SMART1500RM2UN
SMART1500RM2UN
    TRIPPLITE
    UPS SMART LCD RACKMOUNT AVR
SMART1500RM2UN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States SmartPro 120V 1.5kVA 1.35kW Line-Interactive Sine Wave UPS, 2U Rack/Tower, WEBCARDLX Network Interface, LCD, USB, 8 Outlets MODEL NUMBER: SMART1500RM2UN Highlights ● Corrects under- and overvoltages from 83V to 147V ● 8 NEMA 5-15R outlets—4 switchable via network interface ● Pre-installed WEBCARDLX network interface for remote management ● Interactive LCD monitoring screen ● 13 min. runtime at half load; 4.5 min. at full load ● To enable the Auto Probe feature, this product requires LX firmware update 15.5.2 or later to be installed Package Includes Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts, brownouts, power surges and line noise. Pre-installed WEBCARDLX network interface permits remote UPS management 24/7. ● SMART1500RM2UN SmartPro 120V 1.5kVA 1.35kW LineInteractive Sine Wave UPS ● Pre-installed WEBCARDLX network interface ● USB-B to USB-A cable ● Micro-USB to USB-A configuration/console cable ● DB9 cable ● EPO cable ● 4-Post rack mounting hardware ● Owner’s manual Description The SMART1500RM2UN SmartPro® 120V 1.5kVA 1.35kW Line-Interactive Sine Wave UPS provides battery backup and AC power protection against blackouts, brownouts, power surges and line noise that can damage electronics or destroy data. Ideal for backing up servers and network storage devices, the SMART1500RM2UN switches to battery mode in milliseconds to keep your connected equipment running long enough to save files and shut down safely with no data loss. Featuring eight NEMA 5-15R outlets (four switchable) and a 10-ft. (3.05 m) power cord with 120V NEMA 5-15P input, the SMART1500RM2UN has an internal battery that provides 13 minutes of support at half load and 4.5 minutes at full load. The Java-free HTML5-based WEBCARDLX interface enables full remote access for site power and UPS status monitoring, configuration, control and email notifications via secure web browser, SNMP, telnet or SSH. It supports 10/100 Mbps auto-sensing for optimum communication with an Ethernet network. Optional EnviroSense2 modules (sold separately) provide a variety of environmental monitoring capabilities. Protocols supported include IPv4, IPv6, HTTP, HTTPS, SMTP, SNMPv1, SNMPv2, SNMPv3, telnet, SSH, FTP, DHCP and NTP. Automatic voltage regulation (AVR) maintains 120V nominal output over an input range of 83V to 147V without using battery power. EMI/RFI noise filtering improves your equipment's performance and prevents damage. Features Protects Mission-Critical Rack-Mounted EquipmentProvides fully regulated sine wave AC output for servers, network storage devices and telecom hardwareAudible alarm signals loss of utility power, overload, low battery and fault conditions8 NEMA 5-15R outlets (4 are switchable)10-ft. (3.05 m) power cord with 120V NEMA 5-15P input0.9 power factor rating570-joule surge suppression rating Reliable Battery BackupSupports half load up to 13 min. and full load up to 4.5 min.Internal batteries designed for hot-swap field replacement95% line-power efficiency rating saves money in energy costs Pre-Installed WEBCARDLX Network InterfaceNetwork interface supports simultaneous communications via built-in USB, DB9 serial/contact-closure and pre-installed WEBCARDLX network management cardAllows full remote access for power monitoring, configuration, control and email notifications via secure web browser, SNMP, Telnet, SSH, or Command Line.Supports 10/100 Mbps auto1/6 1000 Eaton Boulevard Cleveland, OH 44122 United States sensing for communication with an Ethernet network.Optional EnviroSense2 sensors (sold separately) enable site monitoring of temperature, humidity and contact-closure statusReduce Service Calls with Auto Probe Autonomous Device Management. The Auto Probe feature (Firmware 15.5.2 and greater) checks the connectivity status of any networked device and automatically takes one or more user-configured actions if the device fails to respond; actions include outlet reboot, set SNMP traps, SNMP OID sets, and even script execution when used in conjunction with the Tripp Lite PowerAlert Network Shutdown Agent (PANSA) 2 Load Banks with Switchable OutletsCan control 4 outlets remotely to reboot equipment or shed nonessential loads Automatic Voltage Regulation (AVR)Maintains 120V nominal output over input range of 83V-147V without using battery power EMI/RFI Line Noise FilteringRemoves electromagnetic and radio frequency interference that can disrupt or damage equipment's performance Interactive LCD ScreenFront-panel LCD signals operating mode, load level, voltage, battery charge and estimated runtimesRotates for easy viewing in rack-mount or tower configurations Communications PortsUSB and DB9 ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert software (available via free download from tripplite.eaton.com/products/poweralert)EPO port supports emergency shutdown in large facilities Versatile Installation OptionsHardware included for 4-post mounting in 2U of EIA-standard 19 in. rackMounts on wall or 2-post rack with optional 2POSTRMKITWM accessoryMounts in upright tower position with optional 2-9USTAND accessory Specifications OVERVIEW UPC Code 037332178237 UPS Type Line-Interactive INPUT Input Phase Single-Phase Rated input current (Maximum Load) 12A Nominal Input Voltage(s) Supported 120V AC UPS Input Connection Type 5-15P Input Circuit Breakers 15A UPS Input Cord Length (ft.) 10 UPS Input Cord Length (m) 3.1 Recommended Electrical Service 15A 120V OUTPUT Output Capacity (VA) 1500 Output Capacity (kVA) 1.5 2/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Output Capacity (Watts) 1350 Output Capacity (kW) 1.35 Power Factor 0.9 Nominal Voltage Details 120v nominal output in battery mode Frequency Compatibility 60 Hz Output Voltage Regulation (Line Mode) -21%, +8% Output Voltage Regulation (Battery Mode) +/- 5% Load Management Receptacles Two switchable two-outlet 5-15R load banks Output AC Waveform (AC Mode) Sine wave Output AC Waveform (Battery Mode) Pure Sine wave Nominal Output Voltage(s) Supported 110V; 115V; 120V Output Receptacles (8) 5-15R Individually Controllable Load Banks Yes BATTERY Battery Type Valve Regulated Lead Acid (VRLA) Runtime Full Load (min.) 4.5 min. (1350W) Runtime Half Load (min.) 13 min. (675W) Expandable Runtime No DC System Voltage (VDC) 36 Battery Recharge Rate (Included Batteries) Less than 4.5 hours from 10% to 90% (typical, full load discharge) Battery Access Front panel battery access door Internal UPS Replacement Battery Cartridge  RBC93-2U  Battery Replacement Description Hot-swappable, user replaceable batteries VOLTAGE REGULATION Voltage Regulation Description Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 83 to 147 Overvoltage Correction Input voltages between 128 and 147 are reduced by 12% Undervoltage Correction Input voltages between 83 and 107 are boosted by 14% USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Front panel LCD information and configuration screen offers detailed UPS and site power status and operating data, plus configuration of voltage, operating mode, alarm function and a variety of additional options (see manual for detailed LCD configuration and monitoring options) 3/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Switches 3 pushbutton switches control OFF / ON power status, MODE selection and MUTE / ENTER control functions. LX Platform Interface: Recessed reset switch for interface reboot and factory reset. Alarm Cancel Operation Power-fail alarm can be temporarily silenced using alarm-cancel switch; silent mode alarm configuration option available Audible Alarm Audible alarm indicates UPS startup, power-failure, low-battery, overload, UPS fault and remote shutdown conditions LED Indicators Network Link/Activity (Green): Flashes for network activity. Network Speed (Yellow): 10 Mbps (Flashing), 100 Mbps (On steady). LX Platform Interface Status: Normal Operation (Solid Green); Software Update (Alternating Green/Orange ~1/sec); Factory Reset (Alternating Green/Orange ~2/sec). SURGE / NOISE SUPPRESSION UPS AC Suppression Joule Rating 570 UPS AC Suppression Response Time Instantaneous EMI / RFI AC Noise Suppression Yes PHYSICAL Primary Form Factor Rackmount Rack Height 2U Cooling Method Fan Included Mounting Accessory Description Included 4POSTRAILKIT mounting bracket enables installation in 4 post racks from 20.5 to 36 inches (521 to 914mm) Installation Form Factors Supported with Included Accessories 4 post 19 inch rackmount Installation Form Factors Supported with Optional Accessories 2 post rackmount ( 2POSTRMKITWM ); 2-4 post front rail rackmount ( UPSHDEARKIT ); 4 post rackmount short-depth ( 4POSTRAILKITWM ); Tower ( 29USTAND ); Wallmount ( 2POSTRMKITWM ) Minimum Required Rack Depth (cm) 43.18 Minimum Required Rack Depth (inches) 17 Optional Mounting Accessory Notes Optional  2-9USTAND  enables upright tower UPS placement;  2POSTRMKITWM  enables wall-mount and 2-post rackmount installation;  4POSTRAILKITWM  enables installation in 4-post short-depth racks from 14.5 to 23.5 inches (368 to 597mm);  UPSHDEARKIT  enables installation in 2 or 4-post racks using front vertical rails only, without rear support Primary UPS Depth (mm) 342 Primary UPS Height (mm) 88 Primary UPS Width (mm) 439 Shipping Dimensions (hwd / in.) 8.50 x 23.30 x 19.60 Shipping Dimensions (hwd / cm) 21.59 x 59.18 x 49.78 4/6 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 58.95 Shipping Weight (kg) 26.74 UPS Housing Material Steel UPS Power Module Dimensions (hwd, cm) 8.76 x 43.94 x 34.16 UPS Power Module Dimensions (hwd, in.) 3.45 x 17.3 x 13.45 UPS Power Module Weight (kg) 21.09 UPS Power Module Weight (lbs.) 46.5 Unit Weight (lbs.) 46.5000 Unit Weight (kg) 21.09 ENVIRONMENTAL Operating Temperature Range 32° to 104°F (0° to 40°C) Storage Temperature Range 5° to 122°F (-15° to 50°C) Relative Humidity 0 to 95%, non-condensing AC Mode BTU / Hr. (Full Load) 267 Battery Mode BTU / Hr. (Full Load) 1012 AC Mode Efficiency Rating (100% Load) 95% Audible Noise 45 dBA maximum, front side 1m COMMUNICATIONS Network Management Cards  WEBCARDLX  Network Monitoring Port Description Includes Pre-installed WEBCARDLX Network Management interface card. RJ45 Network port, Micro-USB Configuration/Console port, USB A port supports a variety of Envirosense2 environmental and control modules. See Accessories>Management Hardware section for more information about these modules. PowerAlert Software For local monitoring via the UPS’s built-in Serial or USB communication ports, download PowerAlert software at https://tripplite.eaton.com/products/power-alert Communications Cable Micro-USB, USB, and DB9 cabling included WatchDog Compatibility Supports Watchdog application, OS and hard-reboot restart options for remote applications EPO Port RJ11 interface jack with 4 meter cable included. Supports normally open and normally closed EPO systems SNMP Compatibility SNMPv1, V2c, V3 Network UPS Tools (NUT) Compatibility NUT compatible. See a full list of NUT compatible Tripp Lite UPS systems at https://networkupstools.org/stablehcl.html?manufacturer=Tripp%20Lite Network Compatibility 100 Mbps (Fast Ethernet) Network Management Card Description Network management card included Communications Interface DB9 Serial; EPO (emergency power off); Pre-installed network card; Slot for SNMP/Web interface; USB (HID enabled) 5/6 1000 Eaton Boulevard Cleveland, OH 44122 United States LINE / BATTERY TRANSFER Transfer Time 2-4 milliseconds Low Voltage Transfer to Battery Power (Setpoint) 83 High Voltage Transfer to Battery Power (Setpoint) 147 FEATURES & SPECIFICATIONS Cold Start (Startup in Battery Mode During a Power Failure) Cold-start operation supported High Availability UPS Features Auto Probe Monitoring and Reboot (included); Automatic Voltage Regulation (AVR); Hot swappable batteries; Remote management; Surge/noise protection Green Energy-Saving Features Greater than 95% efficiency - GREEN UPS; Individually controllable load banks Grounding Lug Back panel grounding lug STANDARDS & COMPLIANCE Product Certifications CSA (Canada); NOM (Mexico); UL 1778 Product Compliance RoHS; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year warranty, 3 year with registration. Note: Registration is required for 3-year warranty. Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 6/6
SMART1500RM2UN
物料型号:SMART1500RM2UN
器件简介:SmartPro® 120V 1.5kVA 1.35kW Line-Interactive Sine Wave UPS,该不间断电源(UPS)提供电池备份和交流电源保护,以防停电、电压暂降、电源浪涌和线路噪声损坏电子设备或破坏数据。适用于备份服务器和网络存储设备。
引脚分配:提供八个NEMA 5-15R插座(四个可切换)和一个10英尺(3.05米)长的120V NEMA 5-15P输入电源线。
参数特性: - 自动电压调节(AVR):在83V至147V的输入范围内维持120V的标称输出,无需使用电池。 - EMI/RFI噪声过滤:提高设备性能并防止损坏。 - 输出容量:1500VA,1.5kVA,1350W,1.35kW。 - 电池类型:阀控式铅酸电池(VRLA)。 - 满载运行时间:4.5分钟,半载运行时间:13分钟。
功能详解: - 保护关键任务机架安装设备,提供完全调节的正弦波交流输出。 - 可听见的警报信号,用于市电断电、过载、电池电量低和故障情况。 - 预安装的WEBCARDLX网络接口支持通过USB、DB9串行/接触闭合和预安装的WEBCARDLX网络管理卡进行同时通信。 - 支持通过安全Web浏览器、SNMP、Telnet、SSH或命令行进行远程访问。
应用信息:适用于大型网络、高端桌面/小型网络等应用场景。
封装信息:机架安装,2U高度,通过风扇冷却,包含安装在4柱19英寸机架的配件。
SMART1500RM2UN 价格&库存
很抱歉,暂时无法提供与“SMART1500RM2UN”相匹配的价格&库存,您可以联系我们找货
