文件和关闭系统。 - 应用信息:适用于销售点、酒店、赌场游戏、自助服务机、数字标牌等基于PC的专业应用,以及家庭或办公室网络系统或数字标牌组件。 - 封装信息:紧凑型桌面UPS,带有静音报警,适合桌面、架子或工作站附近的任何地方。
INTERNET350SER 价格&库存
很抱歉,暂时无法提供与“INTERNET350SER”相匹配的价格&库存,您可以联系我们找货
