SU750XL
SU750XL
    TRIPPLITE
    UPS 750VA 600W 6OUT USB
SU750XL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartOnline 120V 750VA 600W DoubleConversion UPS, Tower, Extended Run, Network Card Options, USB, DB9 Serial Highlights ● 750VA / .75kVA / 600 watt online double-conversion tower UPS ● 120V +/-2% output at 50/60Hz, high efficiency economy mode option ● Expandable runtime, Hotswappable battery modules ● USB, RS232 & EPO ports; Network management card options ● Front panel status LEDs with detailed load and battery metering ● 2 independently switchable output load banks ● NEMA 5-15P input; 5-15R outlets ● To use the Auto Probe feature, this product requires a WEBCARDLX network interface (sold separately) running LX firmware update 15.5.2 or later MODEL NUMBER: SU750XL Package Includes Description The SU750XL on-line, double-conversion UPS protects critical server, networking or telecommunications equipment from blackouts, brownouts, voltage fluctuations and surges. Large-capacity 750VA/600W UPS continuously converts incoming AC to DC, then back to perfect sine wave AC output at 120V AC (+/-2%). Removes harmonic distortion, fast electrical impulses, frequency fluctuations and other hard-to-solve power problems not addressed by other UPS systems. True sine wave output and zero transfer time offer guaranteed compatibility with all equipment types. Includes 6 UPS supported outlets; 2 single-outlet load banks can be independently controlled via a software interface to selectively reboot remote equipment or shed less critical loads to extend battery runtime for the most critical equipment. Extended runtime available with optional BP24V15RT2U, BP24V28-2U, or BP24V70-3U external battery packs. Includes slot for network management card options. DB9 enhanced serial monitoring port for unattended shutdown, remote control and monitoring of UPS system and power data. Includes USB and DB9 serial ports. Built-in DB9 port offers both enhanced RS-232 enabled monitoring data, plus contact closure monitoring ability. HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. Tripp Lite's PowerAlert UPS power management software is available via free download. Compatible with Tripp Lite's Watchdog service monitoring/rebooting software. Upright tower form factor; attractive all-black color scheme. Features ● True on-line, double-conversion UPS provides constant, pure sine wave AC output ● Maintains continuous operation with zero transfer time through blackouts, brownouts, voltage fluctuations and surges ● Removes harmonic distortion, electrical impulses, frequency variations and other hard-to-solve power problems ● Accepts input voltages between 80-150V (65-150V at loads under 70%), regulating output to 120V AC +/-2% ● 750VA/600W output capacity with 6 x NEMA5-15R outlets ● Two built-in individually switchable load banks can be controlled via software interface to selectively reboot remote equipment or shed less critical loads to extend battery runtime for the most critical equipment (1 outlet per bank) ● Standard internal battery set provides 11 min. runtime at half load and 4 min. at full load ● Extended runtime available with optional BP24V15RT2U, BP24V28-2U, or BP24V70-3U external 1/6 ● SU750XL UPS System ● USB, DB9 and EPO cabling ● EPO (Emergency Power Off) cabling ● Owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States battery packs ● Intelligent battery management system extends battery life ● Some external battery configurations require the use of Tripp Lite's External Battery Configuration Software (see manual) ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● DB9 serial network interface supports RS-232 and contact closure messaging ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD, MODBUSCARD and RELAYIOCARD ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Compatible with Tripp Lite's WatchDog service monitoring/rebooting software (part# WATCHDOGSW) ● Fault tolerant electronic bypass maintains utility output during a variety of UPS fault conditions ● Diagnostic LEDs ● Upright tower format; attractive all-black color scheme ● $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) Specifications OVERVIEW UPC Code 037332126160 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 6.2A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 15A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 750 Output Capacity (kVA) 0.75 Output Capacity (Watts) 600 Output Capacity (kW) 0.6 Output Capacity Details OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes; 150% load for 30 seconds and >150% load for 0.5 seconds before switching to BYPASS (when bypass input voltage and frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE bypass limits) 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Factor 0.8 Crest Factor 3:1 Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Output frequency matches input nominal on startup, defaults to 60 Hz on cold-start Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/-10% Output Voltage Regulation (Battery Mode) +/- 2% Load Management Receptacles Two switchable single-outlet 5-15R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4 min. (600W) Runtime Half Load (min.) 11 min. (300W) Expandable Runtime Yes External Battery Pack Compatibility  BP24V15RT2U  (limit 1);  BP24V28-2U  (limit 1);  BP24V70-3U  (multi-pack compatible) DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) Less than 6 hours from 10% to 90% (typical, full load discharge) Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC24-SUTWR  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction 2% output voltage regulation during overvoltages to 150 Undervoltage Correction 2% output voltage regulation during undervoltages to 80 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Severe Undervoltage Correction 2% output voltage regulation during undervoltages to 65 (under 70% load only) USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions LED Indicators 14 LEDs indicate line power, online mode, bypass mode, on-battery, overload, battery low, replace battery and fault status information - includes 4-LED meter display for load and battery charge level SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 335 Primary UPS Height (mm) 254 Primary UPS Width (mm) 173 Shipping Dimensions (hwd / in.) 13.90 x 10.00 x 17.90 Shipping Dimensions (hwd / cm) 35.31 x 25.40 x 45.47 Shipping Weight (lbs.) 31.80 Shipping Weight (kg) 14.42 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 25.40 x 17.27 x 33.53 UPS Power Module Dimensions (hwd, in.) 10 x 6.8 x 13.2 UPS Power Module Weight (kg) 13.02 UPS Power Module Weight (lbs.) 28.7 Unit Weight (lbs.) 28.7000 Unit Weight (kg) 13.02 ENVIRONMENTAL 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 306 AC Economy Mode BTU / Hr. (Full Load) 63 AC Mode Efficiency Rating (100% Load) 87% AC Economy Mode Efficiency Rating (100% Load) 97% Audible Noise < 45 dB at front side 1m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX ;  MODBUSCARD ;  RELAYIOCARD  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure communications; Economy-mode setting option is available using PowerAlert software and DB9 Serial cable connection OR via select Network Management Card options PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time No transfer time (0 ms.) in online, double-conversion mode Low Voltage Transfer to Battery Power (Setpoint) 80V (100% load), 65V (
SU750XL
### 物料型号 - 型号:SU750XL
### 器件简介 - 简介:SU750XL是一款在线式双转换UPS,能够保护关键的服务器、网络或电信设备免受停电、电压波动和电涌的影响。这款750VA/600W的UPS能够持续将输入的交流电转换为直流电,然后再转换回完美的正弦波交流电输出,输出电压为120V AC(±2%)。它能够消除谐波失真、快速电脉冲、频率波动等其他UPS系统无法解决的电力问题。真正的正弦波输出和零转换时间保证了与所有设备类型的兼容性。
### 引脚分配 - 输出插座:6个NEMA 5-15R插座 - 独立可控负载库:是,有两个可独立控制的单插座负载库
### 参数特性 - 输入电压范围:80-150V(负载低于70%时为65-150V) - 输出电压调节:在线模式±2%,经济线模式±10%,电池模式±2% - 额定输出电压:支持120V - 电池类型:阀控式铅酸电池(VRLA) - 全负载运行时间:4分钟(600W) - 半负载运行时间:11分钟(300W)
### 功能详解 - 真正的在线式双转换UPS:提供持续、纯净的正弦波交流电输出 - 零转换时间:通过停电、电压波动和电涌维持连续运行 - 消除谐波失真和电脉冲:解决其他UPS系统无法解决的电力问题 - 接受输入电压范围广泛:调节输出至120V AC ±2%
### 应用信息 - UPS应用:关键任务应用
### 封装信息 - 主要形态:塔式 - 冷却方式:风扇 - 支持的安装形态:塔式 - UPS尺寸:高度254mm,宽度173mm,深度335mm - 运输尺寸:高13.90英寸,宽10.00英寸,深17.90英寸 - 运输重量:31.80磅
SU750XL 价格&库存
很抱歉,暂时无法提供与“SU750XL”相匹配的价格&库存,您可以联系我们找货
