SMART2200VS
SMART2200VS
    TRIPPLITE
    UPS SMARTPRO 2.2KVA 1600W 9OUT
SMART2200VS 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 2.2kVA 1.6kW Line-Interactive UPS, Tower, Network Card Options, USB, DB9 Serial Highlights ● 2.2kVA / 2200VA line interactive tower UPS system ● 120V nominal output during brownouts to 79V and overvoltages to 147V ● Front panel status LEDs with load and battery capacity level display ● USB, RS232, EPO and slot for Network Card Options ● NEMA 5-20P input; 2 NEMA 515/20R & 7 5-15R outlets ● To use the Auto Probe feature, this product requires a WEBCARDLX network interface (sold separately) running LX firmware update 15.5.2 or later MODEL NUMBER: SMART2200VS Package Includes Description Tripp Lite's SMART 2200VS intelligent, line interactive UPS protects server, networking and telecommunications equipment from blackouts, voltage fluctuations and transient surges. Small footprint, tower UPS system occupies only 106 square inches of floor space with a height of only 14.25 inches. Large capacity 2200 VA/ 1600 watt rated UPS system offers 7 minutes runtime at full load and 19 minutes at half load during power failures. Line interactive voltage regulation corrects brownouts as low as 79V and overvoltages as high as 147V to fully regulated 120V nominal output for smooth continuous operation of connected equipment. Includes a total of 9 outlets, 3 pairs of which can be individually powered off and back on via software interface to selectively reboot remote equipment or shed less critical loads to extend battery runtime for more critical loads. Includes 2 DB9 and 2 USB enhanced monitoring ports for unattended shutdown, remote control and monitoring of UPS system and power data. Ships in attractive gray color scheme. Compatible with Tripp Lite's PowerAlert and Watchdog service software. Features ● 2200VA/1600 watt output capacity accommodates a variety of server, networking and telecom devices ● High power density 2.2kVA UPS system occupies only 106 square inches of floor space with a height of only 14.25 inches ● Compatible with North American 120V/60 Hz power as found in the USA, Canada and Mexico ● Offers 7 minutes runtime with a full load of 2200VA and 19 minutes with a half load of 1100VA ● Intelligent battery management system extends battery life ● Line interactive voltage regulation corrects severe brownouts and overvoltages from 79 to 147v back to normal 120v levels without using battery power ● 9 total outlets (7 NEMA5-15R; 2 NEMA5-15/20R) ● Includes NEMA 5-20 straight blade 20 amp input plug connection ● Notification of system status via 5 LEDs and multi-function audible alarms ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX and SNMPWEBCARD ● Supports Tripp Lite's WatchDog software application to restore unresponsive programs by automatically 1/5 ● SMART 2200VS UPS System, ● USB and DB9 Serial cabling ● User manual 1000 Eaton Boulevard Cleveland, OH 44122 United States restarting them and rebooting completely locked computers by automatically switching UPS power off and back on again ● Communication ports support on battery, low battery, power restored, AC line voltage, DC battery voltage, load percentage, battery charge current, battery capacity, internal UPS temperature and line frequency status messaging. Interface supports timed inverter shutoff after unattended shutdown, activate self-test and 10 second reboot of connected equipment ● 3 pairs of customized load management receptacles can be individually powered off and back on again via software interface to reboot remote equipment or shed less critical loads to extend battery runtime for the most critical equipment ● Built-in Emergency Power Off (EPO) interface supports emergency shutoff in large facilities ● Hot-swappable/user replaceable batteries allow on-site battery replacement without powering off connected equipment ● UPS battery set ships fully assembled and ready for use, no time consuming, connection of individual internal batteries by user is necessary Specifications OVERVIEW UPC Code 037332115874 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 16A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-20P Input Circuit Breakers 20A UPS Input Cord Length (ft.) 8 UPS Input Cord Length (m) 2.4 Recommended Electrical Service 20A 120V OUTPUT Output Capacity (VA) 2200 Output Capacity (kVA) 2.2 Output Capacity (Watts) 1600 Output Capacity (kW) 1.6 Power Factor 0.73 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18% / +8% 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Three switchable two-outlet 5-15R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (7) 5-15R; (2) 5-15/20R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 7 min. (1600W) Runtime Half Load (min.) 19 min. (800W) Expandable Runtime No DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 4 hours from 10% to 90% (typical, full load discharge) Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC54  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 79V to 147V Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 95 and 104 are boosted by 12% Severe Undervoltage Correction Input voltages between 79 and 94 are boosted by 24% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure, overload and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 305 Primary UPS Height (mm) 361 Primary UPS Width (mm) 234 Shipping Dimensions (hwd / in.) 19.30 x 16.50 x 14.20 Shipping Dimensions (hwd / cm) 49.02 x 41.91 x 36.07 Shipping Weight (lbs.) 58.00 Shipping Weight (kg) 26.31 UPS Housing Material Polycarbonate UPS Power Module Dimensions (hwd, cm) 36.07 x 23.37 x 30.48 UPS Power Module Dimensions (hwd, in.) 14.2 x 9.2 x 12 UPS Power Module Weight (kg) 23.77 UPS Power Module Weight (lbs.) 52.4 Unit Weight (lbs.) 52.4000 Unit Weight (kg) 23.77 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode Efficiency Rating (100% Load) 94% Audible Noise Audible Noise < 47dBA At Front Side 1 Meter COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions; 2 USB ports, 1 DB9 serial and 1 DB9 contact closure port (4 total) 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable 2 USB and 2 DB9 cables included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface Contact closure; DB9 Serial; Slot for SNMP/Web interface; USB LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 79 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SMART2200VS 价格&库存
很抱歉,暂时无法提供与“SMART2200VS”相匹配的价格&库存,您可以联系我们找货
SMART2200VS
    库存:4
