SMART1500RM2U
SMART1500RM2U
    TRIPPLITE
    UPS 1.5KVA 1000W 8OUT RACK MOUNT
SMART1500RM2U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 1.5kVA 1.35kW Line-Interactive Sine Wave UPS, 2U, Network Card Options, LCD, USB, DB9, 8 Outlets MODEL NUMBER: SMART1500RM2U Highlights ● Corrects under- and overvoltages from 83V to 147V ● 8 NEMA 5-15R outlets—4 switchable via network interface ● Network power management and control capability ● Interactive LCD monitoring screen ● 13 min. runtime at half load; 4.5 min. at full load ● To use the Auto Probe feature, this product requires a WEBCARDLX network interface (sold separately) running LX firmware update 15.5.2 or later Package Includes Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts, brownouts, power surges and line noise. Ideal solution for data centers, VoIP systems and network closets. Features Protects Mission-Critical Rack-Mounted Equipment ● Provides fully regulated sine wave AC output for servers, network storage devices and telecom hardware ● Audible alarm signals loss of utility power, overload, low battery and fault conditions ● 8 NEMA 5-15R outlets ● 10-ft. (3.05 m) power cord with 120V NEMA 5-15P input ● 0.9 power factor rating ● 570-joule surge suppression rating Reliable Battery Backup ● Supports half load up to 13 min. and full load up to 4.5 min. ● Internal batteries designed for hot-swap field replacement ● 95% line-power efficiency rating saves money in energy costs 2 Load Banks with Switchable Outlets ● Can control 4 outlets remotely to reboot equipment or shed nonessential loads Automatic Voltage Regulation (AVR) ● Maintains 120V nominal output over input range of 83V-147V without using battery power EMI/RFI Line Noise Filtering ● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment's 1/6 ● SMART1500RM2U SmartPro 120V 1.5kVA 1.35kW LineInteractive Sine Wave UPS ● USB cable ● DB9 cable ● EPO cable ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States performance Interactive LCD Screen ● Front-panel LCD signals operating mode, load level, voltage, battery charge and estimated runtimes ● Rotates for easy viewing in rack-mount or tower configurations Network Management Cards ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD and RELAYIOCARD Communications Ports ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● EPO port supports emergency shutdown in large facilities Versatile Installation Options ● Hardware included for 4-post mounting in 2U of EIA-standard 19 in. rack ● Mounts on wall or 2-post rack with optional 2POSTRMKITWM accessory ● Mounts in upright tower position with optional 2-9USTAND accessory Specifications OVERVIEW UPC Code 037332119209 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 15A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 1350 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Capacity (kW) 1.35 Power Factor 0.9 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -21%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Two switchable two-outlet 5-15R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (8) 5-15R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.5 min. (1350W) Runtime Half Load (min.) 13 min. (675W) Expandable Runtime No DC System Voltage (VDC) 36 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC93-2U  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 83 and 107 are boosted by 14% USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data, plus configuration of voltage, operating mode, alarm function and a variety of additional options (see manual for detailed LCD configuration and monitoring options) Switches 3 pushbutton switches control OFF / ON power status, MODE selection and MUTE / ENTER control functions 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Alarm Cancel Operation Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option available Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to 914mm) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 43.18 Minimum Required Rack Depth (inches) 17 Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  2POSTRMKITWM  enables wall-mount and 2-post rackmount installation;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm);  UPSHDEARKIT  enables installation in 2 or 4-post racks using front vertical rails only, without rear support Primary UPS Depth (mm) 342 Primary UPS Height (mm) 88 Primary UPS Width (mm) 439 Shipping Dimensions (hwd / in.) 8.70 x 20.00 x 23.50 Shipping Dimensions (hwd / cm) 22.10 x 50.80 x 59.69 Shipping Weight (lbs.) 58.50 Shipping Weight (kg) 26.54 UPS Housing Material Steel 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Power Module Dimensions (hwd, cm) 8.76 x 43.94 x 34.16 UPS Power Module Dimensions (hwd, in.) 3.45 x 17.3 x 13.45 UPS Power Module Weight (kg) 21.09 UPS Power Module Weight (lbs.) 46.5 Unit Weight (lbs.) 46.5000 Unit Weight (kg) 21.09 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 267 Battery Mode BTU / Hr. (Full Load) 1012 AC Mode Efficiency Rating (100% Load) 95% Audible Noise 45 dBA maximum, front side 1m Operating Elevation (m) 0 TO 2000M COMMUNICATIONS Network Management Cards  WEBCARDLX ;  RELAYIOCARD  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network UPS Tools (NUT) Compatibility NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 83 High Voltage Transfer to Battery Power (Setpoint) 147 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS; Individually controllable load banks Grounding Lug Back panel grounding lug STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMART1500RM2U 价格&库存
很抱歉,暂时无法提供与“SMART1500RM2U”相匹配的价格&库存,您可以联系我们找货
