SMART750
SMART750
    TRIPPLITE
    UPSSMARTTOWERAVR120V
SMART750 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 750VA 450W Line Interactive UPS, Tower, USB MODEL NUMBER: SMART750 Highlights ● 750VA line interactive tower UPS system ● 120V nominal output during brownouts to 75V and overvoltages to 147V ● Front panel status LEDs with load and battery capacity level display ● USB communications port; Hotswappable batteries ● NEMA 5-15P input; 6 NEMA 515R outlets Package Includes Description Tripp Lite's SMART750 intelligent, line-interactive UPS system protects servers, networking accessories and telecommunications equipment from blackouts, voltage fluctuations and transient surges. Large internal batteries offer 16.2 minutes half load runtime and 5.6 minutes at full load during power failures. 750VA/450 watt power handling capability supports a variety of networking, telecom and various other application types, including the support of multiple network workstations. Includes a total of 6 UPS supported outlets. Supports remote monitoring of UPS and site power conditions via built-in USB monitoring port. PowerAlert UPS monitoring and unattended shutdown is available via free download. Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery low/replace, voltage regulation and load level. Wall mountable with UPSWM wallmount bracket. Networkgrade AC surge suppression protects equipment from damage and performance problems resulting from transient surges. Features ● 750VA/450 watt power handling capability supports a variety of networking, telecom and various other application types ● Built-in voltage regulation and battery support, plus complete AC line surge suppression prevents equipment damage, data loss and downtime ● Large internal batteries offer 16.2 minutes half load runtime and 5.6 minutes at full load during power failures ● Intelligent battery management system extends battery life ● Automatic Voltage Regulation (AVR) circuits with two boost and one voltage reduction level maintains usable 120V nominal output over an input voltage range of 75-147V ● Includes a total of 6 NEMA5-15R outlets ● Includes USB communications port for remote monitoring of UPS status and site power conditions ● Communications port enables safe unattended shutdown without data loss during extended power failures ● Communications port supports messaging of UPS and line power status, including on-battery, low1/5 ● SMART750 UPS System ● USB cable ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States battery, power-restored, AC line voltage, DC battery voltage and battery capacity ● Communications port supports timed inverter shutoff after unattended shutdown, activate self-test and 10-second reboot of connected equipment ● USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Battery replacement door allows on-site hot-swap battery replacement ● Supports Tripp Lite's WatchDog software application to restore unresponsive programs by automatically restarting them and rebooting completely locked computers by automatically switching UPS power off and back on again ● Notification of system status via 5 LEDs and multi-function audible alarms ● Wall mountable with UPSWM wallmount bracket ● Cold start capability enables UPS turn-on in battery mode during blackout conditions Specifications OVERVIEW UPC Code 037332139610 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 4.4A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 750 Output Capacity (Watts) 450 Nominal Voltage Details 115v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks No BATTERY Runtime Full Load (min.) 5.6 min. (450w) Runtime Half Load (min.) 16.2 min. (225w) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 90% (typical, full load discharge) Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC52  (quantity 2) Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75V to 147V Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 93 and 107 are boosted by 14% Severe Undervoltage Correction Input voltages between 75 and 92 are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 510 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary UPS Depth (mm) 191 Primary UPS Height (mm) 300 Primary UPS Width (mm) 183 Shipping Dimensions (hwd / in.) 15.30 x 10.70 x 10.60 Shipping Dimensions (hwd / cm) 38.86 x 27.18 x 26.92 Shipping Weight (lbs.) 23.80 Shipping Weight (kg) 10.80 UPS Housing Material PVC UPS Power Module Dimensions (hwd, cm) 29.97 x 18.29 x 19.05 UPS Power Module Dimensions (hwd, in.) 11.8 x 7.2 x 7.5 UPS Power Module Weight (kg) 10.43 UPS Power Module Weight (lbs.) 23 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 134 Battery Mode BTU / Hr. (Full Load) 568 AC Mode Efficiency Rating (100% Load) 92% COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in USB port, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Communications Interface USB LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 75 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SMART750
物料型号: - 型号编号:SMART750
器件简介: - SMART750是一款智能型在线互动式UPS系统,由Tripp Lite生产,旨在保护服务器、网络配件和电信设备免受停电、电压波动和瞬时浪涌的影响。该设备拥有大型内部电池,在停电期间可提供半负载16.2分钟和全负载5.6分钟的运行时间。
引脚分配: - 输入:NEMA 5-15P接口 - 输出:共有6个NEMA 5-15R插座
参数特性: - 额定输入电流(最大负载):4.4A - 支持的额定输入电压:120V AC - 输出容量(VA):750 - 输出容量(Watts):450 - 电池模式下的名义输出电压:115V - 频率兼容性:60 Hz - 线模式下的输出电压调节:-18%,+8% - 电池模式下的输出电压调节:±5% - 电池运行时间(全负载):5.6分钟(450W) - 电池运行时间(半负载):16.2分钟(225W)
功能详解: - SMART750具备750VA/450W的功率处理能力,支持多种网络、电信和其他应用类型。 - 内置电压调节和电池支持,以及完整的交流线路浪涌抑制,可防止设备损坏、数据丢失和停机。 - 智能电池管理系统延长电池寿命。 - 自动电压调节(AVR)电路在75-147V的输入电压范围内维持120V的名义输出。 - 包括USB通讯端口,用于远程监控UPS状态和现场电力条件。 - 通讯端口支持在长时间电力故障期间安全地无数据丢失地关闭。 - 通讯端口支持UPS和线路电力状态的消息传递。
应用信息: - SMART750适用于大型网络和高端桌面/小型网络环境。
封装信息: - 主要形态因素:塔式 - 安装形态因素支持:壁挂式(使用UPSWM壁挂支架) - 主要UPS尺寸:高300mm x 宽183mm x 深191mm
SMART750 价格&库存
很抱歉,暂时无法提供与“SMART750”相匹配的价格&库存,您可以联系我们找货
