SMART750RMXL2U
SMART750RMXL2U
    TRIPPLITE
    UPS SMARTPRO 750VA 450W 6OUT
SMART750RMXL2U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 750VA 600W Line-Interactive Sine Wave UPS, 2U, Extended Run, Network Card Options, LCD, USB, DB9 Highlights ● 0.75kVA / 750VA / 600W line interactive 2U rack/tower UPS, Sine Wave ● Extended runtime options up to 450W, Interactive LCD interface ● 95% line-mode efficiency, 2 switched load banks, 4-post mounting kit ● USB, RS232, EPO and slot for network management card options ● 120V NEMA 5-15P input, 6 NEMA 5-15R outlets ● To use the Auto Probe feature, this product requires a WEBCARDLX network interface (sold separately) running LX firmware update 15.5.2 or later MODEL NUMBER: SMART750RMXL2U Package Includes Description Tripp Lite SmartPro Line Interactive UPS with enhanced LCD interface offers network-grade power protection for critical server, network and telecommunications equipment. Line Interactive Uninterruptible Power Supply (UPS) with built-in Auto-Voltage Regulation (AVR) actively corrects brownouts and overvoltages back to usable levels while maintaining a full battery charge in case of power failure. Interactive LCD interface reports UPS operating mode, detailed UPS and site-power data, plus enables a variety of UPS setup and configuration options. Super-fast switchover from line to battery power occurs within milliseconds to maintain operation of connected equipment without interruption or reboot. 95% linemode efficiency offers reduced heat emissions and operating costs. Network management interfaces support communications via USB, RS-232 and slot for optional Network Management Card options. HIDcompliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. Network communications ports enable detailed monitoring of equipment load levels, self-test data and utility power conditions. PowerAlert UPS monitoring software is available via free download. Switched output load banks enable scheduled and real-time remote reboot and load shedding of select outlets. Emergency Power Off (EPO) interface. LCD display panel easily rotates for viewing in rackmount or tower configurations. Audible alarm with push-button momentary alarm-cancel and silentmode configuration options. Programmable self-test. Field-replaceable, hot-swappable battery modules. Features ● Tripp Lite SMART750RMXL2U line interactive 2U rack/tower UPS with 750VA / .75kVA / 600W capacity and extended runtime options ● Line interactive UPS with Automatic Voltage Regulation (AVR) corrects brownouts and overvoltages from 83 to 147V ● NEMA 5-15P input plug; 6 NEMA 5-15R output receptacles, Two independently switched output load banks ● Maintains uninterrupted operation of connected networking equipment during blackouts, surges, brownouts and overvoltages ● High 95% efficiency rating in line-power mode offers reduced power consumption and BTU emisssions ● Internal batteries offer 20.7 minutes at 50% load (300W) and 8.5 minutes at 100% load (600W) ● Extended runtime is available with optional BP24V15RT2U (limit 1), BP24V28-2U (limit 1), BP24V70-3U (multi-pack compatible) and BP24V36-2US (multi-pack compatible); Output is reduced to 450 watts maximum with external battery packs 1/6 ● SMART750RMXL2U UPS System ● USB, Serial & EPO cabling ● 4 post installation kit ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● External battery configurations require the use of Tripp Lite's External Battery Configuration Software (see manual) ● Hot-swappable, user-replaceable internal batteries and external battery packs can be replaced with no disruption to connected equipment ● Intelligent battery management system extends battery life ● Front panel LCD monitoring screen with MODE and ENTER buttons reports operating mode with 5-bar battery charge graphic, plus 7 selectable screens of detailed UPS and site power information ● LCD interface also supports a number of advanced user setup and operating preferences ● Ships with 4 post rackmount installation hardware; Optional 2POSTRMKITWM enables 2 post rackmount/wallmount installation; Optional 2-9USTAND enables tower placement ● Built-in USB, RS-232 and slot for optional Network Management Card options ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD and RELAYIOCARD ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Built-in Emergency Power Off (EPO) interface with cable Specifications OVERVIEW UPC Code 037332123527 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 7.5A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 10A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 750 Output Capacity (kVA) 0.75 Output Capacity (Watts) 600 Output Capacity (kW) 0.6 Output Capacity Details 6.3A. Output is reduced to 450 watts maximum when used with external battery packs 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Factor 0.8 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Frequency Compatibility Details Output is regulated to +/-0.05Hz when input frequency exceeds +/-5Hz of nominal. Output Voltage Regulation (Line Mode) -21%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Two switchable two-outlet 5-15R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 8.3 min. (600W) Runtime Half Load (min.) 20.7 min. (300W) Expandable Runtime Yes External Battery Pack Compatibility  BP24V15RT2U  (limit 1);  BP24V28-2U  (limit 1);  BP24V70-3U  (multi-pack compatible);  BP24V362US  (multi-pack compatible) DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge See Tripp Lite UPS Replacement battery selector Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 83 and 107 are boosted by 14% 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States USER INTERFACE, ALERTS & CONTROLS Switches 3 pushbutton switches control OFF / ON power status, MODE selection and MUTE / ENTER control functions Alarm Cancel Operation Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option available Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions LED Indicators Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data, plus configuration of voltage, operating mode, alarm function and a variety of additional options (see manual for detailed LCD configuration and monitoring options) SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to 914mm) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 43.18 Minimum Required Rack Depth (inches) 17 Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  2POSTRMKITWM  enables wall-mount and 2-post rackmount installation;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm);  UPSHDEARKIT  enables installation in 2 or 4-post racks using front vertical rails only, without rear support Primary UPS Depth (mm) 334 Primary UPS Height (mm) 88 Primary UPS Width (mm) 441 Shipping Dimensions (hwd / in.) 8.70 x 18.60 x 23.30 Shipping Dimensions (hwd / cm) 22.10 x 47.24 x 59.18 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 45.50 Shipping Weight (kg) 20.64 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 8.76 x 44.07 x 33.40 UPS Power Module Dimensions (hwd, in.) 3.45 x 17.35 x 13.15 UPS Power Module Weight (kg) 16.06 UPS Power Module Weight (lbs.) 35.4 Unit Weight (lbs.) 35.400 Unit Weight (kg) 16.06 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 109 AC Mode Efficiency Rating (100% Load) 95% AC Economy Mode Efficiency Rating (100% Load) 0.95 Operating Elevation (ft.) 6561 ft. (2000 m) above sea level Audible Noise 45 dBA maximum, front side 1m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX ;  RELAYIOCARD  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 4 milliseconds (AC to battery mode), 2 milliseconds (Battery to AC mode) 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Low Voltage Transfer to Battery Power (Setpoint) 83 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection Grounding Details Back panel grounding lug STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMART750RMXL2U 价格&库存
很抱歉,暂时无法提供与“SMART750RMXL2U”相匹配的价格&库存,您可以联系我们找货
