1000 Eaton Boulevard
Cleveland, OH 44122
United States
AVR Series 120V 700VA 350W Ultra-Compact
Line-Interactive UPS with USB port and Muted
Alarm
MODEL NUMBER: AVR700UXRM
Highlights
700VA ultra-compact 120V line
interactive UPS
Audible alarm is muted for fulltime silent operation
Corrects brownouts and
overvoltages from 83V to 147V
4 UPS battery supported outlets,
4 surge-only outlets
USB port, TEL/DSL protection,
Wall mountable, 98% efficient
50% longer runtime than Tripp
Lite AVR700U
NEMA 5-15P input plug and 8
NEMA 5-15R outlets
Package Includes
Description
Tripp Lite's AVR700UXRM Ultra-Compact Line Interactive UPS offers complete power protection for
desktop PCs, network workstations and a wide variety of professional and consumer electronic devices.
Uninterruptible Power Supply / UPS circuits switch to battery backup mode within milliseconds to keep
connected equipment running without interruption or data loss during power failures. Automatic Voltage
Regulation / AVR power conditioning maintains smooth, continuous operation of connected equipment
during brownouts and overvoltages. Surge-only outlets offer convenient protection for printers and other
desktop accessories not requiring battery support. AC and dataline surge suppression prevents connected
equipment damage. USB communications port supports built-in power management and auto-shutdown
features of Windows and Mac OS X or full featured monitoring and data-saving auto-shutdown options
using Tripp Lite's free PowerAlert monitoring software.
Features
AVR700UXRM ultra-compact 120V line interactive UPS offers complete AC power protection from
blackouts, brownouts and transient surges
700VA / 350 watt UPS output capacity
Audible alarm is completely muted from the factory; Alarm operation can be restored using PowerAlert
UPS management software
Uninterruptible Power Supply / UPS operation maintains battery-derived AC output during blackouts to
prevent data loss and system downtime for connected equipment
Built-in USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
HID-compliant USB port also enables integration with built-in power management and auto shutdown
Automatic Voltage Regulation / AVR corrects extended brownouts and overvoltages from 83 to 147V,
without using battery power
Large internal battery offers 50% longer runtime than Tripp Lite AVR700U
1/5
AVR700UXRM UPS System
USB cable
Instruction manual
Cleveland, OH 44122
United States
11.8 minutes runtime at 50% load (175 watts)
Up to 42 minutes runtime for a single desktop computer system consuming 60 watts continuous
8 built-in NEMA 5-15R outlets, two with extra wide spacing to accommodate transformer plugs
4 UPS battery backup outlets, plus 4 additional surge-only outlets
Right angle NEMA 5-15P input connection with 6ft / 1.8m line cord
Network grade AC surge protection is available from all outlets
Built-in data line surge suppression protects a single dialup or DSL line
Supports Tripp Lite's Watchdog system service to restore operation to locked equipment through soft
reboot of application/OS or hard power off/on reboot of connected equipment, ideal for unattended kiosk
applications
98% line mode efficiency rating uses less energy and BTU emissions
Built-in grounding lug
Hot swappable user battery replacement
Optional PDUB15 bypass PDU enable hot-swappable UPS replacement with no disruption to connected
equipment
Space saving, ultra-compact housing with support for wall-mount, desktop or floor placement
Specifications
OVERVIEW
UPC Code
037332183682
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
12A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P; Right-Angled
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
700
Output Capacity (Watts)
350
Nominal Voltage Details
115v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
+8%, -21%
Output Voltage Regulation (Battery
Mode)
+/- 5%
2/5
Cleveland, OH 44122
United States
UPS Output Receptacles (Surge
Suppression Only)
4 UPS outlets, 4 surge-only outlets
Hot-Swap PDU options
PDUB15 (2U / 8 5-15R outlets)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(8) 5-15R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Half Load (min.)
11.8 min. (175w)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
15.8 hours (10% to 90%)
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC51
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 147
Overvoltage Correction
Input voltages between 128 and 147 are reduced by 12%
Undervoltage Correction
Input voltages between 83 and 104 are boosted by 14%
USER INTERFACE, ALERTS & CONTROLS
Switches
Combination switch controls on/off power status and self-test operation
Audible Alarm
Alarm is factory muted for silent operation; Audible alarm can be restored to indicate power failure and overload
conditions using PowerAlert UPS management software
LED Indicators
2 LEDs indicate power status and overload/check battery status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
420
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out)
EMI / RFI AC Noise Suppression
Yes
3/5
Cleveland, OH 44122
United States
PHYSICAL
Primary Form Factor
Desktop
Installation Form Factors Supported
with Included Accessories
Tower; Ultra-compact desktop; Wallmount
Primary UPS Depth (mm)
152
Primary UPS Height (mm)
89
Primary UPS Width (mm)
287
Shipping Dimensions (hwd / in.)
4.60 x 13.40 x 8.60
Shipping Dimensions (hwd / cm)
11.68 x 34.04 x 21.84
Shipping Weight (lbs.)
11.80
Shipping Weight (kg)
5.35
UPS Housing Material
ABS
UPS Power Module Dimensions
(hwd, cm)
8.89 x 28.70 x 15.24
(hwd, in.)
3.5 x 11.3 x 6
UPS Power Module Weight (kg)
4.99
UPS Power Module Weight (lbs.)
11
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
30
AC Mode Efficiency Rating (100%
Load)
98%
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB interface cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Network UPS Tools (NUT)
Compatibility
NUT compatible. See the full list of Tripp Lite NUT compatible UPS systems at
https://www.networkupstools.org/stable-hcl.html?manufacturer=Tripp Lite
Communications Interface
USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
1-4 milliseconds
4/5
Cleveland, OH 44122
United States
Low Voltage Transfer to Battery
Power (Setpoint)
83
High Voltage Transfer to Battery
Power (Setpoint)
147
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Hot swappable batteries
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
Grounding Details
Included
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
3-year limited warranty
Product Warranty Period (Latin
America)
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$100,000 Ultimate Lifetime
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“AVR700UXRM”相匹配的价格&库存,您可以联系我们找货
