OMNI1000ISO
OMNI1000ISO
    TRIPPLITE
    UPS 1000VA 700W 6OUT USB TOWER
OMNI1000ISO 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States OmniSmart 120V 1000VA 700W Line-Interactive UPS, Tower, Built-In Isolation Transformer, USB port Highlights ● 1000VA / 1kVA tower 120V line interactive UPS with isolation transformer ● Corrects brownouts and overvoltages from 81V to 143V ● USB port, Normal & common mode EMI/RFI line noise immunity ● NEMA 5-15P input plug and 6 515R outlets MODEL NUMBER: OMNI1000ISO Package Includes Description Tripp Lite's OMNI1000ISO offers complete UPS protection with built-in line-interactive voltage regulation, intelligent monitoring and unattended shutdown capability. Built-in isolation transformer with Faraday shield offers full isolation and complete common mode noise rejection. 1000VA power-handling capacity supports point-of-sale applications, computers, internetworking equipment and home theater systems during commercial power failures. Line-interactive voltage regulation corrects brownouts as low as 81V and overvoltages as high as 143V back to normal 120V levels, reserving battery power for use during complete power failures. USB communications port works with PowerAlert Software and cabling to provide automatic unattended shutdown of connected network and PC applications. Features ● 1000VA line-interactive UPS with Faraday-shielded, low-impedance isolation transformer delivers full isolation from potential damage and performance problems ● Provides immunity from EMI/RFI line noise in both normal and common modes. Delivers clean signalreference ground, reducing data errors and audio/video distortion ● Automatic voltage regulation (AVR) automatically corrects incoming voltage to keep equipment working through low voltage (brownouts) as low as 81V and overvoltages as high as 143V without consuming battery power ● Supports loads up to 1000VA/700W ● Half-load runtime of 24 min. (500VA/350W); full load runtime of 8 min. (1000VA/700W) ● 5 diagnostic LEDs indicate AC present, on battery, voltage correction status, overload and battery low/replace ● Electrostatic discharge (ESD) resistance reduces potential static damage to connected electronics ● USB port enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Built-in surge suppression (backed by $200,000 Ultimate Lifetime Insurance U.S., Canada, and Puerto Rico only) safeguards connected equipment against damage ● SURGE VOLTAGE WITHSTAND CAPABILITY: ANSI/IEEE C62.41 Catagories A & B 6KV/200/500 amp 100Khz Ringwave and category B BiWave ● SURGE VOLTAGE ATTENUATION: N-G 2000:1, L-G 240:1, L-N 100:1 1/5 ● OMNI1000ISO UPS System ● USB cable ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● INSERTION LOSS: 65 db N-G from 10Khz to 100Khz, 45 to 60 db L-G from 10Khz to 100Khz, 18 to 54 db L-N from 50Khz to 500 Khz ● 6 UPS-supported AC outlets; 6-ft. cord ● Optional PDUB15 bypass PDU enables hot-swappable UPS replacement with no disruption to connected equipment Specifications OVERVIEW UPC Code 037332126931 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 7.6A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1000 Output Capacity (kVA) 1 Output Capacity (Watts) 700 Output Capacity (kW) 0.7 Output Capacity Details 5.8A @ 120V. 125% @ 10 minutes 110% +/- 10% @ 5 seconds Power Factor 0.7 Nominal Voltage Details 120V in line mode and 115V battery Frequency Compatibility 60 Hz Frequency Compatibility Details Output is regulated to +/-0.05Hz when input frequency exceeds +/-5Hz of nominal. Output Voltage Regulation (Line Mode) -18%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Hot-Swap PDU options PDUB15 (2U / 8 5-15R outlets) Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 8 min. (700W) Runtime Half Load (min.) 24 min. (350W) Expandable Runtime No DC System Voltage (VDC) 36 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC53  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 85 to 143 Overvoltage Correction Input voltages between 128 and 143V are reduced by 9% Undervoltage Correction Input voltages between 96 and 107V are boosted by 10% Severe Undervoltage Correction Input voltages between 85 and 95V are boosted by 20% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status ISOLATION Output Isolation Transformer Professional grade load isolation transformer Surge Voltage Withstand Capability ANSI/IEEE C62.41 Categories A & B 6KV/200/500 amp 100Khz Ringwave and category B BiWave Surge Voltage Attenuation N-G 2000:1, L-G 240:1, L-N 100:1 SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 510 UPS AC Suppression Response Time Instantaneous 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Installation Form Factors Supported with Optional Accessories Wallmount ( UPSWM  - tower mounting kit) Primary UPS Depth (mm) 234 Primary UPS Height (mm) 325 Primary UPS Width (mm) 191 Shipping Dimensions (hwd / in.) 16.90 x 13.50 x 11.30 Shipping Dimensions (hwd / cm) 42.93 x 34.29 x 28.70 Shipping Weight (lbs.) 46.10 Shipping Weight (kg) 20.91 UPS Housing Material PVC UPS Power Module Dimensions (hwd, cm) 32.51 x 19.05 x 23.37 UPS Power Module Dimensions (hwd, in.) 12.8 x 7.5 x 9.2 UPS Power Module Weight (kg) 16.51 UPS Power Module Weight (lbs.) 36.4 Unit Weight (lbs.) 36.4000 Unit Weight (kg) 16.51 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode Efficiency Rating (100% Load) 91% AC Economy Mode Efficiency Rating (100% Load) 0.91 Operating Elevation (ft.) 6561 ft. (2000 m) above sea level COMMUNICATIONS PowerAlert Software For local monitoring via the UPS’s built-in USB port, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB cable included 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Insertion Loss 65 db N-G from 10Khz to 100Khz, 45 to 60 db L-G from 10Khz to 100Khz, 18 to 54 db L-N from 50Khz to 500 Khz Network Management Card Description Network management not supported Communications Interface USB LINE / BATTERY TRANSFER Transfer Time 6 milliseconds typical (10 milliseconds max) Low Voltage Transfer to Battery Power (Setpoint) 81 High Voltage Transfer to Battery Power (Setpoint) 143 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries; Surge/noise protection STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $200,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
OMNI1000ISO 价格&库存
很抱歉,暂时无法提供与“OMNI1000ISO”相匹配的价格&库存,您可以联系我们找货
