SM1500RMXL2UTAA
SM1500RMXL2UTAA
    TRIPPLITE
    UPS SMART RACKMOUNT AVR USB DB9
SM1500RMXL2UTAA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States TAA SmartPro 120V 1.5kVA 1.35kW LineInteractive Sine Wave UPS, 2U, Extended Run, Network Card Options, LCD, USB, DB9 MODEL NUMBER: SM1500RMXL2UTAA Highlights ● Corrects under- and overvoltages from 83V to 145V ● 8 NEMA 5-15R outlets—4 switchable via network interface ● Network power management and control capability ● Expandable runtime with optional external battery packs ● 14 min. runtime at half load; 4.9 min. at full load ● To use the Auto Probe feature, this product requires a WEBCARDLX network interface (sold separately) running LX firmware update 15.5.2 or later Package Includes Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts, brownouts, power surges and line noise. Ideal solution for servers, storage devices and telecom hardware. Features Protects Mission-Critical Rack-Mounted Equipment ● Provides fully regulated sine wave AC output for servers, network storage devices and telecom hardware ● Audible alarm signals loss of utility power, overload, low battery and more ● 8 NEMA 5-15R outlets ● 10-ft. (3.05 m) power cord with 120V NEMA 5-15P input ● 570-joule surge suppression rating Reliable Battery Backup with Expandable Runtime ● Supports half load up to 14 min. and full load up to 4.9 min. ● Internal batteries designed for hot-swap field replacement ● Expandable runtime with optional external battery packs, such as Tripp Lite's BP36V15-2U ● 95% line-power efficiency rating saves money in energy costs Switchable Outlets ● 2 load banks, each with 2 outlets controllable remotely to reboot equipment or shed nonessential loads Automatic Voltage Regulation (AVR) ● Maintains 120V nominal output over input range of 83V-145V without using battery power EMI/RFI Line Noise Filtering ● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment's 1/6 ● SM1500RMXL2UTAA SmartPro 120V 1.5kVA 1.35kW LineInteractive Sine Wave UPS ● USB cable ● DB9 cable ● EPO cable ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States performance Interactive LCD Screen ● Front-panel LCD monitors power status, operating data, voltage, alarm and other options ● Rotates for easy viewing in rack-mount or tower configurations Optional Network Management Cards ● Compatible with Tripp Lite UPS management cards, including TLNETCARD, WEBCARDLX and SNMPWEBCARD Communications Ports ● USB and DB9 ports enables data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● EPO port supports emergency shutdown in large facilities Versatile Installation Options ● Hardware included for 4-post mounting in 2U of EIA-standard 19 in. rack ● Mounts on wall or 2-post rack with optional 2POSTRMKITWM accessory ● Mounts in upright tower position with optional 2-9USTAND accessory ● Mounts to front rails of 2- or 4-post rack with optional UPSHDEARKIT accessory TAA Compliant ● Complies with Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332152831 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 15A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 15A 120V OUTPUT 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 1350 Output Capacity (kW) 1.35 Output Capacity Details Output is reduced to 1200 watts maximum when used with external battery packs Power Factor 0.9 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -14%, +6% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Two switchable two-outlet 5-15R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (8) 5-15R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.9 min. (1350W) Runtime Half Load (min.) 14 min. (675W) Expandable Runtime Yes External Battery Pack Compatibility  BP36V15-2U  (limit 1);  BP36V42-3U  (multi-pack compatible);  BP36V27-2US  (multi-pack compatible) DC System Voltage (VDC) 36 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC93-2U  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 145 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Overvoltage Correction Input voltages between 127 and 145 are reduced by 12% Undervoltage Correction Input voltages between 95 and 108 are boosted by 12% Severe Undervoltage Correction Input voltages between 83 and 94 are boosted by 24% USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data, plus configuration of voltage, operating mode, alarm function and a variety of additional options (see manual for detailed LCD configuration and monitoring options) Switches 3 pushbutton switches control OFF / ON power status, MODE selection and MUTE / ENTER control functions Alarm Cancel Operation Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option available Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to 914mm) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 43.18 Minimum Required Rack Depth (inches) 17 Minimum Required Rack Depth with External Battery Pack (cm) 51 Minimum Required Rack Depth with External Battery Pack (in.) 20 Minimum Required Rack Depth without External Battery Pack (cm) 42 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Minimum Required Rack Depth without External Battery Pack (in.) 16.5 Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  2POSTRMKITWM  enables wall-mount and 2-post rackmount installation;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm);  UPSHDEARKIT  enables installation in 2 or 4-post racks using front vertical rails only, without rear support Primary UPS Depth (mm) 342 Primary UPS Height (mm) 88 Primary UPS Width (mm) 439 Shipping Dimensions (hwd / in.) 8.80 x 23.00 x 19.30 Shipping Dimensions (hwd / cm) 22.35 x 58.42 x 49.02 Shipping Weight (lbs.) 57.40 Shipping Weight (kg) 26.04 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 8.76 x 43.94 x 34.16 UPS Power Module Dimensions (hwd, in.) 3.45 x 17.3 x 13.45 UPS Power Module Weight (kg) 21.09 UPS Power Module Weight (lbs.) 46.5 Unit Weight (lbs.) 46.5000 Unit Weight (kg) 21.09 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 237 Battery Mode BTU / Hr. (Full Load) 751 AC Mode Efficiency Rating (100% Load) 95% Audible Noise 45 dBA maximum, front side 1m COMMUNICATIONS Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network UPS Tools (NUT) Compatibility NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 4 milliseconds (AC to battery mode), 1 millisecond (Battery to AC mode) Low Voltage Transfer to Battery Power (Setpoint) 83 High Voltage Transfer to Battery Power (Setpoint) 145 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS; Individually controllable load banks Grounding Lug Back panel grounding lug STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class B (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SM1500RMXL2UTAA
物料型号: - 型号编号:SM1500RMXL2UTAA
器件简介: - TAA SmartPro 120V 1.5kVA 1.35kW Line-Interactive Sine Wave UPS,2U设计,延长运行时间,可选网络卡,LCD显示屏,USB和DB9接口。 - 保护连接的关键任务设备免受停电、电压暂降、电源浪涌和线路噪声造成的损害、停机和数据丢失。是服务器、存储设备和电信硬件的理想解决方案。
引脚分配: - NEMA 5-15R接口:4个可通过网络接口切换的开关 - USB和DB9通信端口:用于数据保存和无人值守关机,与PowerAlert软件配合使用 - EPO端口:支持大型设施的紧急关机
参数特性: - 输入相位:单相 - 额定输入电流(最大负载):12A - 额定输入电压:120V AC - 输出容量(VA):1500 - 输出容量(kVA):1.5 - 扩展运行时间:支持通过可选的外接电池包扩展运行时间 - 95%的线电效率:节省能源成本
功能详解: - 提供全调节正弦波交流输出,适用于服务器、网络存储设备和电信硬件 - 支持远程控制重启设备或减少非关键负载的2个负载组,每个负载组有2个接口 - 自动电压调节(AVR):在83V-145V输入范围内保持120V额定输出,不使用电池电源 - EMI/RFI线路噪声过滤:消除可能干扰或损坏设备性能的电磁和射频干扰
应用信息: - UPS应用:大型网络;高端桌面/小型网络
封装信息: - 主要形态因素:机架式安装 - 机架高度:2U - 冷却方式:风扇 - 包括的安装配件描述:包括的4POSTRAILKIT安装支架支持在20.5到36英寸(521到914毫米)的4柱机架中安装 - 支持的安装形态因素(包括配件):4柱19英寸机架式安装 - 支持的安装形态因素(可选配件):2柱机架式安装;2-4柱前轨机架式安装;4柱短深度机架式安装;塔式安装;壁挂式安装
SM1500RMXL2UTAA 价格&库存
很抱歉,暂时无法提供与“SM1500RMXL2UTAA”相匹配的价格&库存,您可以联系我们找货
