SMART2200SLT
SMART2200SLT
    TRIPPLITE
    UPS SMART TOWER AVR SERVERS
SMART2200SLT 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 2.2kVA 1.6kW Line-Interactive Sine Wave UPS, Tower, Network Card Options, USB, DB9 Highlights ● 2.2kVA / 2200VA line interactive tower UPS; Sine wave output ● 120V nominal output during brownouts to 83 and overvoltages to 145V ● USB, RS232, EPO and slot for Network Management Card options ● Front panel status LEDs with detailed load and battery capacity display ● NEMA 5-20P input; 6 NEMA 515/20R & 1 L5-20R outlets MODEL NUMBER: SMART2200SLT Package Includes Description 2200VA line-interactive tower UPS system for server, networking and telecommunications equipment. Upright tower form factor. Offers sine wave 120V nominal output in both AC and battery modes. Switches to battery-derived AC output during power failures and extreme voltage variations. Line-interactive automatic voltage regulation (AVR) provides voltage boost/cut during brownouts/overvoltages to maintain regulated 120V nominal output over an input voltage range of 83-145V. Includes NEMA 5-20P input plug and 7 UPS-supported (6 x 5-15/20R & 1 L5-20R) output receptacles. Network-grade AC surge and noise suppression. Network management interfaces support simultaneous communications via USB port, DB9 serial port and slot for Network Management Card option. HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X. Supports simultaneous detailed monitoring of equipment load levels, self-test data and utility power conditions via all three network interfaces. PowerAlert UPS management software is available via free download. Three-stage metered current monitoring and battery charge status LEDs. Utility power and voltage regulation, and battery warning LEDs. Audible alarm. Self-test. Field-replaceable, hot-swappable internal batteries. Attractive all-black color scheme. Features ● SmartPro line-interactive UPS system is ideal for voice, data, medical and industrial networking applications ● Line-interactive voltage regulation maintains selectable 120V nominal output during brownouts as low as 83V and overvoltages to 145V ● Enables continuous operation through blackouts, voltage fluctuations and surges ● Line-interactive automatic voltage regulation (AVR) provides 12% and 24% voltage boost during brownouts and a 12% voltage cut during overvoltages ● Standard internal battery set offers 13 min. runtime at half load (800W) and 5 min. at full load (1600W) ● Intelligent battery management system extends battery life ● Space-saving upright tower format ● Network interfaces support simultaneous communications via built-in USB port, DB9 serial port and slot for Network Management Card option; Compatible with Tripp Lite UPS management card options WEBCARDLX, SNMPWEBCARD and RELAYIOCARD ● HID-compliant USB interface enables integration with built-in power management and auto shutdown features of Windows and Mac OS X 1/5 ● SMART2200SLT UPS System ● USB and DB9 cables ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● UPS interface supports on-battery, low-battery, power-restored, AC-voltage, DC-voltage, output current monitoring, battery charge current, battery capacity, timed inverter shutoff, activate self-test and output power control ● NEMA 5-20P input plug/6 x NEMA 5-15R and 1 x NEMA L5-20R output receptacles ● Front panel LEDs provide current monitoring, voltage regulation, battery charge level, and battery warning information ● UPS ships fully assembled in full compliance with DOT regulations; no time-consuming connection of internal batteries by user required Specifications OVERVIEW UPC Code 037332125774 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 14.8A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-20P Input Circuit Breakers 20A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 20A 120V OUTPUT Output Capacity (VA) 2200 Output Capacity (kVA) 2.2 Output Capacity (Watts) 1600 Output Capacity (kW) 1.6 Power Factor 0.7 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18% / +8% Output Voltage Regulation (Battery Mode) +/- 5% Output AC Waveform (AC Mode) Sine wave 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (6) 5-15/20R; (1) L5-20R Individually Controllable Load Banks No BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 5 min. (1600W) Runtime Half Load (min.) 13 min. (800W) Expandable Runtime No DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% (typical, full load discharge) Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC54  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83V to overvoltages to 145V Overvoltage Correction Input voltages between 127 and 145 are reduced by 12%; Voltage setpoints subject to ±5% tolerance Undervoltage Correction Input voltages between 96 and 108V are boosted by 12%; Voltage setpoints subject to ±5% tolerance Severe Undervoltage Correction Input voltages between 83 and 95V are boosted by 24%; Voltage setpoints subject to ±5% tolerance USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch Audible Alarm Audible alarm indicates power failure and overload conditions LED Indicators 9 LEDs indicate line power, battery power, AVR, overload and replace battery status - with a 3-LED level meter for load and battery charge level SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Primary Form Factor Tower Cooling Method Fan Installation Form Factors Supported with Included Accessories Tower Primary UPS Depth (mm) 318 Primary UPS Height (mm) 267 Primary UPS Width (mm) 226 Shipping Dimensions (hwd / in.) 15.40 x 14.30 x 17.20 Shipping Dimensions (hwd / cm) 39.12 x 36.32 x 43.69 Shipping Weight (lbs.) 69.10 Shipping Weight (kg) 31.34 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 26.67 x 22.61 x 31.75 UPS Power Module Dimensions (hwd, in.) 10.5 x 8.9 x 12.5 UPS Power Module Weight (kg) 25.85 UPS Power Module Weight (lbs.) 57 Unit Weight (lbs.) 57.0000 Unit Weight (kg) 25.85 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 287 Battery Mode BTU / Hr. (Full Load) 889 AC Mode Efficiency Rating (100% Load) 95% Audible Noise Audible Noise < 50 dBA at Front Side 1 Meter COMMUNICATIONS Network Management Cards SNMPWEBCARD;  WEBCARDLX ;  RELAYIOCARD  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable USB and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Network Management Card Description Network management card optional Communications Interface DB9 Serial; EPO (emergency power off); Slot for SNMP/Web interface; USB (HID enabled) LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 83V (±5% tolerance) High Voltage Transfer to Battery Power (Setpoint) 145V (±5% tolerance) FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SMART2200SLT 价格&库存
很抱歉,暂时无法提供与“SMART2200SLT”相匹配的价格&库存,您可以联系我们找货
