SMART700DV
SMART700DV
    TRIPPLITE
    UPS SMART TOWER AVR 120V
SMART700DV 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 700VA 450W Line-Interactive Sine Wave UPS, Tower, 120 or 230V input, Network Card Options, USB, DB9 Highlights ● Maintains 120V output with 120V or 230V input ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule ● USB, RS232, DB9 and slot for Network Management Card options ● C14 inlet with NEMA 5-15P cable and 6 5-15R outlets ● Designed for commercial applications; see product description for home-use recommendations MODEL NUMBER: SMART700DV Package Includes Description Tripp Lite's dual-voltage SMART700DV line-interactive UPS system maintains 120V nominal output when fed with North American 120V or international 230V input voltage. Protects servers, networking accessories and telecommunications equipment from blackouts, voltage fluctuations and transient surges. Large internal batteries offer 54.5 min. half-load runtime and 22.2 min. full load runtime during power failures. 700VA/450W power handling capability supports a variety of networking, telecom and other applications, including multiple network workstations. Includes 6 UPS-supported outlets. Supports remote monitoring of UPS and site power conditions via built-in USB and RS-232 enabled DB9 ports. Works with PowerAlert UPS monitoring and unattended shutdown software available via free download. Includes complete USB and serial cabling. Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery low/replace, voltage regulation and load level. Network-grade AC surge suppression protects equipment from damage and performance problems resulting from transient surges. This product is designed with features typically required in commercial applications, including network connectivity and a ruggedized case. For home use, consider SMART750USB or SMART750TSU. Click to compare product features. Features ● Tripp Lite's dual-voltage SMART700DV line-interactive UPS system maintains 120V nominal output when fed with North American 120V or international 230V input voltage ● Includes detachable input cord with NEMA 5-15P input plug ● Built-in C14 inlet supports a variety of user-supplied international high- and low-voltage input cables ● Protects servers, networking accessories and telecommunications equipment from blackouts, voltage fluctuations and transient surges ● Large internal batteries offer 54.5 min. half-load runtime and 22.2 min. full load runtime during power failures ● Intelligent battery management system extends battery life ● 700VA/450W power handling capability supports a variety of networking, telecom and various other applications types, including multiple network workstations ● Includes 6 UPS-supported outlets ● Supports remote monitoring of UPS and site power conditions via built-in USB and RS-232 enabled DB9 ports 1/5 ● SMART700DV UPS System ● Detachable NEMA 5-15P power cord ● USB cabling and DB9 serial cabling ● Manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX and SNMPWEBCARD ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Includes complete USB and serial cabling ● Built-in audible alarm and 5 front panel LEDs indicate status of line power, battery power, battery low/replace, voltage regulation and load level ● Network-grade AC surge suppression protects equipment from damage and performance problems resulting from transient surges ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases This product is designed with features typically required in commercial applications, including network connectivity and a ruggedized case. For home use, consider SMART750USB or SMART750TSU. Click to compare product features. Specifications OVERVIEW UPC Code 037332126597 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 4.8A (120V), 2.6A (230V) Nominal Input Voltage(s) Supported 120V AC; 230V AC UPS Input Connection Type 5-15P; C14 inlet UPS Input Connection Description Detachable 120v 5-15P input cable included Input Circuit Breakers 6A UPS Input Cord Length (ft.) 6 UPS Input Cord Length (m) 1.8 OUTPUT Output Capacity (VA) 700 Output Capacity (kVA) 0.7 Output Capacity (Watts) 450 Output Capacity (kW) 0.45 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 50 / 60 Hz Frequency Compatibility Details Automatic frequency selection Output Voltage Regulation (Line Mode) -21%, +8% 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Voltage Regulation (Battery Mode) +/- 5% Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 22.2 min. (450W) Runtime Half Load (min.) 54.5 min. (225W) Expandable Runtime No DC System Voltage (VDC) 24 Battery Recharge Rate (Included Batteries) Less than 4 hours from 10% to 90% (typical, full load discharge) Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC54  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 147 (120V), 159 to 282 (230V) Overvoltage Correction A voltage reduction of 12% applies when input voltage is between 125 and 147 (120V), 240 to 282 (230V) Undervoltage Correction A voltage boost of 14% applies when input voltage is between 83 and 104 (120V), 159V and 199V (230V) USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 318 Primary UPS Height (mm) 259 Primary UPS Width (mm) 229 Shipping Dimensions (hwd / in.) 15.25 x 14.25 x 17.75 Shipping Dimensions (hwd / cm) 38.74 x 36.20 x 45.08 Shipping Weight (lbs.) 78.00 Shipping Weight (kg) 35.38 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 25.91 x 22.86 x 31.75 UPS Power Module Dimensions (hwd, in.) 10.2 x 9 x 12.5 UPS Power Module Weight (kg) 28.12 UPS Power Module Weight (lbs.) 62 Unit Weight (lbs.) 62.0000 Unit Weight (kg) 28.12 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 41 AC Mode Efficiency Rating (100% Load) 98% COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 83 (120v), 159 (230v) High Voltage Transfer to Battery Power (Setpoint) 147 (120v), 282 (230v) FEATURES & SPECIFICATIONS High Availability UPS Features Auto Probe Monitoring (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection STANDARDS & COMPLIANCE Product Certifications CSA (Canada); UL 1778 Product Compliance RoHS; CE (Europe); FCC Part 15 Class A (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SMART700DV
- 物料型号:SMART700DV - 器件简介:这是一款双电压智能在线互动式UPS系统,能够在北美120V或国际230V输入电压下维持120V的标称输出。 - 引脚分配:包括6个UPS支持的插座。 - 参数特性:700VA/450W的功率处理能力,支持多种网络、电信和其他应用,包括多个网络工作站。在电源故障期间,大型内部电池提供54.5分钟半载运行时间和22.2分钟全载运行时间。 - 功能详解:支持通过内置USB和RS-232启用的DB9端口远程监控UPS和现场电源条件。与PowerAlert® UPS监控和免费下载的无人值守关闭软件兼容。 - 应用信息:设计用于商业应用,包括网络连接和加固型机箱。对于家庭使用,可以考虑SMART750USB或SMART750TSU。 - 封装信息:塔式设计,支持通过内置USB和RS-232启用的DB9端口进行远程监控。
SMART700DV 价格&库存
很抱歉,暂时无法提供与“SMART700DV”相匹配的价格&库存,您可以联系我们找货
