1000 Eaton Boulevard
Cleveland, OH 44122
United States
550VA Audio/Video Backup Power Block Exclusive UPS Protection for Structured Wiring
Enclosure
MODEL NUMBER: AV550SC
Highlights
4 AC outlets (including 1 delayon outlet for router)
Automatic recycle/reset button;
Auto-restart capability
Regulated 12V DC output for 4
devices; Complete surge
suppression
Convenient installation fits
structured wiring enclosures
without using mounting screws
or brackets
HD-compatible 2.2GHz coaxial
and telephone/modem/DSL line
surge protection; 550VA UPS
capacity
Package Includes
Description
The AV550SC Backup Power Block provides the highest level of protection for structured cabling
installations (ie. telephone, Internet and coax connections). With reliable battery backup, surge protection
and EMI/RFI line noise filtering, the AV550SC provides a complete protection solution for audio/video
distribution systems by supporting modems, routers, RF amplifiers, network interfaces, cameras,
modulators and other equipment through all power problems. In the event of a power failure, the
AV550SC includes an auto-restart feature that eliminates the need to perform an on-site restart. In
addition, when a modem or router freeze-up occurs, the AV550SC features a recycle/reset button with
sequential outlet startup for proper modem and router rebooting.
Features
3 widely-spaced AC outlets (2 Auxiliary, 1 Modem) power, reset or start up connected equipment during
a blackout or system freeze-up (provide battery backup, surge protection and EMI/RFI filtering) - 4
outlets total
Convenient installation designed to fit in the bottom left corner of structured wiring enclosures without
the need for mounting screws or brackets
60-second delay-on AC outlet (router) powers and resets the router during a blackout or system freezeup and delays router start-up for proper system rebooting (provides battery backup, surge protection
12V DC (1-Amp) output connector provides an additional output power source for 12V DC devices as
well as battery backup protection for 4 devices
Recycle/reset button resets connected equipment during system freeze-ups with sequential outlet
startup
HD-compatible 2.2GHz coax jacks protect connected coax lines against surge damage and filter
disruptive EMI/RFI line noise.
Tel/modem/DSL jacks protect connected telephone,modem or DSL lines against surge damage and
filter disruptive EMI/RFI line noise
IEC power input connector accepts included 6-inch power cord
Diagnostic/Overload LEDs: Alert users to potential power problems before they affect connected
equipment.
Resettable circuit breaker prevents dangerous system overloads
1/5
AV550SC backup power block
Detachable 6 in. NEMA 5-15P
power cord
Owner's manual with warranty
information
Cleveland, OH 44122
United States
Auto-restart capability eliminates the need to perform an on-site restart
550VA/300 watts standby UPS system
Mounting screw holes are included on the back of the unit for convenient board, wall or ceiling mounting
(for projectors)
Customizable labels for easier cord/cable indentification and maintenance
Specifications
OVERVIEW
UPC Code
037332138699
UPS Type
Standby
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
10A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P; C14 inlet
UPS Input Connection Description
5-15P input cable is detachable via C14 inlet on UPS
Input Circuit Breakers
10A
UPS Input Cord Length (ft.)
0.5
UPS Input Cord Length (m)
0.2
Recommended Electrical Service
15A 120V
Right-Angle Plug
No
OUTPUT
Output Capacity (VA)
550
Output Capacity (kVA)
0.55
Output Capacity (Watts)
300
Output Capacity (kW)
0.3
Output Capacity Details
4.6A @ 120V
Nominal Voltage Details
115v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Battery
Mode)
+/- 5%
Output Receptacle Details
One receptacle has a 60 second power-up delay
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
2/5
Cleveland, OH 44122
United States
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(4) 5-15R
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
3.1 min. (300W)
Runtime Half Load (min.)
9.7 min. (150W)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
1.5A Maximum; Less than 3 hours from 10% to 90%
VOLTAGE REGULATION
Voltage Regulation Description
Input voltage range of 99 to 139
USER INTERFACE, ALERTS & CONTROLS
Switches
Includes 1 on/off push button (also acts as recycle/reset button)
LED Indicators
2 LEDs indicate power status and overload/low battery status
SURGE / NOISE SUPPRESSION
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); Coax jacks (1 set)
UPS Dataline Suppression Details
HD-compatible 2.2GHz coaxial protection
EMI / RFI AC Noise Suppression
Yes
AC Suppression Joule Rating
1038
DATALINE SURGE SUPPRESSION
Cable (Coax) Protection
Yes
Network (Ethernet) Protection
No
Telephone/DSL Protection
Yes
PHYSICAL
Primary Form Factor
Desktop
Installation Form Factors Supported
with Included Accessories
Wallmount
Primary UPS Depth (mm)
76
Primary UPS Height (mm)
211
Primary UPS Width (mm)
173
3/5
Cleveland, OH 44122
United States
Shipping Dimensions (hwd / in.)
4.60 x 8.50 x 10.00
Shipping Dimensions (hwd / cm)
11.68 x 21.59 x 25.40
Shipping Weight (lbs.)
8.80
Shipping Weight (kg)
3.99
UPS Housing Material
Sheet metal
UPS Power Module Dimensions
(hwd, cm)
21.08 x 17.27 x 7.62
(hwd, in.)
8.3 x 6.8 x 3.0
UPS Power Module Weight (kg)
3.54
UPS Power Module Weight (lbs.)
7.8
Unit Weight (lbs.)
7.800
Unit Weight (kg)
3.54
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
31
AC Mode Efficiency Rating (100%
Load)
97%
Operating Elevation (ft.)
6561 ft. (2000 m) above sea level
COMMUNICATIONS
Network Management Card
Description
Network management not supported
Communications Interface
None
LINE / BATTERY TRANSFER
Transfer Time
4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
99V
High Voltage Transfer to Battery
Power (Setpoint)
139V
FEATURES & SPECIFICATIONS
High Availability UPS Features
Surge/noise protection
Green Energy-Saving Features
High efficiency economy mode operation; Greater than 95% efficiency - GREEN UPS
STANDARDS & COMPLIANCE
4/5
Cleveland, OH 44122
United States
Product Certifications
CSA (Canada); CAN/CSA-C22.2 No. 107.3 (Canada); NOM (Mexico); UL 1778
Product Compliance
FCC Part 68; RoHS; FCC Part 15 Class B (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“AV550SC”相匹配的价格&库存,您可以联系我们找货
