INTERNET600TAA
INTERNET600TAA
    TRIPPLITE
    UPS DESKTOP BATTERY BACK UP
INTERNET600TAA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States TAA-Compliant Internet Office 120V 600VA 300W Standby UPS, Ultra-Compact Desktop, USB MODEL NUMBER: INTERNET600TAA Highlights ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases ● 600VA ultra-compact 120V standby UPS ● 4 UPS battery supported outlets, 4 surge-only outlets ● USB, TEL/DSL protection, Wall mountable, 99% efficient ● NEMA 5-15P input plug and 8 NEMA 5-15R outlets ● This product is ENERGY STAR qualified for its ability to save customers money while helping to protect the environment Package Includes Description Ultra-compact standby UPS with built-in USB monitoring port protects PCs, network workstations and other systems reliant upon a USB interface for UPS monitoring and unattended system shutdown. Maintains AC output during blackouts and brownouts starting at 99V. Includes USB monitoring with cabling, TEL/DSL line surge suppression, surge-only outlets and LED indicators. PowerAlert software available free via download. Features ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases ● This product is ENERGY STAR qualified for its ability to save customers money while helping to protect the environment ● INTERNET600TAA standby UPS offers protection from blackouts, brownouts and surges on both AC and dialup modem lines ● Provides seamless battery derived AC output during blackouts and severe brownouts so that connected equipment can be shut down without data loss ● USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● HID-compliant USB also enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● 4 battery supported outlets protect computer, monitor and other vital system peripherals, plus 4 additional surge suppression-only outlets for printers and other system accessories not requiring battery support ● Attractive stealth black UPS color scheme ● Single line phone jacks with line splitter protects peripherals with a standard dialup phone line connection ● Audible alarm and front panel LEDs offer continuous status information regarding line and battery power operation ● 600VA /300 watt power handling ability supports entry-level PC systems for several minutes during power fail conditions ● Includes attached 6 ft. AC power cord, on/off power switch 1/5 ● INTERNET600TAA UPS system ● USB cable ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Compatible with 120V/60 Hz applications in USA, Canada, Mexico and other countries ● Optional PDUB15 bypass PDU enables hot-swappable UPS replacement with no disruption to connected equipment Specifications OVERVIEW UPC Code 037332184092 UPS Type Standby INPUT Input Phase Single-Phase Rated input current (Maximum Load) 10A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P; Right-Angled Input Circuit Breakers 10A UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 600 Output Capacity (Watts) 300 Nominal Voltage Details 115v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Battery Mode) +/- 5% UPS Output Receptacles (Surge Suppression Only) 4 UPS outlets, 4 surge-only outlets Hot-Swap PDU options PDUB15 (2U / 8 5-15R outlets) Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (8) 5-15R BATTERY Runtime Half Load (min.) 9.9 min. (150w) 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Expandable Runtime No DC System Voltage (VDC) 12 USER INTERFACE, ALERTS & CONTROLS Switches Combination switch controls on/off power status and self-test operation Audible Alarm Audible alarm indicates power-failure and overload status LED Indicators 2 LEDs indicate power status and overload/check battery status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 420 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out) EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Desktop Included Mounting Accessory Description Wallmount installation supported using keyhole mounting tabs Installation Form Factors Supported with Included Accessories Tower; Ultra-compact desktop Primary UPS Depth (mm) 145 Primary UPS Height (mm) 79 Primary UPS Width (mm) 274 Shipping Dimensions (hwd / in.) 4.10 x 8.00 x 13.00 Shipping Dimensions (hwd / cm) 10.41 x 20.32 x 33.02 Shipping Weight (lbs.) 7.00 Shipping Weight (kg) 3.18 UPS Housing Material ABS UPS Power Module Dimensions (hwd, cm) 7.87 x 27.43 x 14.48 UPS Power Module Dimensions (hwd, in.) 3.1 x 10.8 x 5.7 UPS Power Module Weight (kg) 2.95 UPS Power Module Weight (lbs.) 6.5 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius. Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius. 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 14 Battery Mode BTU / Hr. (Full Load) 210 AC Mode Efficiency Rating (100% Load) 99% COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in USB port, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable RJ to USB interface cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network UPS Tools (NUT) Compatibility NUT compatible. See the full list of Tripp Lite NUT compatible UPS systems at https://www.networkupstools.org/stable-hcl.html?manufacturer=Tripp Lite Communications Interface USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 99 High Voltage Transfer to Battery Power (Setpoint) 139 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS WARRANTY & SUPPORT Product Warranty Period (U.S. & Canada) 3-year limited warranty Product Warranty Period (Latin America) 3-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 3-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $100,000 Ultimate Lifetime Insurance  4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
INTERNET600TAA
### 物料型号 - 型号:INTERNET600TAA
### 器件简介 - 这是一款超紧凑型备用UPS,内置USB监控端口,可保护个人电脑、网络工作站和其他依赖USB接口进行UPS监控和无人值守系统关闭的系统。在停电和电压骤降情况下维持交流输出,从99V开始。包括USB监控和连线、电话/DSL线路浪涌保护、仅浪涌保护插座和LED指示器。可通过免费下载的PowerAlert软件进行监控。
### 引脚分配 - UPS输出插座:4个UPS电池支持插座,4个仅浪涌保护插座。
### 参数特性 - 输入电压:120V AC - 输出容量:600VA / 300W - 电池模式下的名义输出电压:115V - 频率兼容性:60Hz - 电池模式下的输出电压调节:±5% - 运行时间:全负载3.4分钟,半负载9.9分钟 - 效率:99%
### 功能详解 - 符合联邦贸易协定法案(TAA),适用于GSA计划购买。 - 通过 ENERGY STAR 认证,节省客户资金的同时保护环境。 - 提供无缝电池派生的交流输出,以便在停电和严重电压骤降期间连接的设备可以无数据丢失地关闭。 - USB端口支持使用Tripp Lite的PowerAlert软件进行数据保存的无人值守关闭。 - HID兼容USB还支持与Windows和Mac OS X的内置电源管理和自动关闭功能的集成。 - 4个电池支持插座保护计算机、显示器和其他重要系统外围设备,另外4个仅浪涌保护插座用于打印机和其他不需要电池支持的系统附件。 - 单线电话插孔和线路分离器保护具有标准拨号线连接的外围设备。 - 操作中的可听警报和前面板LED提供有关线路和电池电源的连续状态信息。 - 600VA/300瓦的功率处理能力,在电源故障条件下支持入门级PC系统数分钟。 - 包括附带的6英尺AC电源线和开关。
### 应用信息 - 适用于120V/60 Hz的美国、加拿大、墨西哥等国家的应用。
### 封装信息 - UPS类型:备用 - UPS输入连接类型:5-15P;直角 - UPS输入线长度:6英尺(1.8米) - UPS输出插座:8个5-15R插座 - 物理尺寸:274mm宽 x 145mm深 x 79mm高 - 运输尺寸:13.00英寸x8.00英寸x4.10英寸(33.02厘米x20.32厘米x10.41厘米) - 运输重量:7.00磅(3.18公斤)
INTERNET600TAA 价格&库存
很抱歉,暂时无法提供与“INTERNET600TAA”相匹配的价格&库存,您可以联系我们找货
