POS500
POS500
    TRIPPLITE
    POS&PC'S120V6OUTLET
POS500 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States POS Series 120V 50/60Hz 500VA 300W Standby UPS, Tower, USB port, 6 Outlets, TEL/DSL Protection MODEL NUMBER: POS500 Highlights ● 500VA low-profile tower 120V standby UPS ● Maintains AC output during power failures ● 3 UPS battery supported outlets, 3 surge-only outlets ● USB port, TEL/DSL protection, 99% efficient ● NEMA 5-15P input and 6 NEMA 5-15R outlets Package Includes ● Description Tripp Lite's POS500 standby UPS system offers surge suppression and long-lasting battery support, ideal for Kiosks, Point-of-Sale, Network Workstations and standalone PC applications. Special housing with rear-facing outlets fits into limited height and width UPS compartments in kiosks and other equipment housings. Internal UPS circuits maintain AC output during power failures and severe brownout conditions so that connected equipment can be properly shut down without data loss. Includes 3 battery-supported outlets for computer, monitor and one vital system peripheral, plus 3 additional surge suppression-only outlets for printers and other system accessories not requiring battery support. USB port enables optional unattended system shutdown without data loss in case of extended power failure; cable included. HIDcompliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. PowerAlert software available via FREE download. Built-in single line phone suppression protects modem, fax machine or other peripheral with a standard dialup/DSL phone connection. Built-in audible alarm and 5 LEDs indicate line power status, battery power status, battery low/replace, overload and site wiring fault status. 500VA/300W power handling ability supports point-ofsale equipment, kiosks, network workstations, small business phone systems and desktop PC equipment. Compatible with Tripp Lite's Watchdog system service to restore operation to locked equipment through soft reboot of application/OS or hard power off/on reboot of connected equipment - ideal for unattended kiosk applications. Offers 4.9 minutes battery runtime with a full load of 500VA and 15.8 minutes with a half load of 250VA. Supports user battery replacement via built-in access panel. $150,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only). Features ● POS500 offer surge suppression and long-lasting battery support for Kiosks, Point-of-Sale, Network Workstations and standalone PC applications ● Special housing with short 6.54 inch height, thin 3.58 inch width and rear-facing outlets is compatible with UPS compartments in many kiosks and other equipment housings 1/5 POS500 UPS, USB cable, User manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Supports a full load of 500VA/300 watts for 4.9 minutes and a half load of 250VA/150 watts for 15.8 minutes ● Supplies battery-derived AC output from UPS supported outlets during brownouts, overvoltages and blackout conditions ● Includes 6 total outlets, 3 with UPS and surge suppression for vital system components and 3 with surge suppression only for accessories not requiring battery support ● Compatible with Tripp Lite's Watchdog system service to restore operation to locked equipment through soft reboot of application/OS or hard power off/on reboot of connected equipment - ideal for unattended kiosk applications ● USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Built-in single line phone suppression protects modem, fax machine or other peripheral with a standard dialup/DSL phone connection ● Built-in audible alarm and 5 LEDs indicate line power status, battery power status, battery low/replace, overload and site wiring fault status ● Optional PDUB15 bypass PDU enables hot-swappable UPS replacement with no disruption to connected equipment ● Supports hot swappable, user battery replacement via built-in access panel Specifications OVERVIEW UPC Code 037332139825 UPS Type Standby INPUT Input Phase Single-Phase Rated input current (Maximum Load) 10A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 10A UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 500 Output Capacity (Watts) 300 Nominal Voltage Details 115v nominal output in battery mode Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Automatic frequency selection 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Voltage Regulation (Battery Mode) +/- 5% UPS Output Receptacles (Surge Suppression Only) 3 UPS outlets, 3 surge-only outlets Hot-Swap PDU options PDUB15 (2U / 8 5-15R outlets) Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks No BATTERY Runtime Full Load (min.) 4.9 min. (300w) Runtime Half Load (min.) 15.8 min. (150w) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) Less than 10 hours from 10% to 90% Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC51  Battery Replacement Description Hot-swappable, user replaceable batteries USER INTERFACE, ALERTS & CONTROLS Switches Combination switch controls on/off power status and self-test operation Audible Alarm Audible alarm indicates power-failure LED Indicators 4 LEDs (online, on battery, replace battery, overload) Site Wiring Fault Indication Rear panel site wiring fault LED SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out) EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 284 Primary UPS Height (mm) 165 Primary UPS Width (mm) 91 Shipping Dimensions (hwd / in.) 9.30 x 7.00 x 14.10 Shipping Dimensions (hwd / cm) 23.62 x 17.78 x 35.81 Shipping Weight (lbs.) 9.50 Shipping Weight (kg) 4.31 UPS Housing Material ABS UPS Power Module Dimensions (hwd, cm) 16.51 x 9.14 x 28.45 UPS Power Module Dimensions (hwd, in.) 6.5 x 3.6 x 11.2 UPS Power Module Weight (kg) 3.67 UPS Power Module Weight (lbs.) 8.1 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 10 AC Mode Efficiency Rating (100% Load) 99% COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in USB port, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB interface cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network UPS Tools (NUT) Compatibility NUT compatible. See the full list of Tripp Lite NUT compatible UPS systems at https://www.networkupstools.org/stable-hcl.html?manufacturer=Tripp Lite Communications Interface USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 4 milliseconds from AC to battery mode; 4 milliseconds from battery to AC mode Low Voltage Transfer to Battery Power (Setpoint) 93 High Voltage Transfer to Battery Power (Setpoint) 139 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $150,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
POS500
### 物料型号 - 型号:POS500
### 器件简介 - 简介:Tripp Lite的POS500是一款备用式UPS系统,提供浪涌保护和持久的电池支持,适合用于Kiosks、销售点、网络工作站和独立PC应用。特别的外壳设计,后部接口,适合有限高度和宽度的UPS隔间。
### 引脚分配 - 接口:NEMA 5-15P输入和6个NEMA 5-15R接口。
### 参数特性 - 输入: - 输入相位:单相 - 额定输入电流(最大负载):10A - 支持的额定输入电压:120V AC - 输入电路断路器:10A - UPS输入线长度:1.8米 - 输出: - 输出容量(VA):500 - 输出容量(Watts):300 - 频率兼容性:50/60Hz,自动频率选择 - 电池模式下输出电压调节:±5% - 电池: - 满负载运行时间:4.9分钟(300W) - 半负载运行时间:15.8分钟(150W) - 直流系统电压:12V - 电池充电率:从10%到90%少于10小时
### 功能详解 - 功能: - 在电力故障和严重低电压条件下维持交流输出。 - 3个电池支持插座和3个额外的仅浪涌保护插座。 - USB端口允许在长时间电力故障时进行数据保护的无人值守关闭。 - 内置单线电话抑制,保护调制解调器、传真机或其他设备。 - 内置声音报警和5个LED指示灯显示电源状态。
### 应用信息 - 应用:适用于销售点设备、Kiosks、网络工作站、小型企业电话系统和桌面PC设备。
### 封装信息 - 物理尺寸: - 高度:165毫米 - 宽度:91毫米 - 深度:284毫米 - 重量: - 发货重量:9.50磅(4.31公斤) - 材料:ABS
POS500 价格&库存
很抱歉,暂时无法提供与“POS500”相匹配的价格&库存,您可以联系我们找货
