TE600
TE600
    TRIPPLITE
    UPS 600VA 425W 6OUT TOWER
TE600 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States TE Series 120V 600VA 425W Line-Interactive UPS, AVR, Tower, DB9 Serial port MODEL NUMBER: TE600 Highlights ● 6 outlets (3 UPS/surge, 3 surgeonly) ● Automatic Voltage Regulation (AVR) corrects brownouts and overvoltages ● Larger scale battery produces significantly longer runtimes ● Serial port works with software to facilitate unattended shutdown Package Includes Description Tripp Lite's TE600 UPS System provides line-interactive voltage regulation and long lasting battery support for small business telephone systems, voicemail systems, personal computers and other communications, network and telecom applications. 600VA power handling capacity and large capacity battery system maintains continuous operation through power interruptions with over 1 hour runtime for many phone systems. Line interactive voltage regulation maintains normal 120 volt output levels during brownouts as low as 75 and overvoltages as high as 147, saving battery reserves for use only during complete power failures. Unique design features 6 protected outlets (3 UPS supported & 3 surgesuppression only), diagnostic LEDs and a built-in serial port that works with PowerAlert Software and cabling to provide automatic unattended shutdown of network and PC applications (part# 75-0195). $200,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only). Features ● Provides connected equipment with continuous power during short and long duration loss of commercial power ● Line-interactive voltage regulation corrects brownouts and overvoltages from 75 to 147 volts back to usable 120V output levels, without using battery power ● Supports loads up to 600VA/425 watts ● 22 minutes half load runtime (300VA/210 watts), 7 minutes full load runtime (600VA/425 watts) ● 6 protected outlets total (3 UPS Supported & 3 surge-suppression only); 6-ft. cord ● DB9 serial network interface ● Complete surge protection and EMI/RFI noise filtering ● $200,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) ● 4 diagnostic LEDs indicate AC present, on battery, voltage correction & battery low/replace ● Battery replacement door 1/4 ● TE600 UPS System ● Warranty information ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332098573 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 600 Output Capacity (Watts) 425 Power Factor 0.71 Nominal Voltage Details 115v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) 115V (+/- 5%) UPS Output Receptacles (Surge Suppression Only) 3 UPS outlets, 3 surge-only outlets Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks No BATTERY Runtime Full Load (min.) 9 min. (425w) Runtime Half Load (min.) 22 min. (212.5w) Expandable Runtime No 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 90% Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC52  (quantity 2) VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 93 and 107 are boosted by 14% Severe Undervoltage Correction Input voltages between 75 and 92 are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery conditions LED Indicators 4 LEDs indicate line power, battery power, overload and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 191 Primary UPS Height (mm) 274 Primary UPS Width (mm) 132 Shipping Dimensions (hwd / in.) 14.00 x 8.10 x 10.20 Shipping Dimensions (hwd / cm) 35.56 x 20.57 x 25.91 Shipping Weight (lbs.) 24.60 Shipping Weight (kg) 11.16 UPS Housing Material Vinyl 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Power Module Dimensions (hwd, cm) 27.43 x 13.21 x 19.05 UPS Power Module Dimensions (hwd, in.) 10.8 x 5.2 x 7.5 UPS Power Module Weight (kg) 8.62 UPS Power Module Weight (lbs.) 19 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode Efficiency Rating (100% Load) 94% COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Interface DB9 Serial LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 75 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $200,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
TE600 价格&库存
很抱歉,暂时无法提供与“TE600”相匹配的价格&库存,您可以联系我们找货
