1000 Eaton Boulevard
Cleveland, OH 44122
United States
TAA-Compliant SmartPro 120V 500VA 300W
Line-Interactive UPS, 1U Rack/Vertical, Network
Card Options, USB, DB9 Serial
Highlights
Federal Trade Agreements Act /
TAA compliant for GSA
schedule purchases
500VA line-interactive 1U
rack/vertical UPS
120V nominal output during
brownouts as low as 90V
USB, RS232, EPO and slot for
Network Management Card
options
Front panel status LEDs; 1
switched output load bank
NEMA 5-15P input; 7 NEMA 515R outlets
To use the Auto Probe feature,
this product requires a
WEBCARDLX network interface
(sold separately) running LX
firmware update 15.5.2 or later
MODEL NUMBER: SMART500RT1UTAA
Package Includes
Description
Tripp Lite's SMART500RT1UTAA intelligent, line-interactive rack/vertical uninterruptible power supply
prevents data loss, downtime and equipment damage due to power outages, voltage fluctuations and
transient surges. Requires only one rack space (1U) in a 2 or 4 post rack. Large internal batteries offer
14.6 minutes half load runtime and 3.2 minutes at full load. Maintains regulated 120V nominal output
without using battery power during brownouts as low as 90V. 500VA/300 watt power handling capability is
compatible with networking, telecom and other sensitive electronic applications. Includes 6 UPS
supported outlets with a single outlet load bank that can be individually controlled via software interface to
reboot select equipment on demand or shed less significant loads to extend battery runtime for more
critical equipment. Includes 1 surge-only outlet for peripherals not requiring battery backup.
Supports simultaneous remote monitoring of UPS and site power conditions via built-in USB and DB9
monitoring ports. PowerAlert UPS monitoring and unattended shutdown software is available via free
download. Emergency Power Off (EPO) interface offers option for instantaneous power-off of UPS and
connected equipment in the case of fire or emergency. Multi-function audible alarms and set of 5 front
panel LEDs offer at-a-glance notification of UPS and line power status. Network-grade AC surge
suppression protects equipment from damage and performance problems resulting from transient surges
and line noise. Attractive all-black color scheme.
Features
Federal Trade Agreements Act / TAA compliant for GSA schedule purchases
Tripp Lite SMART500RT1UTAA .5 kVA / 500VA / 300 watt line interactive UPS
1U rack / vertical compatible form factor
NEMA 5-15P input connection; 7 NEMA 5-15R output receptacles
Installed depth of only 11.8 in / 29.8 cm
Large internal batteries offer runtimes of 14.6 minutes at half load (250VA/150 watts) and 3.2 minutes at
full load (500VA/300 watts)
Maintains regulated 120V nominal output during brownouts as low as 90V
Includes 6 UPS-supported outlets and 1 surge-only outlet
One of the UPS supported outlets is switched for remote load shedding or rebooting of an individual
device
USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
1/6
SMART500RT1UTAA UPS
System
Mounting hardware
Cabling for USB & DB9
monitoring and EPO switching
Instruction manual
Cleveland, OH 44122
United States
software, available via FREE download from tripplite.eaton.com/products/power-alert
Supports detailed monitoring of equipment load levels,self-test data, and utility power condition via builtin RS-232 and USB interfaces
Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX and
SNMPWEBCARD
Supports Tripp Lite's WatchDog software application to restore operation to locked equipment through
soft reboot of application, OS or hard power off/on reboot of connected equipment - ideal for unattended
kiosk applications (requires optional WATCHDOGSW)
Emergency Power Off (EPO) interface with cable
Multi-function audible alarms and set of 5 front panel LEDs
Network-grade AC surge suppression
Field-replaceable, hot-swappable internal UPS batteries
Specifications
OVERVIEW
UPC Code
037332204134
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
5.6A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P
Input Circuit Breakers
15A
UPS Input Cord Length (ft.)
10
UPS Input Cord Length (m)
3.1
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
500
Output Capacity (kVA)
0.5
Output Capacity (Watts)
300
Output Capacity (kW)
0.3
Nominal Voltage Details
120v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
-15%, +13%
Output Voltage Regulation (Battery
Mode)
+/- 5%
2/6
Cleveland, OH 44122
United States
UPS Output Receptacles (Surge
Suppression Only)
6 UPS outlets, 1 surge-only outlet
Load Management Receptacles
One switchable single-outlet 5-15R load bank
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(6) 5-15R
Individually Controllable Load Banks
Yes
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
3.2 min. (300W)
Runtime Half Load (min.)
14.6 min. (150W)
Expandable Runtime
No
DC System Voltage (VDC)
12
Battery Recharge Rate (Included
Batteries)
Less than 4 hours from 10% to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC62-1U
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with input voltage as low as 90
Undervoltage Correction
Input voltages between 90 and 108 are boosted by 14%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure, overload and low-battery conditions
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
567
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out)
EMI / RFI AC Noise Suppression
Yes
567
3/6
Cleveland, OH 44122
United States
AC Suppression Response Time
Instantaneous
PHYSICAL
Primary Form Factor
Rackmount; Vertical
Rack Height
1U
Included Mounting Accessory
Description
Included mounting brackets provide front-rail installation in 2 or 4 post racks
Installation Form Factors Supported
with Included Accessories
2 post 19 inch rackmount; 2 post front mount; 4 post 19 inch rackmount
with Optional Accessories
Vertical Mount Enclosures ( SRWF5U36 , SRWF5U , SRWF10UMOD )
Minimum Required Rack Depth (cm)
38.10
(inches)
15
Primary UPS Depth (mm)
286
Primary UPS Height (mm)
44
Primary UPS Width (mm)
440
Shipping Dimensions (hwd / in.)
15.40 x 4.80 x 22.10
Shipping Dimensions (hwd / cm)
39.12 x 12.19 x 56.13
Shipping Weight (lbs.)
20.90
Shipping Weight (kg)
9.48
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
4.39 x 43.99 x 28.60
(hwd, in.)
1.73 x 17.32 x 11.26
UPS Power Module Weight (kg)
7.98
UPS Power Module Weight (lbs.)
17.6
Unit Weight (lbs.)
17.6000
Unit Weight (kg)
7.98
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
44
AC Mode Efficiency Rating (100%
Load)
96%
4/6
Cleveland, OH 44122
United States
Audible Noise
45 dBA maximum, front side 1m
COMMUNICATIONS
Network Management Cards
SNMPWEBCARD; TLNETCARD ; WEBCARDLX
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Network UPS Tools (NUT)
Compatibility
NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite
Description
Network management card optional
Communications Interface
DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
90
High Voltage Transfer to Battery
Power (Setpoint)
136
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable
batteries; Remote management; Surge/noise protection
Grounding Lug
Back panel grounding lug
STANDARDS & COMPLIANCE
Product Certifications
CSA (Canada); NOM (Mexico); UL 1778
Product Compliance
RoHS; FCC Part 15 Class B (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
$250,000 Ultimate Lifetime
Insurance
5/6
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
很抱歉,暂时无法提供与“SMART500RT1UTAA”相匹配的价格&库存,您可以联系我们找货
