SMART700SER
SMART700SER
    TRIPPLITE
    UPS 700VA 450W 6OUT SERIAL
SMART700SER 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 700VA 450W Line-Interactive UPS, Tower, DB9 Serial MODEL NUMBER: SMART700SER Highlights ● 700VA line interactive tower UPS system ● 120V nominal output during brownouts to 75V and overvoltages to 147V ● Front panel status LEDs with load and battery capacity level display ● RS232 communications port; Hot-swappable batteries ● NEMA 5-15P input; 6 NEMA 515R outlets Package Includes Description Tripp Lite's SMART700SER is an intelligent, line-interactive UPS with DB9 serial port. It protects servers, networking accessories and telecommunications equipment from blackouts, voltage fluctuations and transient surges. Large internal batteries offer 16.9 minutes half load runtime and 5.9 minutes at full load during power failures. 700VA/450 watt power handling capability supports a variety of networking, telecom and various other application types, including the support of multiple network workstations. Includes a total of 6 UPS supported outlets. Supports remote monitoring of UPS and site power conditions via built-in DB9 serial port. PowerAlert UPS monitoring and unattended shutdown software is available for free download. Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery low/replace, voltage regulation and load level. Wall mountable with user-supplied UPSWM wall-mount bracket. Network-grade AC surge suppression protects equipment from damage and performance problems resulting from transient surges. Attractive, small-footprint tower housing uses minimal floor or desktop space. Features ● 700VA/450 watt power handling capability supports a variety of networking, telecom and various other application types ● Built-in voltage regulation and battery support, plus complete AC modem line surge suppression prevents equipment damage, data loss and downtime ● Large internal batteries offer 16.9 minutes half load runtime and 5.9 minutes at full load during power failures ● Intelligent battery management system extends battery life ● Automatic Voltage Regulation (AVR) circuits with two boost and one voltage reduction level maintains usable 120V nominal output over an input voltage range of 75-147V ● Includes a total of 6 NEMA5-15R outlets ● Communications ports support timed inverter shutoff after unattended shutdown, activate self-test and 10 second reboot of connected equipment ● Serial port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, 1/5 ● SMART700SER UPS System ● Serial cable ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States available via FREE download from tripplite.eaton.com/products/power-alert ● Battery replacement door ● Notification of system status via 5 LEDs and multi-function audible alarms ● Wall mountable with user-supplied UPSWM wallmount bracket ● Cold start capability enables UPS turn-on in battery mode during blackout conditions Specifications OVERVIEW UPC Code 037332118172 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 4.33A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 10A UPS Input Cord Length (ft.) 7 UPS Input Cord Length (m) 2.1 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 700 Output Capacity (Watts) 450 Nominal Voltage Details 115v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks No 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 5.9 min. (450w) Runtime Half Load (min.) 16.9 min. (225w) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 90% (typical, full load discharge) Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC52  (x2) Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 93 and 107 are boosted by 14% Severe Undervoltage Correction Input voltages between 75 and 92 are boosted by 30% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 198 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary UPS Height (mm) 300 Primary UPS Width (mm) 183 Shipping Dimensions (hwd / in.) 15.40 x 10.90 x 10.40 Shipping Dimensions (hwd / cm) 39.12 x 27.69 x 26.42 Shipping Weight (lbs.) 23.70 Shipping Weight (kg) 10.75 UPS Housing Material Polycarbonate UPS Power Module Dimensions (hwd, cm) 29.97 x 18.29 x 19.81 UPS Power Module Dimensions (hwd, in.) 11.8 x 7.2 x 7.8 UPS Power Module Weight (kg) 9.53 UPS Power Module Weight (lbs.) 21 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 98 AC Mode Efficiency Rating (100% Load) 92% COMMUNICATIONS Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in serial port, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable DB9 serial cable included Communications Interface DB9 Serial LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 75 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SMART700SER 价格&库存
很抱歉,暂时无法提供与“SMART700SER”相匹配的价格&库存,您可以联系我们找货
