1000 Eaton Boulevard
Cleveland, OH 44122
United States
TE Series 120V 1200VA 940W Line-Interactive
UPS, AVR, Tower, DB9 Serial port
Highlights
6 outlets
Automatic Voltage Regulation
(AVR) corrects brownouts and
overvoltages
Larger scale battery produces
significantly longer runtimes
Serial port works with software
to facilitate unattended
shutdown
MODEL NUMBER: TE1200
Package Includes
Description
Tripp Lite's TE1200 UPS System provides line-interactive voltage regulation and long lasting battery
support for mid-size business telephone systems, voicemail systems, personal computers and other
communications, network and telecom applications. 1200VA power handling capacity and large capacity
battery system maintains continuous operation through power interruptions with over 2 hours runtime for
many phone systems and over 1 hour for larger systems. Line interactive voltage regulation maintains
normal 120 volt output levels during brownouts as low as 75V and overvoltages as high as 147V, saving
battery reserves for use only during complete power failures. Includes 6 outlets, diagnostic LEDs and a
built-in serial port that works with Free PowerAlert Software and cabling to provide automatic unattended
shutdown of network and PC applications. $200,000 Ultimate Lifetime Insurance (U.S., Canada, and
Puerto Rico only).
Features
Provides connected equipment with continuous power during short and long duration loss of commercial
power
Line-interactive voltage regulation corrects brownouts and overvoltages from 75 to 147 volts back to
usable 120V output levels, without using battery power
Supports loads up to 1200VA/940 watts
16 minutes half load runtime (600VA/470 watts), 7 minutes full load runtime (1200VA/940 watts)
6 protected outlets; 6-ft. cord
DB9 network interface
Complete surge protection and EMI/RFI noise filtering
$200,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
5 diagnostic LEDs indicate AC present, on battery, voltage correction, overload & battery low/replace
Battery replacement door
1/5
TE1200 UPS System
Warranty information
Instruction manual
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332098580
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
8.25A
Nominal Input Voltage(s) Supported
120V AC
UPS Input Connection Type
5-15P
UPS Input Cord Length (ft.)
6
UPS Input Cord Length (m)
1.8
Recommended Electrical Service
15A 120V
OUTPUT
Output Capacity (VA)
1200
Output Capacity (kVA)
1.2
Output Capacity (Watts)
940
Power Factor
0.78
Nominal Voltage Details
115v nominal output in battery mode
Frequency Compatibility
60 Hz
Output Voltage Regulation (Line
Mode)
-18%, +8%
Output Voltage Regulation (Battery
Mode)
115V (+/- 5%)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
110V; 115V; 120V
Output Receptacles
(6) 5-15R
Individually Controllable Load Banks
No
BATTERY
Runtime Full Load (min.)
7 min. (940w)
Runtime Half Load (min.)
16 min. (470w)
Expandable Runtime
No
2/5
Cleveland, OH 44122
United States
DC System Voltage (VDC)
36
Battery Recharge Rate (Included
Batteries)
Less than 8 hours from 10% to 90%
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC53
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 75 to 147
Overvoltage Correction
Input voltages between 128 and 147 are reduced by 12%
Undervoltage Correction
Input voltages between 93 and 107 are boosted by 14%
Severe Undervoltage Correction
Input voltages between 75 and 92 are boosted by 30%
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status
Audible Alarm
Audible alarm indicates power-failure and low-battery conditions
LED Indicators
5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
480
UPS AC Suppression Response
Time
Instantaneous
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Installation Form Factors Supported
with Included Accessories
Tower
with Optional Accessories
Wallmount ( UPSWM - tower mounting kit)
Primary UPS Depth (mm)
234
Primary UPS Height (mm)
325
Primary UPS Width (mm)
191
Shipping Dimensions (hwd / in.)
16.90 x 11.20 x 12.80
Shipping Dimensions (hwd / cm)
42.93 x 28.45 x 32.51
Shipping Weight (lbs.)
38.30
Shipping Weight (kg)
17.37
UPS Housing Material
PVC
3/5
Cleveland, OH 44122
United States
UPS Power Module Dimensions
(hwd, cm)
32.51 x 19.05 x 23.37
(hwd, in.)
12.8 x 7.5 x 9.2
UPS Power Module Weight (kg)
17.24
UPS Power Module Weight (lbs.)
38
ENVIRONMENTAL
Operating Temperature Range
+32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius
Storage Temperature Range
+5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
134
Battery Mode BTU / Hr. (Full Load)
438
AC Mode Efficiency Rating (100%
Load)
94%
COMMUNICATIONS
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
DB9 cable included
Communications Interface
Contact closure; DB9 Serial
LINE / BATTERY TRANSFER
Transfer Time
2-4 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
75
High Voltage Transfer to Battery
Power (Setpoint)
147
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
4/5
Cleveland, OH 44122
United States
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“TE1200”相匹配的价格&库存,您可以联系我们找货
