SUINT1500LCD2U
SUINT1500LCD2U
    TRIPPLITE
    INTL UPS SYSTEM SMART
SUINT1500LCD2U 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton Tripp Lite series SmartOnline 208/230V 1500VA 1.35kW Double-Conversion UPS - 6 Outlets, Extended Run, Card Slot, LCD, USB, DB9, 2U MODEL NUMBER: SUINT1500LCD2U Highlights ● Offers network-grade protection against power failures and voltage fluctuations ● Zero transfer time between online and battery modes for uninterrupted operation ● Optional external battery packs provide additional runtime for applications requiring it ● Optional WEBCARDLX with latest version of PADM20 supports Auto Probe feature ● ENERGY STAR-certified to save electricity, lower costs, and protect the environment Applications On-line double-conversion UPS provides pure sine wave AC output to server and network equipment in data centers and computer rooms. ● Deliver perfectly regulated sine wave output to mission-critical equipment ● Protect connected components from dangerous surges, spikes and line noise ● Keep equipment operational through power failures ● Allow time to save data and safely shut down components in case of a prolonged blackout Features Double-Conversion UPS Protects Equipment against Damage, Downtime and Data Loss This 200/208/220/230/240V 50/60 Hz UPS system maintains perfect output by converting AC input to DC, then reconverting UPS output to fully regulated sine wave AC with +/-2% voltage regulation in online and battery modes. Featuring a 1350W capacity, high 0.9 power factor, 936 joules of surge suppression, true on-line operation with pure sine wave output and zero transfer time to battery mode in on-line doubleconversion mode, the SmartOnline® SUINT1500LCD2U double-conversion UPS provides the highest level of AC power protection and battery backup for critical network closet, computer room and data center equipment. Set Power Strategies to Reflect Your Protection Priorities Pick your power strategy, from precise power for sensitive systems to the highest possible electrical efficiency, while ensuring 100% uptime. Choose from five selectable strategies: Max Efficiency, Max Quality, Frequency Regulation, Frequency Conversion and Auto Adaptive, which automatically offers increased efficiency when power conditions are good and enhanced power quality when power conditions are poor. Individually Controllable Load Banks Let You Access and Control Outlets Remotely Four C13 outlets are split evenly into two switchable load banks, allowing you to reboot select components or shed loads remotely. In addition to those four outlets, this UPS provides two more C13 outlets in their own unswitched bank for powering critical components. Reliable, Expandable Battery Backup Keeps You Operational Through Power Outages The field-replaceable, hot-swappable internal battery (RBC36S) provides 12.6 minutes of support at half load (675W) and 4.5 minutes at full load (1350W), keeping protected equipment operational through power failures. For mission-critical applications demanding scalable extended runtime, the UPS supports “smart” external battery packs, such as Tripp Lite’s BP36V15-2U (sold separately). Both the internal and external batteries are automatically sensed and configured during replacement to offer accurate runtimeremaining and battery age notifications during outages. The intelligent battery management system with temperature-compensated charging extends battery life. 1/7 Package Includes ● SUINT1500LCD2U SmartOnline Double-Conversion UPS ● USB cable ● RS-232 cable ● EPO cable ● (2) C13-to-C14 power cables ● 4-post rack-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Automatic Bypass Maintains Utility Output During Fault Conditions Auto-bypass mode keeps connected equipment powered and operational, even during UPS fault conditions. ENERGY STAR-Certified Economy Mode Helps You Save Money and Protect the Environment By meeting strict EPA efficiency guidelines, this ENERGY STAR-certified UPS system helps you save money and energy. A power-saving Economy mode setting option offers enhanced efficiency and reduced BTU output when utility power is already high quality. Automatically Turns Back On After Power Is Restored Battery-independent restart ensures automatic UPS power-up without user interaction after lengthy power outages, even when batteries are expired and require replacement. Intuitive Front-Panel Interface for Convenient UPS Operation and Monitoring The front-panel LCD screen reports UPS operating mode, detailed UPS status and site-power information, as well as a variety of advanced UPS setup and configuration options. LEDs indicate AC input/output, battery and fault status. Advanced Communications Ports Allow for Automatic Saves and Shutdowns RS-232 and HID-compliant USB ports connect to a computer running Tripp Lite’s free downloadable PowerAlert® software to enable safe unattended file saves and system shutdown in case of a prolonged power failure. An EPO port connects the UPS to a contact closure switch to enable emergency inverter shutdown. Cables are included. Optional WEBCARDLX Network Interface Offers 24/7 Access The optional WEBCARDLX (sold separately) with the latest version of PowerAlert Device Manager firmware (PADM20) provides enhanced remote management capabilities, including customizable dashboard graphs to fit user preferences. The PADM20 upgrade and Tripp Lite’s PowerAlert Element Manager (PAEM) software form a powerful tool for expanding maintenance functions in large installations, including firmware update checks and backup and restoration of device configurations. Auto Probe allows a UPS with switched loads to automatically reboot devices if a network communication failure is detected. This preserves uptime and minimizes the time and expense associated with on-site support. Versatile Installation Options Hardware is included for mounting the UPS system in 2U of space in an EIA-standard 19-inch 4-post rack. Use the optional 2POSTRMKITWM (sold separately) for 2-post rack mounting or the optional 2-9USTAND (sold separately) for mounting in an upright tower position. The C14 power inlet accepts a variety of usersupplied input cords. Specifications OVERVIEW UPC Code 037332248077 UPS Type On-Line INPUT Input Phase Single-Phase Rated input current (Maximum Load) 7.49A Nominal Input Voltage(s) Supported 200V AC; 208V AC; 220V AC; 230V AC; 240V AC 2/7 1000 Eaton Boulevard Cleveland, OH 44122 United States UPS Input Connection Type C14 inlet OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 Output Capacity (Watts) 1350 Output Capacity (kW) 1.35 Output Capacity Details DE-RATING INFORMATION: Max output in Frequency Conversion mode is reduced to 945 watts for 208/220/230/240V output voltages; Max output is 1080W (756W in Frequency Conversion mode) at 200V output voltage OVERLOAD CAPACITY: Supports inverter operation up to 105% load continuously, 125% for 3 minutes, 150% for 30 seconds and >150% for 0.5 seconds before switching to BYPASS (when bypass input voltage and frequency are WITHIN bypass limits) or SHUTDOWN (when bypass input voltage or frequency are OUTSIDE bypass limits). Power Factor 0.9 Crest Factor 3:1 Nominal Voltage Details Nominal output voltage is user configured on first power-on Frequency Compatibility 50 / 60 Hz; Supports 50 to 60 Hz and 60 to 50 Hz conversion Frequency Compatibility Details Output frequency matches input nominal on startup; Output capacity de-rates by 30% during frequency conversion operation Output Voltage Regulation (Line Mode) +/- 2% Output Voltage Regulation (Economy Line Mode) +/- 10% Output Voltage Regulation (Battery Mode) +/- 2% Included Output Power Cables Includes 2 C13 to C14 power cables Load Management Receptacles Two switchable 2-outlet load banks Output AC Waveform (AC Mode) Pure Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 200V; 208V; 220V; 230V; 240V Output Receptacles (6) C13 Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.5 min. (1350W) Runtime Half Load (min.) 12.6 min. (675W) Expandable Runtime Yes 3/7 1000 Eaton Boulevard Cleveland, OH 44122 United States External Battery Pack Compatibility  BP36V15-2U  (limit 1);  BP36V27-2US  (multi-pack compatible);  BP36V42-3U  (multi-pack compatible) DC System Voltage (VDC) 36 Battery Recharge Rate (Included Batteries) Less than 5.8 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC36S  Battery Replacement Description Hot-swappable, replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Online, double-conversion power conditioning Overvoltage Correction 2% output voltage regulation during overvoltages to 288V Undervoltage Correction 2% output voltage regulation during undervoltages to 160V (100% load), 130V (70% load), 100V (30% load) USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Interactive front-panel LCD interface reports UPS operating mode, detailed UPS status and site-power information; LCD interface also enables a variety of advanced UPS setup and configuration options Switches 5 front panel switches: On/Off, Up, Down and Escape Alarm Cancel Operation Power-fail alarm can be silenced by following on-screen prompts Audible Alarm Audible alarm indicates power failure, low battery, overload and fault LED Indicators 4 front panel LEDs: AC input (green), AC output (green), Battery (yellow), Fault (red) SURGE / NOISE SUPPRESSION UPS Dataline Suppression Details Single line dialup / network dataline protection included EMI / RFI AC Noise Suppression Yes AC Suppression Joule Rating 936 AC Suppression Response Time Instantaneous PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to 914mm) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount 4/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 58.42 Minimum Required Rack Depth (inches) 23 Minimum Required Rack Depth with External Battery Pack (cm) 67 Minimum Required Rack Depth with External Battery Pack (in.) 26.5 Minimum Required Rack Depth without External Battery Pack (cm) 58 Minimum Required Rack Depth without External Battery Pack (in.) 23 Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  2POSTRMKITWM  enables wall-mount and 2-post rackmount installation;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm);  UPSHDEARKIT  enables installation in 2 or 4-post racks using front vertical rails only, without rear support Primary UPS Depth (mm) 496 Primary UPS Height (mm) 88 Primary UPS Width (mm) 438 Shipping Dimensions (hwd / in.) 9.45 x 22.24 x 27.56 Shipping Dimensions (hwd / cm) 24.00 x 56.49 x 70.00 Shipping Weight (lbs.) 58.00 Shipping Weight (kg) 26.31 UPS Housing Material Metal UPS Power Module Dimensions (hwd, cm) 8.79 x 43.79 x 49.61 UPS Power Module Dimensions (hwd, in.) 3.46 x 17.24 x 19.53 UPS Power Module Weight (kg) 20.36 UPS Power Module Weight (lbs.) 44.88 Unit Weight (lbs.) 44.8800 Unit Weight (kg) 20.36 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) 5/7 1000 Eaton Boulevard Cleveland, OH 44122 United States Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 5 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 330 AC Economy Mode BTU / Hr. (Full Load) 142 Battery Mode BTU / Hr. (Full Load) 689 AC Mode Efficiency Rating (100% Load) >93% AC Economy Mode Efficiency Rating (100% Load) >97% Audible Noise
SUINT1500LCD2U
物料型号:SUINT1500LCD2U 器件简介:1500VA/1350W的双转换UPS,提供8个输出插座,具有LCD显示,USB和DB9接口,2U机架/塔式设计。
引脚分配:8个C13输出插座,其中4个分为两组可切换的双插座负载银行。
参数特性:输入电压支持200V至240V AC,额定输入电流为7.2A,输出功率因数为0.9,峰值因子为3:1。
功能详解:提供不间断电源保护,防电磁和射频干扰,具有清晰的LCD界面,支持远程管理和控制。
应用信息:适用于教育、医疗保健、军事、政府和其他关键任务IT应用。
封装信息:2U机架/塔式设计,金属外壳,支持4柱19英寸机架安装和塔式安装。
以上信息来源于PDF文档,涵盖了您请求的各个部分的详细信息。
SUINT1500LCD2U 价格&库存
很抱歉,暂时无法提供与“SUINT1500LCD2U”相匹配的价格&库存,您可以联系我们找货
