OMNI1500XLNAFTA
OMNI1500XLNAFTA
    TRIPPLITE
    UPS 1500VA 940W 8OUT TOWER
OMNI1500XLNAFTA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Omni VS Line Interactive UPS System - NAFTA assembled version of OMNIVS1500XL MODEL NUMBER: OMNI1500XLNAFTA Highlights ● 1500VA / 1.5kVA line interactive, tower UPS with extended runtime capability ● Maintains 120V nominal output over an input range of 75V to 147V ● Workstation optimized features include USB port, single line TEL / DSL or Ethernet line surge suppression and two surge-only outlets ● Input: NEMA 5-15P (120V 15A) / Output: 8 NEMA 5-15R (120V) ● $200,000 Ultimate Lifetime Insurance (USA, Puerto Rico and Canada only) Package Includes Description Tripp Lite's OMNI1500XLNAFTA line interactive UPS system offers voltage regulation, surge suppression and long lasting, expandable battery support for personal computers, internetworking equipment and other sensitive electronics. Internal UPS batteries support entry level PC systems for up to 75 minutes during power failures so that connected equipment can be shut down without data loss. Automatic Voltage Regulation (AVR) circuits regulate brownouts as low as 75 and overvoltages up to 147 volts back to usable 120V levels without using battery power. Offers complete desktop power protection in an attractive black tower configuration. Includes 6 battery supported outlets for computer, monitor and vital system peripherals, plus 2 additional surge suppression only outlets for printers and other system accessories not requiring battery support. USB port enables optional unattended system shutdown without data loss in the case of extended power failure (USB cable included). PowerAlert software available via free download from www.tripplite.eaton.com. Built-in data line suppression offers protection for equipment with single line TEL/DSL or network Ethernet connection. Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery low/replace, voltage regulation and overload. 1500VA power handling ability supports entry-level PCs, network workstations, point-of-sale equipment, small business phone systems, audio/video equipment and home theater systems. Offers 4.5 minutes battery runtime with a full load of 1500VA and 13 minutes with a half load of 750VA. Supports hot-swappable battery replacement via built-in access panel. Extended runtime available with optional BP24V34, BP24V15RT2U, BP24V282U, or BP24V70-3U external battery packs. Features ● OMNI1500XLNAFTA Uninterruptible Power Supply offers voltage regulation, surge suppression and long lasting battery support ● Supports entry level PCs up to 75 minutes during blackouts to enable shutdown without data loss ● Regulates brownouts as low as 75V and overvoltages to 147V back to usable 120V nominal levels without using battery power ● 6 UPS battery supported outlets, plus 2 additional surge suppression-only outlets ● USB port and cable enables UPS monitoring and unattended shutdown in the case of extended power failure ● PowerAlert software available via free download from tripplite.eaton.com ● Data line surge suppression protects standard dialup/DSL or Ethernet line connection ● Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery low/replace, voltage regulation and overload 1/5 ● OMNI1500XLNAFTA Line Interactive UPS ● USB and telephone cable ● Owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States ● 1500VA power handling ability supports a variety of sensitive electronic equipment ● 4.5 minutes full load runtime (1500VA), 13 minutes half load runtime (750VA) ● Runtime is expandable with the addition of external battery packs ● Supports hot swappable battery replacement via built-in access panel ● $200,000 Ultimate Lifetime Insurance (USA, Puerto Rico and Canada only) Specifications OVERVIEW UPC Code 037332137630 INPUT Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 940 Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) 115V (+/- 5%) UPS Output Receptacles (Surge Suppression Only) 6 UPS outlets, 2 surge-only outlets Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 115V; 120V Output Receptacles (8) 5-15R BATTERY Runtime Full Load (min.) 4.5 min. (940w) Runtime Half Load (min.) 13 min. (470w) 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Expandable Runtime Yes External Battery Pack Compatibility  BP24V15RT2U  (limit 1);  BP24V28-2U  (limit 1);  BP24V70-3U  (multi-pack compatible) DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC51  (quantity 2) Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 93 and 107 are boosted by 14% Severe Undervoltage Correction Input voltages between 75 and 92 are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 510 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 191 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary UPS Height (mm) 300 Primary UPS Width (mm) 183 Shipping Dimensions (hwd / in.) 15.50 x 11.00 x 11.25 Shipping Dimensions (hwd / cm) 39.37 x 27.94 x 28.58 Shipping Weight (lbs.) 30.00 Shipping Weight (kg) 13.61 UPS Housing Material Polycarbonate UPS Power Module Dimensions (hwd, cm) 29.97 x 18.29 x 19.05 UPS Power Module Dimensions (hwd, in.) 11.8 x 7.2 x 7.5 UPS Power Module Weight (kg) 12.70 UPS Power Module Weight (lbs.) 28 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 355.1 Battery Mode BTU / Hr. (Full Load) 277.9 AC Mode Efficiency Rating (100% Load) 90% COMMUNICATIONS PowerAlert Software Free download from https://tripplite.eaton.com/products/power-alert Communications Cable USB cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 75 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $200,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
OMNI1500XLNAFTA
### 物料型号 - 型号:OMNI1500XLNAFTA
### 器件简介 - 简介:Tripp Lite的OMNI1500XLNAFTA是一款线互动式UPS系统,提供电压调节、浪涌抑制和长久、可扩展的电池支持,适用于个人电脑、网络设备和其他敏感电子设备。内部UPS电池支持入门级PC系统在断电情况下最长75分钟,以便连接的设备可以无数据丢失地关闭。自动电压调节(AVR)电路可以在不使用电池电源的情况下,将低至75伏和高达147伏的电压调节至可用的120伏水平。
### 引脚分配 - 输出插座:6个电池支持的UPS插座,2个额外的仅浪涌抑制插座。
### 参数特性 - 额定输入电流(最大负载):12A - 名义输入电压:120V AC - 输出容量(VA):1500 - 输出容量(kVA):1.5 - 输出容量(瓦特):940 - 频率兼容性:60 Hz - 输出电压调节(在线模式):-18%,+8% - 输出电压调节(电池模式):115V(+/-5%) - 运行时间(全负载):4.5分钟(940W) - 运行时间(半负载):13分钟(470W)
### 功能详解 - 电压调节:自动电压调节(AVR)维持线电源操作,输入电压范围75至147伏。 - 浪涌/噪声抑制:UPS AC抑制焦耳等级为510,响应时间为瞬时。 - 数据线路抑制:1线TEL/DSL(1进/1出);10/100Base T以太网。 - EMI/RFI AC噪声抑制:是。
### 应用信息 - 应用:支持入门级PC、网络工作站、销售点设备、小型企业电话系统、音视频设备和家庭影院系统。
### 封装信息 - 主要形态:塔式 - 冷却方法:风扇 - UPS尺寸:高300mm x 宽183mm x 深191mm
OMNI1500XLNAFTA 价格&库存
很抱歉,暂时无法提供与“OMNI1500XLNAFTA”相匹配的价格&库存,您可以联系我们找货
