SMART550USBWD
SMART550USBWD
    TRIPPLITE
    UPS 550VA 300W 6OUT USB W/SOFTWR
SMART550USBWD 数据手册
SmartPro 120V 550VA 300W Line-Interactive UPS, AVR, Watchdog Software, Tower, USB, Surge-only Outlets Highlights ● 550VA tower 120V line interactive UPS with WatchDog software ● Corrects brownouts as low as 89V without using battery power ● 3 UPS battery supported outlets, 3 surge-only outlets ● USB port, TEL/DSL/ethernet protection ● NEMA 5-15P input plug and 6 NEMA 5-15R outlets MODEL NUMBER: SMART550USBWD Package Includes Description Tripp Lite's SMART550USBWD provides unattended systems (including kiosks, web/email servers, security system computers and more) with a single-purchase solution for 100% availability, including a UPS System and WatchDog Service Monitoring/Reboot Software. In addition to completely bulletproofing equipment against two common causes of downtime (blackouts and computer service lockup) SMART550USBWD models save money by providing two availability products for less than the price of a single solution. The line-interactive UPS System offers voltage regulation, surge suppression and long lasting battery support. Internal UPS circuits support systems for up to 30 minutes during power failures. Automatic Voltage Regulation (AVR) circuits regulate brownouts as low as 89 volts back to normal 120V levels without using battery power. Offers complete power protection in an attractive black tower configuration. Includes 3 battery supported outlets for computer, monitor and one vital system peripheral, plus 3 additional surge suppression-only outlets for printers and other system accessories not requiring battery support. USB port works with PowerAlert Software (included) to enable optional unattended system shutdown without data loss in the case of an extended power failure, USB cable included. Built-in single line RJ11 phone suppression jacks protect modem or other peripheral with a standard dialup/DSL phone connection. Built-in audible alarm and 4 front panel LEDs indicate line power status, battery power status, battery low/replace status and voltage boost operation. 550VA/300 watt power handling ability. Offers 4.6 minutes battery runtime with a full load of 550VA/300 watts and 14.8 minutes with a half load of 275VA/150 watts. Supports battery replacement via built-in access panel. $200,000 connected equipment insurance (USA and Canada Only). WatchDog Software (included) automatically reboots locked-up or poorly performing system service applications. Set CPU- and memory-usage thresholds and monitor service performance in one application. Together with the UPS System, WatchDog Software eliminates the #1 reason for costly service calls—the need to reboot locked systems.* WatchDog Software runs directly on your computer, 1/5 ● SMART550USBWD UPS System ● USB and telephone interconnection cables ● Tripp Lite WatchDog and PowerAlert Software on CDROM ● Instruction manual with warranty information eliminating the need for a separate hardware device. If the system fails to reboot, WatchDog Software automatically directs PowerAlert Software to reboot the computer and connected equipment by powering down and restarting the UPS System. WatchDog Software supports Windows® NT, 2000 and XP systems. *Server Technology study Features ● SMART550USBWD line interactive UPS system offers voltage regulation and battery support in addition to complete AC and dialup/DSL modem line surge suppression ● Includes Tripp Lite's WatchDog Service Monitoring/Reboot Software as well as PowerAlert, Tripp Lite's Network Power Management Software ● WatchDog Software automatically reboots locked-up or poorly performing system service applications ● Supports CPUs for up to 30 minutes during power failures ● Supports a max load of 550VA/300 watts for 4 minutes and a half load of 275VA/150 watts for 15 minutes ● Automatic Voltage Regulation (AVR) circuits correct brownouts as low as 89 volts without using battery power ● 550VA/300 watt power handling ability ● Includes 3 battery supported outlets, plus 3 additional surge suppression-only outlets, 6 foot AC line cord (all NEMA 5-15) ● USB port enables unattended shutdown without data loss during extended power failures. Includes USB cable ● Attractive black tower configuration ● Built-in RJ-style phone suppression jacks protect modem or other peripheral with a dialup or DSL line phone connection ● Built-in audible alarm and 4 front panel LEDs indicate UPS system and line power status ● Supports battery replacement via built-in access panel ● Compatible with 120V/60Hz applications for USA, Canada, Mexico and more ● $200,000 connected equipment insurance (USA and Canada Only) Specifications OVERVIEW UPC Code 037332119339 UPS Type Line-Interactive INPUT Rated input current (Maximum Load) 10A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V Input Phase Single-Phase 2/5 OUTPUT Output Volt Amp Capacity (VA) 550 Output Watt Capacity (Watts) 300 Frequency Compatibility 60 Hz Output Voltage Regulation (Battery Mode) 115V (+/- 5%) UPS Output Receptacles (Surge Suppression Only) 3 UPS outlets, 3 surge-only outlets Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 115V; 120V Output Receptacles (6) 5-15R BATTERY Full Load Runtime (min.) 4 min. (300w) Half Load Runtime (min.) 15 min. (150w) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) Less than 3.6 hours from 10% to 90% Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC51  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 89 Undervoltage Correction Input voltages between 89 and 104V are boosted by 14% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery conditions LED Indicators 4 LEDs indicate line power, battery power, overload and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 3/5 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out) EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 165 Primary UPS Height (mm) 216 Primary UPS Width (mm) 127 Shipping Dimensions (hwd / cm) 30.48 x 20.96 x 23.50 Shipping Dimensions (hwd / in.) 12.00 x 8.25 x 9.25 Shipping Weight (kg) 7.26 Shipping Weight (lbs.) 16.00 UPS Housing Material PVC UPS Power Module Dimensions (hwd, cm) 21.59 x 12.70 x 16.51 UPS Power Module Dimensions (hwd, in.) 8.5 x 5 x 6.5 UPS Power Module Weight (kg) 6.53 UPS Power Module Weight (lbs.) 14.4 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 65.1 Battery Mode BTU / Hr. (Full Load) 358.4 AC Mode Efficiency Rating (100% Load) 94% COMMUNICATIONS PowerAlert Software PowerAlert and Watchdog software included Communications Cable USB interface cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications 4/5 Communications Interface USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 89 High Voltage Transfer to Battery Power (Setpoint) 139 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries WARRANTY Product Warranty Period (U.S. & Canada) 3-year limited warranty Product Warranty Period (Latin America) 3-year limited warranty Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 3-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $200,000 Ultimate Lifetime Insurance  © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 5/5
SMART550USBWD
物料型号: - 型号编号:SMART550USBWD
器件简介: - SMART550USBWD是一款智能型UPS,提供不间断电源和电压调节功能,同时内置WatchDog服务监控/重启软件。它为无人值守系统(包括售货亭、Web/电子邮件服务器、安全系统计算机等)提供100%可用性的单次购买解决方案。
引脚分配: - 包含3个电池支持插座和3个额外的仅浪涌保护插座,以及1个RJ风格的电话抑制插孔,用于保护调制解调器或其他具有拨号/DSL电话连接的外围设备。
参数特性: - 电压调节:自动电压调节(AVR)电路可以在不使用电池的情况下将低至89伏的电压调节回正常的120伏水平。 - 功率处理能力:550VA/300瓦。 - 电池运行时间:在550VA/300瓦的满负荷下可运行4.6分钟,在275VA/150瓦的半负荷下可运行14.8分钟。
功能详解: - 提供电压调节、浪涌抑制和长时间电池支持。 - USB端口配合PowerAlert软件(内置)实现在长时间电力故障时无需数据丢失的系统自动关闭。 - 内置的单线RJ11电话抑制插孔保护具有标准拨号/DSL电话连接的调制解调器或其他外围设备。 - 内置的可听警报和4个前面板LED指示UPS系统和线路电源状态。
应用信息: - 适用于美国、加拿大、墨西哥等120V/60Hz的电气环境。 - 提供高达200,000美元的连接设备保险(仅限美国和加拿大)。
封装信息: - 主要UPS尺寸:高216mm x 宽127mm x 深165mm。 - 运输尺寸:高12.00英寸 x 宽8.25英寸 x 高9.25英寸。 - 运输重量:16.00磅(约7.26公斤)。
SMART550USBWD 价格&库存
很抱歉,暂时无法提供与“SMART550USBWD”相匹配的价格&库存,您可以联系我们找货
