1000 Eaton Boulevard
Cleveland, OH 44122
United States
TAA-Compliant SmartPro 120V 550VA 300W
Line-Interactive UPS, AVR, Tower, USB, Surgeonly Outlets
Highlights
Federal Trade Agreements Act /
TAA Compliant for GSA
Schedule purchases
550VA tower 120V line
interactive UPS
Corrects brownouts as low as
89V without using battery power
3 UPS battery supported outlets,
3 surge-only outlets
USB port, TEL/DSL/ethernet
protection
NEMA 5-15P input plug and 6
NEMA 5-15R outlets
MODEL NUMBER: SMART550USBTAA
Package Includes
Features
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
SMART550USBTAA line interactive UPS system offers voltage regulation and battery support, plus
complete AC and dialup/DSL modem line surge suppression
Supports entry level PC systems for up to 30 minutes during power failures to enable a safe system
shutdown
Supports a max load of 550VA/300 watts for 4.6 minutes and a half load of 275VA/150 watts for 14.8
minutes
Automatic Voltage Regulation (AVR) circuits correct brownouts as low as 89 volts without using battery
power
Attractive stealth black tower configuration
Includes 3 battery supported outlets, plus 3 additional surge suppression-only outlets, 6-ft. (1.83 m) AC
line cord (all NEMA 5-15)
USB port enables unattended shutdown without data loss during extended power failures, includes USB
cable
PowerAlert software available via free download from tripplite.eaton.com
Built-in RJ11 phone suppression jacks protect modem, fax machine or other peripheral with a dialup or
DSL line phone connection
Built-in audible alarm and 4 front panel LEDs indicate UPS system and line power status
550VA/300 watt power handling ability supports a variety of computer, internetworking, telecom and
consumer electronics equipment
Supports battery replacement via built-in access panel
Compatible with 120V/60Hz applications for USA, Canada, Mexico and more
$200,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
Specifications
1/5
SMART550USBTAA TAA
Compliant UPS System
USB and Telephone
interconnection cables
Instruction manual with warranty
information
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332152763
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
10A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P; Right-Angled
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
550
Output Capacity (Watts)
300
Nominal Voltage Details
115v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Battery
Mode)
+/- 5%
UPS Output Receptacles (Surge
Suppression Only)
3 UPS outlets, 3 surge-only outlets
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(6) 5-15R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
4.6 min. (300w)
Runtime Half Load (min.)
14.8 min. (150w)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
Less than 3.6 hours from 10% to 90%
2/5
Cleveland, OH 44122
United States
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC51
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 89
Undervoltage Correction
Input voltages between 89 and 104 are boosted by 14%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and low-battery conditions
LED Indicators
4 LEDs indicate line power, battery power, overload and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
480
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out)
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
Primary UPS Depth (mm)
165
Primary UPS Height (mm)
216
Primary UPS Width (mm)
127
Shipping Dimensions (hwd / in.)
12.00 x 8.25 x 9.25
Shipping Dimensions (hwd / cm)
30.48 x 20.96 x 23.50
Shipping Weight (lbs.)
16.00
Shipping Weight (kg)
7.26
UPS Housing Material
PVC
UPS Power Module Dimensions
(hwd, cm)
21.59 x 12.70 x 16.51
3/5
Cleveland, OH 44122
United States
(hwd, in.)
8.5 x 5 x 6.5
UPS Power Module Weight (kg)
6.53
UPS Power Module Weight (lbs.)
14.4
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
68
AC Economy Mode Efficiency Rating
(100% Load)
94%
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in USB port, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB interface cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Communications Interface
USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
89
High Voltage Transfer to Battery
Power (Setpoint)
139
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection
WARRANTY & SUPPORT
Product Warranty Period (U.S. &
Canada)
3-year limited warranty
Product Warranty Period (Latin
America)
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
4/5
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“SMART550USBTAA”相匹配的价格&库存,您可以联系我们找货
