SMART2200VSXL
SMART2200VSXL
    TRIPPLITE
    UPS SMARTPRO 2.2KVA 1600W 10OUT
SMART2200VSXL 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 2.2kVA 1.6kW Line-Interactive UPS, Tower, Extended Run, Network Card Options, USB, DB9 Serial Highlights ● 2.2kVA / 2200VA line interactive tower UPS system ● 120V nominal output during brownouts to 79V and overvoltages to 147V ● Expandable runtime; Status LEDs with load and battery display ● USB, RS232, EPO and slot for Network Card Options; 3 switched load banks ● NEMA 5-20P input; 2 NEMA 515/20R & 7 5-15R outlets MODEL NUMBER: SMART2200VSXL Package Includes Description Tripp Lite's SMART 2200VSXL intelligent, line interactive UPS with expandable runtime protects server, networking and telecommunications equipment from blackouts, voltage fluctuations and transient surges. Small footprint, tower UPS system occupies only 106 square inches of floorspace with a height of only 14.25 inches. Large capacity 2200 VA/1600 watt rated UPS system offers 7 minutes runtime at full load and 19 minutes at half load during power failures. Runtime is expandable with optional external battery packs. Line interactive voltage regulation corrects brownouts as low as 79V and overvoltages as high as 147V to fully regulated 120V nominal output for smooth continuous operation of connected equipment. Includes a total of 10 outlets, 3 of which can be individually powered off and back on via software interface to selectively reboot remote equipment or shed less critical loads to extend battery runtime for more critical loads. Includes slot for Network Monitoring card option. Includes 2 DB9 and 2 USB enhanced monitoring ports for unattended shutdown, remote control and monitoring of UPS system and power data. Ships in attractive gray color scheme. Compatible with Tripp Lite's PowerAlert and Watchdog service software. Features ● 2200VA/1600 watt output capacity accommodates a variety of server, networking and telecom devices ● High power density 2.2kVA UPS system occupies only 106 square inches of floorspace with a height of only 14.25 inches ● Compatible with North American 120V/60 Hz power as found in the USA, Canada and Mexico ● Offers 7 minutes runtime with a full load of 2200VA and 19 minutes with a half load of 1100VA ● Runtime is expandable with BP48V24-2U (limit 1), BP48V60RT-3U (multi-pack compatible) and BP48V27-2US (multi-pack compatible) external battery packs ● Intelligent battery management system extends battery life ● Line interactive voltage regulation corrects severe brownouts and overvoltages from 79 to 147v back to normal 120v levels without using battery power 1/5 ● SMART 2200VSXL UPS System ● USB & DB9 serial cabling ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● 10 total outlets (7 NEMA5-15R; 2 NEMA5-15/20R; 1 L5-20R) ● Includes NEMA 5-20P straight blade 20 amp input plug connection ● Notification of system status via 5 LEDs and multi-function audible alarms ● 4 built-in communications ports (2-DB9, 2-USB) for remote monitoring and unattended shutdown ● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software, available via FREE download from tripplite.eaton.com/products/power-alert ● Compatible with Tripp Lite UPS management card options TLNETCARD, WEBCARDLX and SNMPWEBCARD ● Supports Tripp Lite's WatchDog software application to restore unresponsive programs by automatically restarting them and rebooting completely locked computers by automatically switching UPS power off and back on again ● Communication ports support on battery, low battery, power restored, AC line voltage, DC battery voltage, load percentage, battery charge current, battery capacity, internal UPS temperature and line frequency status messaging. Interface supports timed inverter shutoff after unattended shutdown, activate self-test and 10 second reboot of connected equipment ● 3 individual customized load management receptacles can be individually powered off and back on again via software interface to reboot remote equipment or shed less critical loads to extend battery runtime for the most critical equipment ● Built-in Emergency Power Off (EPO) interface supports emergency shutoff in large facilities ● Hot-swappable/user replaceable batteries allow on-site battery replacement without powering off connected equipment ● UPS battery set ships fully assembled and ready for use, no time consuming, connection of individual internal batteries by user is necessary Specifications OVERVIEW UPC Code 037332116871 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 16A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-20P Input Circuit Breakers 20A UPS Input Cord Length (ft.) 8 UPS Input Cord Length (m) 2.4 Recommended Electrical Service 20A 120V OUTPUT Output Capacity (VA) 2200 Output Capacity (kVA) 2.2 Output Capacity (Watts) 1600 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Capacity (kW) 1.6 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -18% / +8% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Three switchable single-outlet 5-15R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) PWM sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (7) 5-15R; (2) 5-15/20R; (1) L5-20R Individually Controllable Load Banks Yes BATTERY Runtime Full Load (min.) 7 min. (1600w) Runtime Half Load (min.) 19 min. (800w) Expandable Runtime Yes External Battery Pack Compatibility  BP48V24-2U  (limit 1);  BP48V60RT-3U  (multi-pack compatible);  BP48V272US  (multi-pack compatible) DC System Voltage (VDC) 48 Battery Recharge Rate (Included Batteries) Less than 4 hours from 10% to 90% (typical, full load discharge) Battery Access Battery access door Internal UPS Replacement Battery Cartridge  RBC54  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 79V to 147V Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 95 and 104 are boosted by 12% Severe Undervoltage Correction Input voltages between 79 and 94 are boosted by 24% USER INTERFACE, ALERTS & CONTROLS Switches 2 Switches control off/on power status and alarm-cancel/self-test operation 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Alarm Cancel Operation Power-fail alarm can be silenced using alarm-cancel switch; once silenced, alarm will re-sound to indicate lowbattery status Audible Alarm Audible alarm indicates power-failure, overload and low-battery conditions LED Indicators 5 LEDs indicate line power, battery power, overload, voltage regulation and battery low/replace status SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 480 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Tower Cooling Method Fan Primary UPS Depth (mm) 305 Primary UPS Height (mm) 361 Primary UPS Width (mm) 234 Shipping Dimensions (hwd / in.) 20.00 x 14.90 x 15.20 Shipping Dimensions (hwd / cm) 50.80 x 37.85 x 38.61 Shipping Weight (lbs.) 63.80 Shipping Weight (kg) 28.94 UPS Housing Material Polycarbonate UPS Power Module Dimensions (hwd, cm) 36.07 x 23.37 x 30.48 UPS Power Module Dimensions (hwd, in.) 14.2 x 9.2 x 12 UPS Power Module Weight (kg) 25.63 UPS Power Module Weight (lbs.) 56.5 ENVIRONMENTAL Operating Temperature Range +32 to +104 degrees Fahrenheit / 0 to +40 degrees Celsius Storage Temperature Range +5 to +122 degrees Fahrenheit / -15 to +50 degrees Celsius Relative Humidity 0 to 95%, non-condensing AC Mode Efficiency Rating (100% Load) 94% Audible Noise Audible Noise < 47dBA At Front Side 1 Meter COMMUNICATIONS 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Network Management Cards SNMPWEBCARD;  TLNETCARD ;  WEBCARDLX  Network Monitoring Port Description Supports detailed monitoring of UPS and site power conditions; 2 USB ports, 1 DB9 serial and 1 DB9 contact closure port (4 total) PowerAlert Software For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable 2 USB and 2 DB9 cables included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications Communications Interface Contact closure; DB9 Serial; Slot for SNMP/Web interface; USB LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 79 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Hot swappable batteries WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
SMART2200VSXL
物料型号: - 型号:SMART2200VSXL
器件简介: - 该UPS系统提供2200VA/1600瓦的输出容量,并兼容北美120V/60 Hz电源,适用于美国、加拿大和墨西哥。
引脚分配: - 10个总插座(7个NEMA5-15R;2个NEMA5-15/20R;1个L5-20R) - 3个可单独控制的负载管理插座
参数特性: - 输入电压:120V AC - 输出容量:2200VA/2.2kVA - 输出功率:1600瓦/1.6千瓦 - 电池运行时间:满载7分钟,半载19分钟 - 扩展运行时间:是 - 电池电压:48VDC - 电池充电率:从10%到90%少于4小时
功能详解: - 智能电池管理系统延长电池寿命 - 在线互动电压调节功能,无需使用电池即可将电压从79V到147V调节至120V - 支持通过软件接口单独控制3个负载管理插座 - 包括2个DB9和2个USB增强监控端口,用于远程控制和监控UPS系统
应用信息: - 适用于服务器、网络和电信设备 - 支持Tripp Lite的PowerAlert和Watchdog服务软件
封装信息: - 物理尺寸:106平方英寸占地面积,14.25英寸高 - 颜色:灰色 - 包含USB和DB9串行线缆 - 包括NEMA 5-20P直插20安培输入插头连接
附加信息: - 提供2年保修,注册后可延长至3年 - 提供$250,000的终极终身保险
SMART2200VSXL 价格&库存
很抱歉,暂时无法提供与“SMART2200VSXL”相匹配的价格&库存,您可以联系我们找货
