1000 Eaton Boulevard
Cleveland, OH 44122
United States
OmniSmart 120V 500VA 300W Line-Interactive
UPS, Tower, Built-In Isolation Transformer, USB
port
Highlights
500VA tower 120V line
interactive UPS with isolation
transformer
Corrects brownouts as low as
83V without using battery power
USB port, Normal & common
mode EMI/RFI line noise
immunity
NEMA 5-15P input plug and 3 515R outlets
MODEL NUMBER: OMNI500ISO
Package Includes
Description
Tripp Lite's OMNI500ISO offers complete UPS protection with built-in line-interactive voltage regulation,
intelligent monitoring and unattended shutdown capability. Built-in isolation transformer with faraday shield
offers full isolation and complete common mode noise rejection. 500VA power handling capacity supports
point-of-sale applications, computers, internetworking equipment and home theater systems during
commercial power failures. Line-interactive voltage regulation corrects brownouts as low as 83V back to
normal 120V levels, saving battery reserves for use only during complete power failures. Built-in USB
communications port works with PowerAlert Software and cabling to provide automatic unattended
shutdown of connected network and PC applications.
Features
500VA line-interactive UPS with faraday-shielded, low-impedance isolation transformer delivers full
isolation from potential damage and performance problems
Provides immunity from EMI/RFI line noise in both normal and common modes. Delivers clean signalreference ground, reducing data errors and audio/video distortion
Automatic voltage regulation (AVR) automatically corrects incoming voltage to keep equipment working
through low voltage (brownouts) as low as 83V, without draining battery power
Supports loads up to 500VA/300W
5.4 min. full-load runtime (300W); 11 min. half load runtime (150W)
Electrostatic discharge (ESD) resistance reduces potential static damage to connected electronics
USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software,
available via FREE download from tripplite.eaton.com/products/power-alert
Built-in surge suppression (backed by $200,000 Ultimate Lifetime Insurance U.S., Canada, and Puerto
Rico only) safeguards connected equipment against damage
SURGE VOLTAGE WITHSTAND CAPABILITY: ANSI/IEEE C62.41 Categories A & B 6KV/200/500 amp
100Khz Ringwave and category B BiWave.
SURGE VOLTAGE ATTENUATION: N-G 2000:1, L-G 240:1, L-N 100:1.
INSERTION LOSS: 65 db N-G from 10Khz to 100Khz, 45 to 60 db L-G from 10Khz to 100Khz, 18 to 54
db L-N from 50Khz to 500 Khz.
3 protected outlets; 6-ft. cord
1/5
OMNI500ISO UPS system
USB cable
Instruction manual
Cleveland, OH 44122
United States
4 diagnostic LEDs indicate AC present, on battery, overload and battery low/replace
Optional PDUB15 bypass PDU enables hot-swappable UPS replacement with no disruption to
connected equipment
Specifications
OVERVIEW
UPC Code
037332125125
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
4.8A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P; Right-Angled
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
500
Output Capacity (kVA)
0.5
Output Capacity (Watts)
300
Output Capacity (kW)
0.3
Power Factor
0.6
Nominal Voltage Details
115v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
-18%, +8%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Hot-Swap PDU options
PDUB15 (2U / 8 5-15R outlets)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(3) 5-15R
Individually Controllable Load Banks
No
2/5
Cleveland, OH 44122
United States
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
5.4 min. (300W)
Runtime Half Load (min.)
11 min. (150W)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
Less than 4.5 hours from 10% to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC51
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 83
Undervoltage Correction
Input voltages between 83 and 107 are boosted by 14%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and low-battery conditions
LED Indicators
4 LEDs indicate line power, battery power, overload and battery low/replace status
ISOLATION
Output Isolation Transformer
Professional grade load isolation transformer
Surge Voltage Withstand Capability
ANSI/IEEE C62.41 Categories A & B 6KV/200/500 amp 100Khz Ringwave and category B BiWave
Surge Voltage Attenuation
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
680
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower
3/5
Cleveland, OH 44122
United States
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
Primary UPS Depth (mm)
191
Primary UPS Height (mm)
274
Primary UPS Width (mm)
132
Shipping Dimensions (hwd / in.)
14.20 x 10.00 x 8.10
Shipping Dimensions (hwd / cm)
36.07 x 25.40 x 20.57
Shipping Weight (lbs.)
22.30
Shipping Weight (kg)
10.12
UPS Housing Material
PVC
UPS Power Module Dimensions
(hwd, cm)
27.43 x 13.21 x 19.05
(hwd, in.)
10.8 x 5.2 x 7.5
UPS Power Module Weight (kg)
9.89
UPS Power Module Weight (lbs.)
21.8
Unit Weight (lbs.)
21.8000
Unit Weight (kg)
9.89
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode Efficiency Rating (100%
Load)
91%
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in USB port, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB cable included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Insertion Loss
65 db N-G from 10Khz to 100Khz, 45 to 60 db L-G from 10Khz to 100Khz, 18 to 54 db L-N from 50Khz to 500 Khz
Network Management Card
Description
Network management not supported
Communications Interface
USB
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
83
4/5
Cleveland, OH 44122
United States
High Voltage Transfer to Battery
Power (Setpoint)
147
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Hot swappable batteries; Surge/noise protection
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); UL 1778
Product Compliance
RoHS; FCC Part 15 Class B (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“OMNI500ISO”相匹配的价格&库存,您可以联系我们找货
