SU1500XLCD
SU1500XLCD
    TRIPPLITE
    UPS SMART ONLINE
SU1500XLCD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton Tripp Lite series SmartOnline 120V 1.5kVA 1.35kW Double-Conversion UPS, Tower, Extended Run, Network Card Options, LCD, USB, DB9 MODEL NUMBER: SU1500XLCD Highlights ● 1500VA / 1.5kVA / 1350 watt on-line double-conversion tower UPS ● 100/110/120/127V 50/60Hz output, 97% efficiency economy mode option ● Interactive LCD with 10 selectable screens of UPS and site power data ● USB, RS232 & EPO ports, slot for network management card options ● Expandable runtime, Hotswappable batteries ● 2 independently switchable load banks ● NEMA 5-15P input; 6 5-15R outlets ● To use the Auto Probe feature, this product requires a WEBCARDLX network interface (sold separately) running LX firmware update 15.5.2 or later Package Includes Description Do you need to protect small- to medium-size servers, networking equipment and telecom systems against data loss, downtime and equipment damage due to power outages, voltage fluctuations and transient surges? Tripp Lite’s SU1500XLCD SmartOnline® Tower UPS System is the solution! Featuring a 1500VA/1350W capacity and true on-line operation with pure sine wave output and zero transfer time to battery, it provides the highest level of power protection for mission-critical equipment. The SU1500XLCD’s large internal battery set supports connected equipment during blackouts, and runtime is expandable with optional external battery packs BP48V60RT-3U and BP48V27-2US, sold separately. The SU1500XLCD has 6 5-15R outlets, including 2 load banks of 3 outlets each that are individually controllable to reboot select equipment on demand or maximize battery runtime for mission-critical equipment. USB and DB9 communication ports support messaging of detailed UPS operational parameters and line power status. PowerAlert UPS management software is available via free download. The SU1500XLCD also accepts an optional network management card. It comes backed by $250,000 of Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only). Features Ideal for Protection of Mission-Critical EquipmentThe SU1500XLCD provides true on-line operation, reliable battery backup and comprehensive power management capability in a compact tower form factor. Featuring a 1500VA/1350W capacity, 6 5-15R outlets, a 10-ft. cord with standard 5-15P plug, USB/DB9 ports and a slot for an optional network management card, SU1500XLCD offers a complete power protection solution for small- to medium-size servers, storage devices, telecom systems and other mission-critical equipment. True On-Line Operation with Pure Sine Wave Output and Zero Transfer TimeThe SU1500XLCD provides the highest level of protection available for mission-critical equipment. It actively converts raw incoming AC power to DC, then re-converts it back to regulated, filtered AC output with a pure sine wave, completely isolating connected components from all power problems. Zero transfer time between AC and battery operation maintains continuous output and further protects connected equipment from the disruptive effects of blackouts and severe low-voltage conditions. Sine wave output guarantees compatibility with all equipment types. Individually Controllable OutletsThe SU1500XLCD includes 2 load banks of 3 outlets each that are 1/7 ● SU1500XLCD SmartOnline® Tower UPS System ● USB, DB9 and EPO Cabling ● Owner’s Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States individually controllable via a software interface for remote reboot of locked-up equipment or load shedding to maximize battery backup time for mission-critical equipment. Reliable, Expandable Battery BackupUPS battery backup keeps connected equipment operational through short power failures, and provides time to save data and perform an orderly system shutdown in case of a prolonged blackout. The SU1500XLCD features a large internal battery set that provides 14 minutes of battery support for a half load (675 watts) and 4.5 minutes for a full load (1350 watts). Intelligent battery management system extends battery life. During normal operation, incoming utility power keeps the UPS battery fully charged so that backup power will always be available if needed. For mission-critical applications demanding continuous uptime, the fully scalable SU1500XLCD can provide expandable runtime with optional external battery packs BP48V60RT-3U and BP48V27-2US, sold separately. High Power Factor and Highly Efficient Operation Reduces BTU OutputThe SU1500XLCD features a high 0.9 power factor and an optional, highly efficient economy mode setting that can significantly reduce a facility’s energy costs. In economy mode, the UPS operates with 97% efficiency, minimizing heat output, reducing cooling requirements and consuming less electricity. AC Line and Tel/Ethernet Surge SuppressionA sudden power surge or spike can damage or destroy electronic components and wipe out irreplaceable data. The SU1500XLCD features a 570-joule surge suppression rating to protect connected components and data from the harmful effects of power surges. One set of tel/Ethernet (RJ45) jacks provides surge protection for a standard phone or network connection (cable not included). EMI/RFI Line Noise FilteringVarious electrical and radio sources can cause disruptive interference on the AC line. This line noise is a common cause of incremental hardware damage, data corruption and audio/video performance problems. The SU1500XLCD incorporates technology that filters out disruptive line noise, preventing it from affecting your equipment. LCD Screen and Audible AlarmThe SU1500XLCD features a front-panel LCD screen that enables IT personnel to monitor line power, on-line mode, bypass mode, on-battery, overload, battery low, replace battery and fault status information. It is supplemented by an audible alarm that signals UPS startup, power failure, low battery, overload, UPS fault and remote shutdown conditions. USB/DB9 Ports, SNMP Capability and Included PowerAlert SoftwareSU1500XLCD includes HIDcompliant USB interface that enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. USB and DB9 ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert. Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX, SNMPWEBCARD, MODBUSCARD and RELAYIOCARD. Emergency Power Off (EPO) CapabilityThe SU1500XLCD features an EPO interface port that supports emergency shutoff in large facilities (cable included). Peace of MindThe SU1500XLCD comes with $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) for connected equipment. Specifications OVERVIEW UPC Code 037332174642 UPS Type On-Line INPUT Input Phase Single-Phase 2/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 100V AC; 110V AC; 120V AC; 127V AC Nominal Input Voltage Description 120V factory default UPS Input Connection Type 5-15P Input Circuit Breakers 15A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 1350 Output Capacity (kW) 1.35 Output Capacity Details ON LINE MODE: Maximum output capacity rating is reduced to 1215W (115V), 1148W (110V) and 1080W (100V); FREQUENCY REGULATION / CONVERSION MODE: Maximum output ratings are reduced in frequency regulation / conversion mode (127/120V 945 watts, 115V 851 watts, 110V 804 watts, 100V 756 watts). OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% load for 3 minutes; 150% load for 30 seconds and >150% load for 0.5 seconds before switching to BYPASS (when bypass input voltage and frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE bypass limits) Power Factor 0.9 Crest Factor 3:1 Nominal Voltage Details 120V default Frequency Compatibility 50 / 60 Hz; Supports 50 to 60 Hz and 60 to 50 Hz conversion Frequency Compatibility Details ON LINE MODE: Output frequency is automatically configured to match nominal input frequency on startup; Output matches input frequency when +/-5Hz of nominal; Output is regulated to +/-0.05Hz when input frequency exceeds +/-5Hz of nominal. UPS switches to battery mode when input frequency is below 40Hz or above 70Hz. FREQUENCY REGULATION / CONVERSION MODE: Output is regulated to +/-0.05Hz of selected output frequency when input is 40 to 70Hz; UPS switches to battery mode when input frequency is below 40Hz or above 70Hz. BATTERY MODE: Output is regulated to +/-0.05Hz of selected nominal. Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 3% Load Management Receptacles Two switchable three-outlet load banks Output AC Waveform (AC Mode) Pure Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 100V; 110V; 115V; 120V; 127V Output Receptacles (6) 5-15R 3/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.5 min. (1350W) Runtime Half Load (min.) 14 min. (675W) Expandable Runtime Yes Expandable Runtime Description External battery configurations require the use of Tripp Lite's External Battery Configuration Software, see manual for details External Battery Pack Compatibility  BP48V27-2US  (multi-pack compatible);  BP48V60RT-3U  (multi-pack compatible) DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 3 hours from 10% to 90% (typical, full load discharge) Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC48-SUTWR  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction 2% output voltage regulation during overvoltages to 150 Undervoltage Correction 2% output voltage regulation during undervoltages to 55V (33% load), 70V (70% load), 100V (100% load) USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data, plus configuration of voltage, frequency, operating mode, alarm function and a variety of additional options Switches 2 switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option available Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 UPS AC Suppression Response Time Instantaneous UPS Dataline Suppression 1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet EMI / RFI AC Noise Suppression Yes PHYSICAL 4/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 495 Primary UPS Height (mm) 259 Primary UPS Width (mm) 229 Shipping Dimensions (hwd / in.) 14.80 x 12.90 x 23.30 Shipping Dimensions (hwd / cm) 37.59 x 32.77 x 59.18 Shipping Weight (lbs.) 55.00 Shipping Weight (kg) 24.95 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 25.91 x 22.86 x 49.53 UPS Power Module Dimensions (hwd, in.) 10.2 x 9 x 19.5 UPS Power Module Weight (kg) 23.72 UPS Power Module Weight (lbs.) 52.3 Unit Weight (lbs.) 48.5000 Unit Weight (kg) 22.00 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 512 AC Economy Mode BTU / Hr. (Full Load) 142 Battery Mode BTU / Hr. (Full Load) 814 AC Mode Efficiency Rating (100% Load) 90% AC Economy Mode Efficiency Rating (100% Load) 97% Audible Noise < 50.5 dB at front side 1m Operating Elevation (m) Up to 3000m COMMUNICATIONS 5/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX ;  MODBUSCARD ;  RELAYIOCARD  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions; DB9 port supports RS232 and contact closure communications PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Network Management Card Description Network management card optional Communications Interface Contact closure; DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time Zero transfer time (0 ms.) in online, double-conversion and frequency regulation / conversion modes Low Voltage Transfer to Battery Power (Setpoint) 55V (33% load), 70V (70% load), 100V (100% load) High Voltage Transfer to Battery Power (Setpoint) 150 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (requires WEBCARDLX); Automatic inverter bypass; Hot swappable batteries; Remote management; Surge/noise protection; Zero transfer time Green Energy-Saving Features High efficiency economy mode operation; Individually controllable load banks; Schedulable daily hours of economy mode operation STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  6/7 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 7/7
SU1500XLCD 价格&库存
很抱歉,暂时无法提供与“SU1500XLCD”相匹配的价格&库存,您可以联系我们找货
