SMX1050SLT
SMX1050SLT
    TRIPPLITE
    UPS INTERNATIONAL SMART TOWER
SMX1050SLT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 230V 1.05kVA 650W Line-Interactive Sine Wave UPS, Tower, Network Card Options, USB, DB9, 8 Outlets MODEL NUMBER: SMX1050SLT Highlights ● Corrects under- and overvoltages from 182V to 278V (230V) ● 8 C13 outlets ● Front-panel LEDs indicate load, power, voltage and battery statuses ● Add optional WEBCARDLX with latest version of PADM20 for enhanced remote management ● 20 min. runtime at half load; 7 min. at full load Package Includes Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts, brownouts, surges and line noise. Ideal solution for point-of-sale applications, VoIP systems and small business networks. Description The SMX1050SLT SmartPro 230V 1.05kVA 650W Line-Interactive Sine Wave UPS provides battery backup and AC power protection against blackouts, brownouts, power surges and line noise that can damage electronics or destroy data. Ideal for backing up point-of-sale applications, VoIP systems and small business networks, the SMX1050SLT switches to battery mode in milliseconds to keep your connected equipment running long enough to save files and shut down safely with no data loss. Featuring eight C13 outlets and a C14 inlet that accepts a user-supplied AC power cord, the SMX1050SLT has an internal battery that provides 20 minutes of support at half load and seven minutes at full load. Front-panel LEDs indicate line power, voltage regulation, load level and battery status. An alarm sounds to indicate power failure or overload. Automatic voltage regulation (AVR) maintains selectable 220V, 230V or 240V nominal output over an input range of 174V–266V (220V), 182V–278V (230V) or 190V–290V (240V) without using battery power. EMI/RFI noise filtering improves your equipment’s performance and prevents damage. A 350-joule surge suppression rating protects your equipment from harmful power surges. With Tripp Lite’s downloadable PowerAlert® software, the SMX1050SLT enables safe unattended system shutdown and file saves in case of a prolonged power failure. Adding an optional network management card permits remote management of the UPS, including reboots and activity logs. Features Protects Mission-Critical Equipment ● Provides fully regulated sine wave AC output for point-of-sale applications, VoIP systems and small business networks ● Audible alarm signals loss of utility power or overload ● 8 C13 outlets ● C14 inlet accepts user-supplied AC power cord with country-specific plug ● 350-joule surge suppression rating Reliable Battery Backup 1/6 ● SMX1050SLT SmartPro 230V 1.05kVA 650W Line-Interactive Sine Wave UPS ● USB cable ● DB9 cable ● (2) IEC-320 C13-to-C14 power cables ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Supports half load up to 20 min. and full load up to 7 min. ● Internal batteries designed for hot-swap field replacement ● Cold-start capability enables turn-on in battery mode during blackouts Automatic Voltage Regulation (AVR) ● Maintains selectable nominal output without using battery power ● Corrects brownouts and overvoltages from 174V–266V (220V), 182V–278V (230V) or 190V–290V (240V) EMI/RFI Line Noise Filtering ● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment’s performance LED Indicators ● Front-panel LEDs indicate line power, voltage regulation, load level and battery status Optional Network Management Cards ● Compatible with Tripp Lite UPS management card options WEBCARDLX, SNMPWEBCARD and RELAYIOCARD Optional WEBCARDLX (sold separately) with the latest version of PowerAlert Device Manager firmware (PADM20) provides enhanced remote management capabilitiesPADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance functions in large installations, including firmware update checks and backup and restoration of device configurations Communication Ports ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert Telephone/Network Jacks ● Protect against power surges over telephone/DSL or network Ethernet lines Specifications OVERVIEW UPC Code 037332124548 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 2.8A (230V), 3.0A (220V), 2.7A (240V) Nominal Input Voltage(s) Supported 220V AC; 230V AC; 240V AC UPS Input Connection Type C14 inlet UPS Input Connection Description IEC320-C14 input connection accepts a variety of detachable cordsets to match country or site-specific wall receptacles OUTPUT 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Capacity (VA) 1050 Output Capacity (kVA) 1.05 Output Capacity (Watts) 650 Output Capacity (kW) 0.65 Nominal Voltage Details 230V nominal output in battery mode Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Automatic frequency selection Output Voltage Regulation (Line Mode) -9%, +5% Output Voltage Regulation (Battery Mode) +/- 5% Included Output Power Cables Includes 2 C13 to C14 output power cables Hot-Swap PDU options PDUBHV10 (2U / 8 C13 outlets) Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 220V; 230V; 240V Output Receptacles (8) C13 Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 7 min. (650W) Runtime Half Load (min.) 20 min. (325W) Expandable Runtime No DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) Less than 8 hours from 10% to 90% (typical, full load discharge) Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC24-SLT  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 182 to 278 (230v), 190 to 290 (240v), 174 to 266 (220v) Overvoltage Correction Voltage reduction of 12% applies when input is 244 to 278 (230v), 254 to 290 (240v), 232 to 266 (220v); Voltage setpoints ±5% tolerance Undervoltage Correction Voltage boost of 14% applies when input is 182 to 206 (230v), 190 to 216 (240v), 174 to 198 (220); Voltage setpoints ±5% tolerance 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation; rear panel protected switches support nominal voltage selection Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch Audible Alarm Audible alarm indicates power failure and overload conditions LED Indicators 9 LEDs indicate line power, battery power, AVR, overload and replace battery status - with a 3-LED level meter for load and battery charge level SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 350 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 335 Primary UPS Height (mm) 259 Primary UPS Width (mm) 173 Shipping Dimensions (hwd / in.) 14.00 x 9.75 x 18.50 Shipping Dimensions (hwd / cm) 35.56 x 24.76 x 46.99 Shipping Weight (lbs.) 38.60 Shipping Weight (kg) 17.51 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 25.91 x 17.27 x 33.53 UPS Power Module Dimensions (hwd, in.) 10.2 x 6.8 x 13.2 UPS Power Module Weight (kg) 16.33 UPS Power Module Weight (lbs.) 36 Unit Weight (lbs.) 36.0000 Unit Weight (kg) 16.33 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 52 Battery Mode BTU / Hr. (Full Load) 521 AC Mode Efficiency Rating (100% Load) 94% Operating Elevation (ft.) Up to 10,000 ft Audible Noise Audible Noise < 50 dBA at Front Side 1 Meter Operating Elevation (m) Up to 3000m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  WEBCARDLX ;  RELAYIOCARD  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface DB9 Serial; Slot for SNMP/Web interface; USB LINE / BATTERY TRANSFER Transfer Time 4-8 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 174V (220V), 182V (230V) or 190V (240V); Voltage setpoints ±5% tolerance High Voltage Transfer to Battery Power (Setpoint) 266V (220V), 278V (230V) or 290V (240V); Voltage setpoints ±5% tolerance FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection STANDARDS & COMPLIANCE Product Certifications GOST (Russia) Product Compliance RoHS; SASO (Saudi Arabia); CE (Europe); FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (International) 2-year limited warranty 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Mexico) 2-year limited warranty Product Warranty Period (Puerto Rico) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMX1050SLT
物料型号:SMX1050SLT
器件简介:SmartPro® 230V 1.05kVA 650W 线路互动式正弦波不间断电源(UPS)为连接的关键任务设备提供电池备份和交流电源保护,以防止停电、电压波动、电力浪涌和线路噪声造成的损害。适合用于销售点应用、VoIP系统和小型企业网络。
引脚分配:包括8个C13输出插座和一个C14输入插座。
参数特性: - UPS类型:线路互动式 - 输入相位:单相 - 额定输入电流(最大负载):2.8A(230V)、3.0A(220V)、2.7A(240V) - 输出容量(VA):1050 - 输出容量(W):650 - 电池类型:阀控铅酸(VRLA) - 全负载运行时间(分钟):7(650W) - 半负载运行时间(分钟):20(325W)
功能详解: - 提供完全调节的正弦波交流输出,适用于销售点应用、VoIP系统和小型企业网络。 - 8个C13输出插座。 - C14输入插座接受用户提供的带国家特定插头的交流电源线。 - 350焦耳的浪涌抑制等级保护设备免受有害的电力浪涌。
应用信息:适用于大型网络、高端桌面/小型网络。
SMX1050SLT 价格&库存
很抱歉,暂时无法提供与“SMX1050SLT”相匹配的价格&库存,您可以联系我们找货
