OMNIX1500XLTAA
OMNIX1500XLTAA
    TRIPPLITE
    INTLUPSOMNISMARTTOWER8OUT
OMNIX1500XLTAA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States TAA-Compliant OmniVS 230V 1500VA 940W Line-Interactive UPS, Extended Run, Tower, USB port, C13 Outlets Highlights ● Federal Trade Agreements Act / TAA Compliant for GSA Schedule purchase ● 1500VA / 1.5kVA tower 230V line interactive extended-run UPS ● Corrects brownouts and overvoltages from 151 to 282V ● USB port, TEL/DSL/ethernet protection, External battery pack options ● C14 input and 8 C13 outlets MODEL NUMBER: OMNIX1500XLTAA Package Includes Description Tripp Lite's OMNIX1500XLTAA is compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. This line interactive UPS system offers voltage regulation, surge suppression and long lasting, expandable battery support for personal computers, internetworking equipment and other sensitive electronics. Internal UPS circuits support entry level PC systems for up to 75 minutes during power failures so that connected equipment can be shut down without data loss. Automatic Voltage Regulation (AVR) circuits regulate brownouts as low as 151 and overvoltages up to 282 volts back to usable 230V levels without using battery power. Offers complete desktop power protection in an attractive black tower configuration. Includes 8 IEC320-C13 outlets with battery support and AC surge suppression. USB port enables optional unattended system shutdown without data loss in the case of extended power failure, USB cable included. PowerAlert software available via free download from www.tripplite.eaton.com. Built-in single line RJ jacks protect modem, fax machine, Ethernet, cordless phone or other peripheral with a standard dialup/DSL phone connection. Built-in audible alarm and 4 front panel LEDs indicate line power status, battery power status, battery low/replace status and voltage boost operation. 1500VA power handling ability supports entry-level PCs, network workstations, point-of-sale equipment, small business phone systems, audio/video equipment and home theater systems. Offers 4.5 minutes battery runtime with a full load of 1500VA and 13 minutes with a half load of 750VA. Supports hot-swappable battery replacement via built-in access panel. Extended runtime available with optional BP24V15RT2U or BP24V28-2U external battery packs. Features ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases ● OMNIX1500XLTAA Uninterruptible Power Supply offers voltage regulation, surge suppression and long lasting battery support ● Supports entry level PCs up to 75 minutes during blackouts to enable shutdown without data loss, runtime is further expandable by connecting an external battery pack ● Regulates brownouts as low as 151 and overvoltages to 282V back to usable 230V nominal levels without using battery power ● 8 IEC320 C13 outlets with complete AC surge suppression ● C14 inlet accepts user-supplied AC power cord with country-specific plug ● USB port and cable enables unattended shutdown in the case of extended power failure ● PowerAlert software available via free download from tripplite.eaton.com 1/5 ● OMNIX1500XLTAA TAA Compliant line interactive UPS ● 2 C13 to C14 interconnection cables ● USB and phone line cables ● Owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Dataline surge suppression protects standard dialup/DSL or Ethernet line connection ● Audible alarm and 4 front panel LEDs offer complete UPS and line power status information ● 1500VA power handling ability supports a variety of sensitive electronic equipment ● 4.5 minutes full load runtime (1500VA), 13 minutes half load runtime (750VA) ● Runtime is further expandable with the addition of external battery packs ● Supports hot swappable battery replacement via built-in access panel ● Attractive full color retail packaging Specifications OVERVIEW UPC Code 037332153272 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 5A Nominal Input Voltage(s) Supported 230V AC UPS Input Connection Type C14 inlet UPS Input Connection Description Attached 15cm line cord with C14 inlet. The C14 inlet accepts user-supplied AC power cord with country-specific plug. UPS Input Cord Length (ft.) 0.5 UPS Input Cord Length (m) 0.2 OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 940 Frequency Compatibility 50 / 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Included Output Power Cables Includes 2 C13 to C14 output power cables Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 230V Output Receptacles (8) C13 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States BATTERY Runtime Full Load (min.) 4.5 min. (940w) Runtime Half Load (min.) 13 min. (470w) Expandable Runtime Yes External Battery Pack Compatibility  BP24V15RT2U  (limit 1);  BP24V28-2U  (limit 1);  BP24V70-3U  (multi-pack compatible) DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC51  (quantity 2) Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 151 to 282 Overvoltage Correction Input voltages between 245 and 282 are reduced by 12% Undervoltage Correction Input voltages between 177 and 199 are boosted by 14% Severe Undervoltage Correction Input voltages between 151 and 176 are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 340 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Installation Form Factors Supported with Included Accessories Tower 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 191 Primary UPS Height (mm) 300 Primary UPS Width (mm) 183 Shipping Dimensions (hwd / in.) 15.50 x 11.00 x 11.25 Shipping Dimensions (hwd / cm) 39.37 x 27.94 x 28.58 Shipping Weight (lbs.) 35.00 Shipping Weight (kg) 15.88 UPS Housing Material Polycarbonate UPS Power Module Dimensions (hwd, cm) 29.97 x 18.29 x 19.05 UPS Power Module Dimensions (hwd, in.) 11.8 x 7.2 x 7.5 UPS Power Module Weight (kg) 14.51 UPS Power Module Weight (lbs.) 32 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 98.8 Battery Mode BTU / Hr. (Full Load) 654.6 AC Mode Efficiency Rating (100% Load) 97% COMMUNICATIONS PowerAlert Software Free download from https://tripplite.eaton.com/products/power-alert Communications Cable USB interface cable included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Communications Interface USB LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 151 High Voltage Transfer to Battery Power (Setpoint) 282 FEATURES & SPECIFICATIONS 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
OMNIX1500XLTAA 价格&库存
很抱歉,暂时无法提供与“OMNIX1500XLTAA”相匹配的价格&库存,您可以联系我们找货
