SMART1050NET
SMART1050NET
    TRIPPLITE
    UPS1050VA705W6OUTW/SOFTWARE
SMART1050NET 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SMART1050NET is not for sale in Colorado, Vermont and Washington state. Customers in these states should purchase the recommended ENERGY STAR® 2.0 model instead: OMNISMART1050MX. Learn more about ENERGY STAR 2.0 and sales restrictions in these states. SmartPro 120V 1.05kVA 705W Line-Interactive UPS, Tower, USB, 6 Outlets MODEL NUMBER: SMART1050 Highlights ● Corrects under- and overvoltages from 75V to 147V ● 6 NEMA 5-15R outlets ● Front-panel LEDs indicate load, power and battery statuses ● Monitoring of power conditions via PowerAlert® ● 23 min. runtime at half load; 8 min. at full load Package Includes Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts, brownouts, power surges and line noise. Ideal solution for data centers, VoIP systems, points of sale and network closets. Description The SMART1050 SmartPro 120V 1.05kVA 705W Line-Interactive UPS provides battery backup and AC power protection against blackouts, brownouts, power surges and line noise that can damage electronics or destroy data. Ideal for backing up data centers, VoIP systems, points of sale and network closets, the SMART1050 switches to 1.05kVA/705W battery mode in milliseconds to keep your connected equipment running long enough to save files and shut down safely with no data loss. Featuring six NEMA 5-15R outlets and a six-foot power cord with 120V NEMA 5-15P input, the SMART1050 has an internal battery that provides 23 minutes of support at half load and eight minutes at full load. Front-panel LEDs indicate line power, battery power, overload, voltage regulation and battery status. An alarm sounds to indicate power failure or a low battery. Automatic voltage regulation (AVR) maintains 120V nominal output over an input range of 75V to 147V without using battery power. EMI/RFI noise filtering improves your equipment’s performance and prevents damage. A 480-joule surge suppression rating protects your equipment from harmful power surges. With Tripp Lite’s PowerAlert software, available via free download, the SMART1050 enables safe unattended system shutdown and file saves in case of a prolonged power failure. Features Protects Mission-Critical Equipment ● Provides fully regulated AC output for servers, network storage devices and telecom hardware 1/6 ● SMART1050 SmartPro 120V 1.05kVA 705W Line-Interactive UPS ● USB cable ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Audible alarm signals loss of utility power or low battery ● 6 NEMA 5-15R outlets ● 6 ft. power cord with 120V NEMA 5-15P input ● 480-joule surge suppression rating Reliable Battery Backup ● Supports half load up to 23 min. and full load up to 8 min. ● Internal batteries designed for hot-swap field replacement ● 96% line-power efficiency rating saves money in energy costs ● Cold-start capability enables turn-on in battery mode during blackouts Automatic Voltage Regulation (AVR) ● Maintains 120V nominal output over input range of 75V–147V without using battery power EMI/RFI Line Noise Filtering ● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment’s performance LED Indicators ● Front-panel LEDs signal indicate line power, battery power, overload, voltage regulation and battery status USB Communication Port ● USB port combines with PowerAlert software (available via free download at tripplite.eaton.com/products/power-alert) to enable safe unattended system shutdown and file saves in case of a prolonged power failure ● Supports messaging of UPS and line power status, including voltage and battery capacity Small-Footprint Tower Housing ● Uses less than 53 sq. in. of floor or desktop space ● Mounts on wall with optional UPSWM accessory Specifications OVERVIEW UPC Code 037332033802 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 6.7A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P; Right-Angled 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Input Circuit Breakers 12A UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity (VA) 1050 Output Capacity (kVA) 1.05 Output Capacity (Watts) 705 Output Capacity (kW) 0.705 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks No BATTERY Runtime Full Load (min.) 8 Runtime Half Load (min.) 23 Expandable Runtime No DC System Voltage (VDC) 18 Battery Recharge Rate (Included Batteries) Less than 4 hours from 10% to 90% (typical, full load discharge) Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC52  (quantity 3) Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 93 and 107 are boosted by 14% Severe Undervoltage Correction Input voltages between 75 and 92 are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes AC Suppression Joule Rating 480 AC Suppression Response Time Instantaneous PHYSICAL Primary Form Factor Tower Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 183 Primary UPS Height (mm) 300 Primary UPS Width (mm) 183 Shipping Dimensions (hwd / in.) 15.60 x 10.60 x 10.70 Shipping Dimensions (hwd / cm) 39.62 x 26.92 x 27.18 Shipping Weight (lbs.) 33.00 Shipping Weight (kg) 14.97 UPS Housing Material Polycarbonate UPS Power Module Dimensions (hwd, cm) 29.97 x 18.29 x 18.29 UPS Power Module Dimensions (hwd, in.) 11.8 x 7.2 x 7.2 UPS Power Module Weight (kg) 13.15 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Power Module Weight (lbs.) 29 Unit Dimensions (hwd / in.) 11.750 x 7.250 x 7.500 Unit Weight (lbs.) 29.6000 Unit Weight (kg) 13.43 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode Efficiency Rating (100% Load) 96% COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in USB port, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Communications Interface USB LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 75 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMART1050NET 价格&库存
很抱歉,暂时无法提供与“SMART1050NET”相匹配的价格&库存,您可以联系我们找货
