MODBUSCARD
MODBUSCARD
    TRIPPLITE
    UPS PC COMMUNICATION VIA MODBUS
MODBUSCARD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States MODBUS Management Accessory Card for UPS Remote Monitoring and Control MODEL NUMBER: MODBUSCARD Highlights ● Internal MODBUS management accessory card ● Simple installation and setup ● Implements MODBUS RTU protocol ● Provides RS-422/485 and RS232 interfaces Package Includes Description Tripp Lite's MODBUSCARD provides UPS systems with the functionality of communication with PCs via MODBUS. Implements MODBUS RTU protocol. Provides MODBUS functions including Read Coils, Discrete Inputs, Holding Registers, Input Registers, Write Single Coil and Single Register. Provides RS422/485 and RS-232 interfaces (PC communicates with UPS via RS-422/485 or RS-232 or both at the same time). Three sets of 8 dipswitches support Card ID, RS-232 and RS-422/485 configurations. Includes RS-422/485 and RS-232 communications ports. See manual for detailed setup instructions and full set of functions and configuration options. Compatible with select SmartOnline UPS models only (The MODBUSCARD should be listed within the "UPS Accessories" or "Power Management & Hardware" sections of the compatible UPS product webpage). Features ● Tripp Lite's MODBUSCARD provides UPS systems with the functionality of communication with PCs via MODBUS. ● Implements MODBUS RTU protocol. ● Provides MODBUS functions including Read Coils, Discrete Inputs, Holding Registers, Input Registers, Write Single Coil and Single Register. ● Provides RS-422/485 and RS-232 interfaces (PC communicates with UPS via RS-422/485 or RS-232 or both at the same time). ● Three sets of 8 dipswitches support Card ID, RS-232 and RS-422/485 configurations. Includes RS422/485 and RS-232 communications ports. See manual for detailed setup instructions and full set of functions and configuration options. ● Compatible with select SmartOnline UPS models only (The MODBUSCARD should be listed within the "UPS Accessories" or "Power Management & Hardware" sections of the compatible UPS product webpage). Specifications OVERVIEW UPC Code 037332157065 1/2 ● MODBUSCARD ● Installation Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Shipping Dimensions (hwd / in.) 1.60 x 6.00 x 6.00 Shipping Dimensions (hwd / cm) 4.06 x 15.24 x 15.24 Shipping Weight (lbs.) 0.55 Shipping Weight (kg) 0.25 Unit Dimensions (hwd / in.) 0.600 x 2.350 x 5.280 Unit Dimensions (hwd / cm) 1.5 x 6.1 x 13.5 Unit Weight (lbs.) 0.11 Unit Weight (kg) 0.05 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
MODBUSCARD 价格&库存
很抱歉,暂时无法提供与“MODBUSCARD”相匹配的价格&库存,您可以联系我们找货
