1000 Eaton Boulevard
Cleveland, OH 44122
United States
120V 1500VA 900W A/V Digital Line-Interactive
UPS with LCD Display, Tel/DSL/Coax/Ethernet
Protection
Highlights
LCD status screen with built-in
LCD dimmer
Automatic voltage regulation
protects A/V components from
power fluctuations
EMI/RFI line noise filtering
8 widely-spaced UPS-supported
outlets, DB9 serial and USB
ports with HID protocol
3-line 2.2 GHz coaxial surge
protection plus single-line
tel/DSL or Ethernet surge
protection
MODEL NUMBER: HTRL15UPS
Package Includes
Description
Tripp Lite's HTRL15UPS Line-Interactive Digital UPS System offers voltage regulation, surge suppression
and long-lasting battery support for home theater/media center components and other sensitive electronic
equipment, including PVRs/DVRs, media center PCs/servers, home automation/control systems and
security equipment. Internal UPS circuits support entry-level PCs or individual VCR/DVR components
during power failures. Prevents data loss, viewing interruptions, lost recordings and loss of component
programming. Automatic Voltage Regulation (AVR) circuits regulate brownouts and overvoltages from
75V to 147V back to usable levels without consuming battery power. Offers complete power protection
with support for upright tower, flat shelf-mount or 2U rackmount installation in an attractive all-black
cabinet design. Includes 8 battery-supported outlets. Built-in USB port and DB9 serial port enable optional
unattended system shutdown without data loss in case of extended power failure; cabling included.
PowerAlert Software available via free download from www.tripplite.eaton.com. HID-compliant USB
interface enables integration with built-in power management and auto-shutdown features of Windows
and Mac OS X. Built-in single-line RJ-45 jacks offer protection for equipment with single-line tel/DSL or
network Ethernet connection. Three sets of 2.2 GHz coaxial jacks protect against surges entering on
CATV, satellite or broadcast antenna connections. Built-in audible alarm and large LCD front panel status
screen indicates line power status, battery power status, battery low/replace status and voltage boost
operation. 1500VA/900W power-handling capacity supports entry-level PCs, home entertainment
systems, network workstations and audio/video components. $250,000 Ultimate Lifetime Insurance (U.S.,
Canada, and Puerto Rico only).
Features
LCD Display with dimmer switch indicates input voltage, battery capacity and a variety of operating
conditions. Display is rotatable for easy viewing whether UPS is in vertical or horizontal position
Offers voltage regulation, surge suppression and long-lasting battery support during blackouts
1/5
HTRL15UPS Digital UPS
USB, phone, and coax cabling
Mounting hardware
Manual with warranty
information
Cleveland, OH 44122
United States
Supports entry-level PCs or single VCR/DVR components during blackouts
Regulates brownouts and overvoltages from 75V to 147V back to usable levels without consuming
battery power
8 UPS battery-supported outlets
Included USB port and DB9 serial port enable unattended shutdown in case of extended power failure
HID-compliant USB interface enables integration with built-in power management and auto-shutdown
features of Windows and Mac OS X.
PowerAlert software available via free download from tripplite.eaton.com
Set of phone/network jacks protects a single dialup/DSL phone line or network Ethernet connection
3-line 2.2 GHz coaxial surge protection for cable, satellite and antenna connections
1500VA/900W power handling ability supports a variety of sensitive computer, home theater and other
equipment
3.5 min. full load runtime (1500VA/900W); 13 min. half-load runtime (750VA/450W)
Cabinet adapts to tower or rackmount shelf format. Rackmount installation brackets for 2U installation
included
$250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
Specifications
OVERVIEW
UPC Code
037332127419
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
8.5A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P; Right-Angled
Input Circuit Breakers
10A
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
1500
Output Capacity (kVA)
1.5
Output Capacity (Watts)
900
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
-18%, +8%
2/5
Cleveland, OH 44122
United States
Output Voltage Regulation (Battery
Mode)
115V (+/- 5%)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
115V; 120V
Output Receptacles
(8) 5-15R
Individually Controllable Load Banks
Yes
BATTERY
Runtime Full Load (min.)
3.5 min. (900w)
Runtime Half Load (min.)
13 min. (450w)
Expandable Runtime
No
DC System Voltage (VDC)
24
Battery Recharge Rate (Included
Batteries)
Less than 4.5 hours from 10% to 90%
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147
Overvoltage Correction
Input voltages between 128 and 147 are reduced by 12%
Undervoltage Correction
Input voltages between 93 and 107 are boosted by 14%
Severe Undervoltage Correction
Input voltages between 75 and 92 are boosted by 30%
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Backlighted LCD screen indicates input voltage, 5-bar battery charge level, overload, AVR, on battery and replace
battery status; LCD screen rotates for rack/tower viewing
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure, low-battery and overload status; alarm can be disabled using PowerAlert
software
LED Indicators
Front panel LCD display
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
480
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet; Coax jacks (3 sets)
UPS Dataline Suppression Details
HD-compatible 2.2GHz coaxial protection
EMI / RFI AC Noise Suppression
Yes
3/5
Cleveland, OH 44122
United States
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
2U
Cooling Method
Fan
Included Mounting Accessory
Description
Pair of mounting ears enable tower and 2-4 post rackmount installation
Installation Form Factors Supported
with Included Accessories
Tower
Maximum Device Depth (cm)
26.67
Maximum Device Depth (in.)
10.5
Maximum Device Depth (mm)
267
Primary UPS Depth (mm)
267
Primary UPS Height (mm)
89
Primary UPS Width (mm)
437
Shipping Dimensions (hwd / in.)
7.00 x 21.00 x 14.50
Shipping Dimensions (hwd / cm)
17.78 x 53.34 x 36.83
Shipping Weight (lbs.)
31.00
Shipping Weight (kg)
14.06
UPS Housing Material
ABS
UPS Power Module Dimensions
(hwd, cm)
8.89 x 43.69 x 26.67
(hwd, in.)
3.5 x 17.2 x 10.5
UPS Power Module Weight (kg)
13.15
UPS Power Module Weight (lbs.)
29
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
266.1
Battery Mode BTU / Hr. (Full Load)
626.7
AC Mode Efficiency Rating (100%
Load)
92%
COMMUNICATIONS
PowerAlert Software
Free download from https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 Serial cabling included
4/5
Cleveland, OH 44122
United States
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Communications Interface
USB (HID enabled); DB9 Serial
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
75
High Voltage Transfer to Battery
Power (Setpoint)
147
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Inverter can be cold started to enable temporary AC output during a power failure
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“HTRL15UPS”相匹配的价格&库存,您可以联系我们找货
