OMNIX350HG
OMNIX350HG
    TRIPPLITE
    INTL UPS OMNI HOSPITAL GRADE
OMNIX350HG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OmniSmart 230V 350VA 225W CE/IEC 60601-1 Medical Grade Line-Interactive UPS with Built-In Isolation Transformer Highlights ● 350VA line interactive tower UPS ● Professional features include USB port, IEC320 plug & outlets, built-in isolation transformer ● Input: IEC320 C14 inlet (230V) / Output: 6 IEC320 C13 (230V) ● 2 line phone suppression for TEL/DSL line protection ● Approved for use within the Patient Care Vicinity ● Approved to EN60601-1-2:2015, 4th Edition MODEL NUMBER: OMNIX350HG Package Includes Description Tripp Lite's OMNIX350HG offers medical-grade UPS protection with built-in line interactive voltage regulation. IEC320 plug & outlets, plus built-in isolation transformer with Faraday shield offers full isolation and removes common mode noise. Tested to CE/IEC 60601-1 as medical electrical equipment. 350VA power handling capacity supports computers, inter-networking equipment and other critical loads during commercial power failures. Line interactive voltage regulation corrects brownouts as low as 159V back to normal 230V levels, saving battery reserves for use only during complete power failures. Includes, 2 line phone surge suppression and built-in USB communications port. Application Usage This UPS contains a lead acid battery designed to be connected continuously to an AC power source, except during brief power outages. It is not intended for frequent charge/discharge cycles, such as mobile cart applications where the UPS is often disconnected from the power source. Using the OMNIX350HG in this type of application will void the battery warranty. Features ● Ideal UPS protection for applications in medical patient-care areas where CE/ IEC 60601-1 electrical medical equipment is required ● Line-interactive voltage regulation corrects brownouts as low as 159V without using battery power ● IEC320 plug and outlets offer added degree of safety and reliability to input/output connections ● Full line isolation prevents shock potential and operational problems in sensitive electronic equipment ● Resistant to electrostatic discharge ● Supports loads up to 350VA/225 watts ● 37 minutes half load runtime (with 175VA load), 15.5 minutes full load runtime (with 350VA load) ● 6 protected outlets; 6-inch dongle with IEC C14 inlet ● C14 inlet accepts user-supplied AC power cord with grounded country-specific plug ● 1-USB port for monitoring interface ● Complete surge protection, line isolation and EMI/RFI noise filtering ● 2 phone line surge suppression for modems, fax machines and other phone accessories ● 4 diagnostic LEDs indicate AC present, on battery, voltage correction & battery low/replace 1/5 ● OMNIX350HG Hospital Grade UPS System ● USB communication and telephone cables included ● Warranty information ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Battery replacement door and back panel equipotential connection (grounding lug) ● Ground Potential Equalization Connector: POAG-S6/20 Specifications OVERVIEW UPC Code 037332140432 UPS Type Line-Interactive INPUT Rated input current (Maximum Load) 1.8A Nominal Input Voltage(s) Supported 230V AC UPS Input Connection Type C14 inlet UPS Input Connection Description C14 inlet accepts user-supplied AC power cord with grounded country-specific plug UPS Input Cord Length (ft.) 0.50 UPS Input Cord Length (m) 0.2 Recommended Electrical Service 10A 230V Voltage Compatibility (VAC) 230 Input Phase Single-Phase OUTPUT Output Capacity (VA) 350 Output Capacity (kVA) 0.35 Output Capacity (Watts) 225 Output Capacity (kW) 0.225 Nominal Voltage Details 230v nominal inverter output voltage Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Automatic frequency selection Output Voltage Regulation (Line Mode) -18%, +8% Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 220V; 230V; 240V Output Receptacles (6) C13 Individually Controllable Load Banks No BATTERY 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 15.5 min. (225W) Runtime Half Load (min.) 37 min. (113W) Expandable Runtime No DC System Voltage (VDC) 12 Battery Recharge Rate (Included Batteries) Less than 7.2 hours from 10% to 90% Battery Access Battery access door allows hot-swap battery replacement without powering connected equipment off Internal UPS Replacement Battery Cartridge  RBC52  (quantity 2) Typical Battery Lifespan 3-6 years, depending on usage VOLTAGE REGULATION Voltage Regulation Description Line interactive UPS offers a single boost level of brownout correction to maintain usable, computer grade output Undervoltage Correction Input voltages between 159 and 199 are boosted by 14% USER INTERFACE, ALERTS & CONTROLS Switches Yes, includes 2 front panel mounted push-button switches for system enable, self-test and alarm cancel functions Audible Alarm Audible alarm indicates power failure conditions, silenceable via alarm cancel switch. Once cancelled, alarm will resume when approximately 2 minutes of battery operation remain (assuming full load) LED Indicators 4 LEDs indicate line power, battery power, overload and battery low/replace status SURGE / NOISE SUPPRESSION EMI / RFI AC Noise Suppression Yes AC Suppression Response Time Instantaneous Dataline Suppression 2-Line Tel/DSL PHYSICAL Primary Form Factor Tower Cooling Method Convection Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 188 Primary UPS Height (mm) 269 Primary UPS Width (mm) 132 Shipping Dimensions (hwd / in.) 14.13 x 10.43 x 8.23 Shipping Dimensions (hwd / cm) 35.89 x 26.49 x 20.90 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 27.40 Shipping Weight (kg) 12.43 UPS Housing Material PVC UPS Power Module Dimensions (hwd, cm) 26.92 x 13.21 x 18.80 UPS Power Module Dimensions (hwd, in.) 10.6 x 5.2 x 7.4 UPS Power Module Weight (kg) 11.52 UPS Power Module Weight (lbs.) 25.4 Unit Weight (lbs.) 25.4000 Unit Weight (kg) 11.52 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 15.6 Battery Mode BTU / Hr. (Full Load) 124.5 COMMUNICATIONS Network Management Card Description Network management not supported Communications Interface USB LINE / BATTERY TRANSFER Transfer Time 5 milliseconds AC to battery; 8 milliseconds battery to AC Low Voltage Transfer to Battery Power (Setpoint) 159 High Voltage Transfer to Battery Power (Setpoint) 266 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Surge/noise protection Grounding Lug Ground Potential Equalization Connector: POAG-S6/20 STANDARDS & COMPLIANCE Product Certifications IEC 60601-1 Product Compliance RoHS; CE (Europe); FCC Part 15 Class B (USA) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (International) 2-year limited warranty Product Warranty Period (Mexico) 2-year limited warranty Product Warranty Period (Puerto Rico) 2-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
OMNIX350HG
### 物料型号 - 型号:OMNIX350HG
### 器件简介 - 简介:OMNIX350HG是一款医疗级UPS电源,内置线交互式电压调节功能。它通过了CE/IEC 60601-1认证,适用于医疗电气设备。350VA的功率容量可以在商业电力故障期间支持计算机、网络设备等关键负载。线交互式电压调节可以将低至159V的电压调整回正常的230V水平,节省电池储备,仅在完全断电时使用。
### 引脚分配 - 输入:IEC320 C14插座(230V) - 输出:6个IEC320 C13插座(230V)
### 参数特性 - 输入电压:230V AC - 输出容量:350VA/225W - 频率兼容性:50/60 Hz自动频率选择 - 输出电压调节:线模式下-18%,+8% - 电池类型:阀控铅酸(VRLA) - 全负载运行时间:15.5分钟(225W) - 半负载运行时间:37分钟(113W)
### 功能详解 - 电压调节:线交互式UPS提供单级提升电压校正,以维持可用的、计算机级的输出。 - 用户界面、警报和控制:包括2个前面板安装的按钮开关,用于系统启用、自测和报警取消功能。 - 浪涌/噪声抑制:包括EMI/RFI交流噪声抑制和2线电话浪涌抑制。
### 应用信息 - 应用:适用于医院/医疗环境。
### 封装信息 - 物理形态:塔式 - 冷却方式:自然对流 - 尺寸:高269mm x 宽132mm x 深188mm - 运输重量:约12.43kg
OMNIX350HG 价格&库存
很抱歉,暂时无法提供与“OMNIX350HG”相匹配的价格&库存,您可以联系我们找货
